RF 315/433 MHz Transmitter-receiver Module and Arduino?
i but this: http://www.instructables.com/id/RF-315433-MHz-Transmitter-receiver-Module-and-Ardu/
but i haven't a idea to connect or the code to write for test this.. i start whit the trasmitter and i try to trasmit a signal in my icom radio scanner..
i install the virtualwire.h library but i want trasmit an inpulse not a message.. no one can help me write the code?and connect the trasmitter? to send a inpulse in my icom scanner
i but this
You did what?
Why not? There are pictures in step 2. It hardly gets any simpler.
The code is in step 3.
Scanners don't detect signals by themselves. Signals that change are what a scanner detects.
What you think you want to do and what is reasonable to do may not be the same thing at all. Start with explaining what you are trying to accomplish, NOT how you think you should do it.
Not without understanding the requirements, which you haven't described.
There% was* a) picture$. How@ much! more+ do( you# need?
Don't splatter punctuation marks all over the place. Do use capital letters appropriately.
i try to send a signal in my icom radio scanner..
i find the correct code
#include <VirtualWire.h>
    Serial.begin(9600);   // Debugging only
    Serial.println("setup");
    // Initialise the IO and ISR
    //vw_set_ptt_inverted(true); // Required for DR3100
    vw_setup(2000);  // Bits per sec
    const char *msg = "hello";
    digitalWrite(13, HIGH); // Flash a light to show transmitting
    vw_send((uint8_t *)msg, strlen(msg));
    vw_wait_tx(); // Wait until the whole message is gone
    digitalWrite(13, LOW);
    delay(200);
but this trasmin in wfm i want trasmit in am... i'm not english sorry for mistake.. but in my language not is simple...
You can not transmit in AM using a FM transmitter it is not possible.
I found this video helpful. It lets you understand and write your own communication system using RF transmitters and receivers.
And here is a simple code that is more explanatory the video provides.
https://code.google.com/p/rf85/
Using Virtual Wire library is a real pain in the but.
Can these RF 315/433 MHz Transmitter-receiver Modules send and receive Amplitude Modulated (AM) signals the could be outputted to an external speaker?
Also, could these modules be modified to work @ 900 MHz?
What signal are you planning to modulate the amplitude of?
No.
hello. im a beginner in using arduino. how do i program it so that whenever the arduino gets an input of 1, the transmitter will send a signal to the receiver. im using the program below, but instead of blinking lights id like to have a steady light. pls help
for Transmitter
vw_set_tx_pin(3);
pinMode(8, INPUT);
pinMode(9, INPUT);
pinMode(10, INPUT);
pinMode(11, INPUT);
digitalWrite(8, HIGH);
digitalWrite(9, HIGH);
digitalWrite(10, HIGH);
digitalWrite(11, HIGH);
char *msg;
if(digitalRead(8) == LOW){
char *msg = "1";
digitalWrite(13, true); // Flash a light to show transmitting
digitalWrite(13, false);}
if(digitalRead(9) == LOW){
char *msg = "2";
if(digitalRead(10) == LOW){
char *msg = "3";
if(digitalRead(11) == LOW){
char *msg = "4";
for receiver
Serial.println("RECEIVER");
vw_set_rx_pin(2);
vw_rx_start();
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
pinMode(11, OUTPUT);
digitalWrite(8, LOW);
digitalWrite(9, LOW);
digitalWrite(10, LOW);
digitalWrite(11, LOW);
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
if (vw_get_message(buf, &buflen)) // Non-blocking
int i;
digitalWrite(13, true); // Flash a light to show received good message
// Message with a good checksum received, dump it.
Serial.print("Received: [");
for (i = 0; i < buflen; i++)
Serial.print(buf*);*
// if(buf == '1'){digitalWrite(8, HIGH);}
// if(buf == '2'){digitalWrite(9, HIGH);}
// if(buf == '3'){digitalWrite(10, HIGH);}
// if(buf == '4'){digitalWrite(11, HIGH);}
// Serial.print(" ");
* Serial.print("] strength(");*
* int sensorValue = analogRead(A1);*
* Serial.print(sensorValue);*
* Serial.println(")");*
* digitalWrite(13, false);*
The code that you improperly posted does something. You failed to describe what it does. How what it does differs from what you want is not clear.
