Retrieve data from my website page on the internet using ESP32
The webpage should have an address like this - mysite.com/data/index.html - and look like this:
<!DOCTYPE HTML><html><head>
  <title>HTML Form to Input Data</title>
  <meta name="viewport" content="width=device-width, initial-scale=1">
  <style>
    html {font-family: Times New Roman; display: inline-block; text-align: center;}
    h2 {font-size: 3.0rem; color: #FF0000;}
  </style>
  </head><body>
  <h2>HTML Form to Input Data</h2>
  <form action="/get">
    Enter a string: <input type="text" name="input_string">
    <input type="submit" value="Submit">
  </form><br>
    Enter an integer: <input type="text" name="input_integer">
  </form><br>
    Enter a floating value: <input type="text" name="input_float">
  </form>
</body></html>
In this page you should enter different types of text which can be treated as text, int or float.
I need to get these values entered into my website using an ESP32 connected to my home modem.
I took inspiration from the internet, in particular here:
https://microcontrollerslab.com/esp32-esp8266-web-server-input-data-html-forms/
This example (given in the link) would suit me just fine, but sadly it works in local.
Instead I need to make the ESP32 pull data from my web page on the net.
My knowledge in this field is very limited if not almost none.
I need help adapting the code below (taken from the link in question) to point to my site's page.
For convenience I have copied the code below.
#include <Arduino.h>
#ifdef ESP32
  #include <WiFi.h>
  #include <AsyncTCP.h>
#else
  #include <ESP8266WiFi.h>
  #include <ESPAsyncTCP.h>
#endif
#include <ESPAsyncWebServer.h>
AsyncWebServer server(80);
const char* ssid = "Your_SSID";
const char* password = "Your_Password";
const char* input_parameter1 = "input_string";
const char* input_parameter2 = "input_integer";
const char* input_parameter3 = "input_float";
const char index_html[] PROGMEM = R"rawliteral(
  <style>
  </style>
  </head><body>
  </form><br>
  </form><br>
  </form>
</body></html>)rawliteral";
void notFound(AsyncWebServerRequest *request) {
  request->send(404, "text/plain", "Not found");
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  if (WiFi.waitForConnectResult() != WL_CONNECTED) {
    Serial.println("Connecting...");
    return;
  Serial.print("IP Address: ");
  server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
    request->send_P(200, "text/html", index_html);
  server.on("/get", HTTP_GET, [] (AsyncWebServerRequest *request) {
    String input_message;
    String input_parameter;
    if (request->hasParam(input_parameter1)) {
      input_message = request->getParam(input_parameter1)->value();
      input_parameter = input_parameter1;
    else if (request->hasParam(input_parameter2)) {
      input_message = request->getParam(input_parameter2)->value();
      input_parameter = input_parameter2;
    else if (request->hasParam(input_parameter3)) {
      input_message = request->getParam(input_parameter3)->value();
      input_parameter = input_parameter3;
    else {
      input_message = "No message sent";
      input_parameter = "none";
    Serial.println(input_message);
    request->send(200, "text/html", "HTTP GET request sent to your ESP on input field ("+ input_parameter + ") with value: " + input_message + "<br><a href=\"/\">Return to Home Page</a>");
  server.onNotFound(notFound);
  server.begin();
Thanks in advance
In that case you should not run a server on the ESP but a client. Your client (the ESP) should connect to the server and send a GET or POST.
Can't help you further but there should be enough on the web.
Head over to namecheap and register your domain and then transfer it to something like cloudflare and setup your cname and such to point to the ip of your ESP32 then, I'm thinking run a GET function/routine like sterretje said via setTimeout().
Assuming you're NOT using a static IP, I'm interested in seeing your code to keep your IP up to date at your DNS provider. There's plenty of sh/bash scripts that you can find to do it but, I haven't seen a C or C++ implementation yet. I just recently have been looking for one and don't personally feel like porting a .sh script (too much string juggling... but I will if I have to :-(.
