reversed array
in python, there is function to reverse the elements in an array, I believe it is just 'reversed arraname()'
Is there such a thing in C++? I have looked throught the fundamentals page and glanced through a C++ turorial and cannot find that function.
I am trying to arrange Array[1,2,3,4,5,6] to array[6,5,4,3,2,1]
Roger Ayotte
No.
But it isn't necessary - you could just read the array backwards
AWOL,
Thanks, I know I could, looking fore shortcut. What about reverse_copy?
Make a copy that is the reverse?
Just looking for a way not to iterate through it. I've found out recently that for loops are as bad as delay()!!
Roger
“ I've found out recently that for loops are as bad as delay()!!”
Wrong !!
larryd:
Wrong !!
+1
" I've found out recently that for loops are as bad as delay()!!"
They can be. If you are stepping backwards through an array , say to reverse it , and your loop control variable is an unsigned integer, you could be in for a long wait.
They are not as bad as delay, but you need to use them carefully. If you use them for something that will take forever (well, even a few milliseconds) then they can be as bad as delay. For (and while) should be used for things you can be sure will complete quickly and will not depend on anything else that might slow them down.
rcayot:
How do you think a "reverse copy" feature would work? It would have to iterate through the array element-by-element and copy them into a new memory area in the reverse sequence. So, not only is that NOT a shortcut, but it uses more memory.
You can do it with swapping (using the degenerated machinery of a swap sort). Swap the first and last, second and second last, etc... but you have to make a special case for an odd number of elements because you will have one extra in the middle that doesn't move.
The shortest possible shortcut is to read the array backwards.
Or, for an arbitrary index:
reverseIndex = arraySize - index - 1;
okay, here goes.
I have this code with the help of others. It takes a set of six LEDs and pulses them with PWM. The first LED pulses, then after a short delay. the second starts (before the first ends) etc cetera.
The code below works, but what I want to do is reverse the elements in the array so I can then run trhe sequence backwards. If I terate throught the loop, the LEDs will NOT light simultaneously.
  pulse LED with PWM
  https://forum.arduino.cc/index.php?topic=675980
  by noiasca
uint32_t CMillis = 0;
class PulseLed
  private :
    const byte ledPin;                       // has to be a GPIO with PWM
    uint8_t interval = 2;                   // the intervall in milliseconds for each change
    uint32_t previousMillis = 0;             // stores the last change
    uint8_t pwm = 0;                         // actual value of PWM
    uint8_t start = 0;                       // range from (lowest PWM value)
    uint8_t end =  255;                      // range to (highest PWM value
    uint8_t pulsecount = 0;
    int y =0;
    bool dir = true;
  public :
    PulseLed ( byte ledPin) :
      ledPin(ledPin)
    void begin()
      pinMode(ledPin, OUTPUT);
    void setInterval(byte newInterval)
      interval = newInterval;
    void setRange( byte newStart, byte newEnd)
      if (newEnd > newStart)
        start = newStart;
        end = newEnd;
    void setpulsecount(byte newpulsecount)
      pulsecount = newpulsecount;
  void tick()
  if ((millis() - previousMillis > interval) && (pulsecount != 0))
  previousMillis = millis();
  if  (y >= start && dir == true)
    if ((y <= end -1) && (dir == true)) y = y + 17;
    else dir = false;
    if ((y > start) && (dir == false)) y = y - 1;
    else dir = true;
    analogWrite(ledPin, y);
    if (y <= start)
    pulsecount = (pulsecount - 1);
PulseLed pulseLed[] {2, 3, 4, 5, 6, 7};
  for (int i = 0; i < 6; i ++)
  pulseLed[i].setRange(0, 255);   // set an individuall PWM range from ... to ...
  pulseLed[i].setInterval(2);    // set the interval/speed of pulsing
  pulseLed[i].setpulsecount(1);  // set number of times to pulse
CMillis = millis();
pulseLed[0].tick();
if (millis() - CMillis <= 50) {return;}
pulseLed[1].tick();
if (millis() - CMillis <= 100) {return;}
pulseLed[2].tick();
if (millis() - CMillis <= 150) {return;}
pulseLed[3].tick();
if (millis() - CMillis <= 200) {return;}
pulseLed[4].tick();
if (millis() - CMillis <= 250) {return;}
pulseLed[5].tick();
if (millis() - CMillis <= 1100) {return;}
// Serial.println(millis() - CMillis);
CMillis = millis();
SO, If I could reverse the order pin numbers are in teh array, the void loop will keep running back and forth.
Roger Ayotte
P.S. of course the for loops are not exactly as bad as delay, BUT, my experience, which is very limited, is that the for loop will run exclusively until completed. Perhaps using an if loop in hte middle might work, but at my stage of expertise, I have not been able to accomplish that....... yet!
For that purpose, it makes no sense to reverse the array. You should simply read it backwards.
"Reading the array backwards" has been mentioned several times, but is evidently quite a difficult-to-grasp concept.
