Hello all,
I'm looking for help setting up a RC522 RFID reader/writer and need some help pulling and storing card ID numbers. I'm using a MEGA2560. I'm trying to do the "simple" access granted (green LED) access denied (red LED).
I'm using the RC522 library from Miguelbalboa and the RFID_default_keys example sketch as a base, which works fine and i can read all three of my badges.
From what I've learned from reading is that I have to try and pull the CARD ID number from the dump_byte_array function and create a String. Then I compare that to an array of cards I have. Sounds simple but I cannot find a way to acquire the CARD ID and store it.
I've searched for the past three days and seem to find the same builds and sketches but not the one I'm looking for. I'm a "noob" so I may have over looked it in my search. I may be making this way more complicated then i have to but thats why I'm asking the experts.
Anywho. so from what I have figured out is that here is how they grab the data from the cards,
void dump_byte_array(byte *buffer, byte bufferSize) {
for (byte i = 0; i < bufferSize; i++) {
Serial.print(buffer[i] < 0x10 ? " 0" : " ");
Serial.print(buffer[i], HEX);
and here is how they write it to the serial port.
// Look for new cards
if ( ! mfrc522.PICC_IsNewCardPresent())
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial())
return;
// Show some details of the PICC (that is: the tag/card)
Serial.print("Card ID:");
dump_byte_array(mfrc522.uid.uidByte, mfrc522.uid.size);
Serial.print("PICC type: ");
byte piccType = mfrc522.PICC_GetType(mfrc522.uid.sak);
I just don't know how I can intercept the information and make it into a usable form for me.
and here is the whole sketch. I put in steve bill and bob and their CARD ID's so i don't lose them.
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN 5 // Configurable, see typical pin layout above
#define SS_PIN 53 // Configurable, see typical pin layout above
#define STEVE C3 B0 8B F4
#define BILL A3 3E 75 D5
#define BOB D6 B7 E7 3D
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
// Number of known default keys (hard-coded)
// NOTE: Synchronize the NR_KNOWN_KEYS define with the defaultKeys[] array
#define NR_KNOWN_KEYS 8
// Known keys, see: https://code.google.com/p/mfcuk/wiki/MifareClassicDefaultKeys
byte knownKeys[NR_KNOWN_KEYS][MFRC522::MF_KEY_SIZE] = {
{0xff, 0xff, 0xff, 0xff, 0xff, 0xff}, // FF FF FF FF FF FF = factory default
{0xa0, 0xa1, 0xa2, 0xa3, 0xa4, 0xa5}, // A0 A1 A2 A3 A4 A5
{0xb0, 0xb1, 0xb2, 0xb3, 0xb4, 0xb5}, // B0 B1 B2 B3 B4 B5
{0x4d, 0x3a, 0x99, 0xc3, 0x51, 0xdd}, // 4D 3A 99 C3 51 DD
{0x1a, 0x98, 0x2c, 0x7e, 0x45, 0x9a}, // 1A 98 2C 7E 45 9A
{0xd3, 0xf7, 0xd3, 0xf7, 0xd3, 0xf7}, // D3 F7 D3 F7 D3 F7
{0xaa, 0xbb, 0xcc, 0xdd, 0xee, 0xff}, // AA BB CC DD EE FF
{0x00, 0x00, 0x00, 0x00, 0x00, 0x00} // 00 00 00 00 00 00
* Initialize.
pinMode (LED1, OUTPUT);
Serial.begin(9600); // Initialize serial communications with the PC
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522 card
Serial.println("Try the most used default keys to print block 0 of a MIFARE PICC.");
* Helper routine to dump a byte array as hex values to Serial.
* Try using the PICC (the tag/card) with the given key to access block 0.
* On success, it will show the key details, and dump the block data on Serial.
* @return true when the given key worked, false otherwise.
boolean try_key(MFRC522::MIFARE_Key *key)
boolean result = false;
byte buffer[18];
byte block = 0;
byte status;
// Serial.println("Authenticating using key A...");
status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, block, key, &(mfrc522.uid));
if (status != MFRC522::STATUS_OK) {
// Serial.print("PCD_Authenticate() failed: ");
// Serial.println(mfrc522.GetStatusCodeName(status));
return false;
// Read block
byte byteCount = sizeof(buffer);
status = mfrc522.MIFARE_Read(block, buffer, &byteCount);
// Serial.print("MIFARE_Read() failed: ");
else {
// Successful read
result = true;
Serial.print("Success with key:");
dump_byte_array((*key).keyByte, MFRC522::MF_KEY_SIZE);
// Dump block data
Serial.print("Block "); Serial.print(block); Serial.print(":");
dump_byte_array(buffer, 16);
mfrc522.PICC_HaltA(); // Halt PICC
mfrc522.PCD_StopCrypto1(); // Stop encryption on PCD
return result;
* Main loop.
return;
return;
digitalWrite(LED1, HIGH);
// Try the known default keys
MFRC522::MIFARE_Key key;
for (byte k = 0; k < NR_KNOWN_KEYS; k++) {
// Copy the known key into the MIFARE_Key structure
for (byte i = 0; i < MFRC522::MF_KEY_SIZE; i++) {
key.keyByte[i] = knownKeys[k][i];
// Try the key
if (try_key(&key)) {
// Found and reported on the key and block,
// no need to try other keys for this PICC
