Rfid arduino reader to gps
Hi Everyone
I have a project to send the rfid reader data to gps 1wire data.
In detail
i am reading rfid tag number using rfid reader and this is data is send to another arduino using nrf24l01. other side nrf24l01 reciver receives the data and can be seen on serial monitor.
now th question is i need to send this data which received at receiver side of nrf24 to other additional gps module which has 1 wire data input.
can anyone please explain hot the data which is seen on serial monitor can be send from arduino pin to 1 wire of external gps module.
Thank you in advance
Your topic was MOVED to its current forum category which is more appropriate than the original as it has nothing to do with Installation and Troubleshooting of the IDE
What is the GPS going to do with the data you send ?
Gps will get the card detail and link to vehicle. that particular card reader is linked to particluar car which has gps
Please post a link to the GPS unit that you will be using
Has it got any on board processing and storage ?
tetonika gps 630
i has option 1wire data pin which can read data.
but my question is how to send data from arduino to this. like which pins i have to use. in arduino serial monitor i can see the values
You mean GPS, Global Positioning System?
Do you expect the GPS to transmit?
I think you will find they are called GPS RECEIVERS.
Can you please draw a block diagram of how you are thinking of configuring this network?
An image of a hand drawn diagram will be fine.
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
GPS device is already installed on vehicle its used for fleet management.
my questiuon is hot to send data which us received on arduino to gps 1 wire.
i see data on arduino serial monito i need to send this data to gps 1wire data.
i can connect gps 1 wire data to any pin of arduino ?
or i need to connec the gps 1wire data wire to tx pin of arduino?
I gather;
You wish to send data TO the GPS, why?
What will the GPS do with the data?
Or do we have a translation problem?
The Fleet management GPS ONLY provides location and speed data to the management device, the fleet management device does not send any data to the GPS.
Please a block diagram with arrows showing the direction of data flow.
Thanks.. Tom... :smiley: :+1: :coffee: :australia:
Hi. gps will know which card is attached to vehicle
imgaine we have driver car he insert to card reader and from card reader using nrf data is send to another arduino which is near gps device in the vehicle. so from receiver arduino need to send data to gps.
gps has one wire data pin
Why?
Do you mean the Fleet device will combine the RFID data from the UNO and GPS data and log it?
The GPS is part of the Fleet device, what will the GPS do with the data?
Can you post link data/spec of the one wire GPS?
PLEASE draw and post a block diagram.
Can you please tell us your electronics, programming, arduino, hardware experience?
Thanks.. Tom..
Hi
gps is fleet device we can everydats of the vehicle form gps device. here gps is not just navigation, it has everything including tacho can fms and other additonal global parameter.
from arduino how can data be transferred to gps 1 wire data wire
So you are talking about the single fleet device which has a GPS connected.
The fleet device does not use the GPS to transmit data, GPS can't transmit.
The fleet controller probably has a mobile phone sim-card in it or GSM.
Have you actually looked at the device and read its manual?
Can you post a link to data/specs of the fleet device, and a photograph.
Tom Please forget about gps.
i need to know how the data which is on serial monitor like 88889999 this must be sent to another input device can you please tell how this can be done?
It depends on the devices and the format of the data?
i have received data using nrf24l01 from another arduino so i need to send this data to gps device using wire. i am using teltoniks gps module
Something like this;
Teltonika FMB120 | GPS Tracker | GNSS, GSM, Bluetooth, Backup battery
Note the GSM, you cannot send data to the GPS.
Contact the distributor/manufacturer and ask them, how will the device know what to do with the data you want to send to it.
PS. G'dnight I'm off to bed. :sleeping: :sleeping: :sleeping: :sleeping: :sleeping:
