Hello, I've been trying to send a char from one arduino to another using ManiacBug's RF24 library, but whenever the receiver reads the value it gets a few weird values, however, if I send the same value repeated times the receiver starts to get the correct value, for example, if I send 1 from time to time, the receiver sometimes reads 1, sometimes 68 and sometimes -17, everytime it outputs one of those values, I even ran the scanner to check for "empty" channels and switched to them, still the same behavior...
Well, here's the code:
//ON BOTH ARDUINOS
const uint64_t pipes[2] = { 0xF0F0F0F0E1LL, 0xF0F0F0F0D2LL };
void setup(void)
printf_begin();
radio.begin();
radio.setRetries(15,15);
radio.setPayloadSize(RADIO_PAYLOAD_SZ); //8
radio.setChannel(RADIO_CHANNEL); //currently set to 8
radio.openWritingPipe(pipes[RADIO_PIPE_TO]); //on the sender val = 1 and on receiver val = 0
radio.openReadingPipe(1,pipes[RADIO_PIPE_FROM]); //on the sender val = 0 and on receiver val = 1
//ON ONE ARDUINO (THE "SENDER")
void loop(void)
if (EVENT) {
char c = 1;
radio.write(&c,sizeof(char)); //this is supposed to be the command to send, which is being read incorrectly
radio.write(&value, sizeof(unsigned long));
radio.write(&len, sizeof(int));
radio.write(&type, sizeof(int));
char c = 2;
//ON THE OTHER ARDUINO (THE "RECEIVER")
short x = 0; //I tried to use a struct to receive all the values but it gets "corrupted" when reading as well
void loop(void)
if ( radio.available() )
if ( x == 0 ) {
char c = 0;
radio.read(&c, sizeof(char));
printf("command %d\r\n", c);
if ( c == 2 ) {
x = 3;
if ( radio.read(&value, sizeof(unsigned long)) )
x = 1;
} else if ( x == 1 ) {
if ( radio.read(&len, sizeof(int)) )
x = 2;
} else if ( x == 2 ) {
if ( radio.read(&type, sizeof(int)) )
x = 3;
if ( x == 3 ) {
doStuff();
x = 0;
Whenever I send "c" to the receiver it receives weird values, including but not only the value I sent, for instance, when I send 1, the receiver reads 1, -17 and 68, and when I send 2 it reads 2 and usually 68 as well.
On the receiver side I tried to use a struct to receive all values instead of using the flag "x" to indicate what's the hardware reading at the moment, but whenever I read the struct all values inside it would be garbage. The struct was something like:
typedef struct {
unsigned long Value;
int Len;
int Type;
} MyStruct;
MyStruct s;
radio.write(&s, sizeof(MyStruct));
radio.,read(&s, sizeof(MyStruct)); //garbage inside the struct
Does anyone have any idea what could it be...? I'm currently using a NRF24L01+, VCC on 3v3, CE is on 8, CSN 10, SCK 13, MISO 12 and MOSI 11 attached to an Arduino Nano.
Well, please let me know if I forgot to input any other important information, thanks everyone!
