hello everyone
i'm working on a project to make an rc car controlled by a RF remote controller. my remote controller has 4 buttons (forward, backward, right turn and left turn) to make the robot move, the required button has to be kept pressed and it stops when the button is released. however, i'm having a small problem currently; the car should be moving continuously unless i release my finger from the button but each time i switch it on, it behaves differently, for example if i keep pressing forward button, it moves forward discontinuously, in other words it keeps stopping for a while and moves again like being interrupted. i checked the electronic circuit and the antennas for both transmitter and receiver and both seemed fine.
so can you guys help me out?
transmitter code:
#include <VirtualWire.h>
char *controller;
int forward = 4;
int backward = 3;
int rightTurn = 5;
int leftTurn = 2;
int L = 13;
int buttonStateForward = 1;
int buttonStateBackward = 1;
int buttonStateRightTurn = 1;
int buttonStateleftTurn = 1;
Serial.begin (9600); // Debugging only
Serial.println ("Setup");
pinMode(13,OUTPUT);
pinMode(forward, INPUT);
pinMode(backward, INPUT);
pinMode(rightTurn, INPUT);
pinMode(leftTurn, INPUT);
vw_set_ptt_inverted(true); //
vw_set_tx_pin(9);
vw_setup(2000);// speed of data transfer Kbps
void loop(){
buttonStateForward = digitalRead(forward);
buttonStateBackward = digitalRead(backward);
buttonStateRightTurn = digitalRead(rightTurn);
buttonStateleftTurn = digitalRead(leftTurn);
if (buttonStateForward == LOW) {
controller="1" ;
vw_send((uint8_t *)controller, strlen(controller));
vw_wait_tx(); // Wait until the whole message is gone
digitalWrite(13,1);
else if (buttonStateForward == HIGH) {
controller="5" ;
digitalWrite(13,1);
if (buttonStateBackward == LOW) {
controller="2" ;
digitalWrite(13,1);
else if (buttonStateBackward == HIGH){
controller="5" ;
digitalWrite(13,1);
if (buttonStateRightTurn== LOW) {
controller="3" ;
digitalWrite(13,1);
else if (buttonStateRightTurn== HIGH) {
controller="5" ;
digitalWrite(13,1);
if (buttonStateleftTurn == LOW) {
controller="4" ;
digitalWrite(13,1);
else if (buttonStateleftTurn == HIGH) {
controller="5" ;
digitalWrite(13,1);
receiver code:
const int IN1 = 5;
const int IN2 = 4;
const int IN3 = 2;
const int IN4 = 3;
vw_set_ptt_inverted(true); // Required for DR3100
vw_set_rx_pin(12);
vw_setup(2000); // Bits per sec
pinMode(13, OUTPUT);
pinMode(IN1, OUTPUT);
pinMode(IN2, OUTPUT);
pinMode(IN3, OUTPUT);
pinMode(IN4, OUTPUT);
vw_rx_start(); // Start the receiver PLL running
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
if (vw_get_message(buf, &buflen)) { // Non-blocking
int i;
digitalWrite(13,HIGH);
for (i = 0; i < buflen; i ++) {
Serial.print (buf [i]);
if(buf [i] == '1') {
forward ();
Serial.println (" = forward");
if(buf [i] == '2') {
backward ();
Serial.println (" = backward");
if(buf [i] == '4') {
right ();
Serial.println (" = right");
if(buf [i] == '3') {
left ();
Serial.println (" = left");
if(buf [i] == '5') {
Stop ();
Serial.print(" ");
Serial.println("");
digitalWrite(13,LOW);
void forward () {
digitalWrite (IN1, LOW);
digitalWrite (IN2, HIGH);
digitalWrite (IN3, LOW);
digitalWrite (IN4, HIGH);
void backward () {
digitalWrite (IN1, HIGH);
digitalWrite (IN2, LOW);
digitalWrite (IN3, HIGH);
digitalWrite (IN4, LOW);
void right () {
void left () {
void Stop () {
