Rfid reader module - UART software serial
Screenshot 2024-01-10 193402
i have rfid reader module that send data over UART https://www.aliexpress.com/item/32868030909.html
i connected VCC to 3v
GND to GND
RX to D4
#include <SoftwareSerial.h>
const int RFID_rx = D4;
SoftwareSerial rfid_Serial(RFID_rx, -1);  // RX pin is D4, TX pin is not used (-1)
  rfid_Serial.begin(9600);
  // RFID
  if (rfid_Serial.available()) {
    // Read the incoming data
    int incomingByte = rfid_Serial.read();
    // Print the received byte in hexadecimal format
    Serial.print("Received: 0x");
    Serial.printf("%02X", incomingByte);
  // RFID
what i recieve when put a tag on module is:
Received: 0xF8
Received: 0xF8
Received: 0xF8
Received: 0xF8
Received: 0xF8
Received: 0xF8
Received: 0xF8
Received: 0xF8
Received: 0xF8
Received: 0xF8
Received: 0xF8
    Serial.print("Received: 0x%02X\r\n", incomingByte);
Ok. And what does the documentation say that means?
12V or 5V?
its 5v but in aliexpress page they writed:
the module can operate normally in the range of 3v-5v
there just some info in aliexpress page , link above.
it should work like this but idk maybe there is something wrong in my code
do aliexpress provide an example sketch to test delivered module that it is still working? or how do you know how to handle this module?
Yes, there is and it shows exactly what the UART message is. And it is multiple bytes long, but your program only reads and processes a SINGLE byte/character. Why do you not read the entire message before doing any processing of the data?
canu write code here coz i dont know how
Could, but won't. Spend a week or so studying how other programs read message, not single characters, and change your program and test it.
Can you measure the voltage on the "UART" pin when the device is idle?
I can't tell for sure, but it looks somewhat like there is an rs232 converter chip on that board, in which case it won't work directly with SoftwareSerial.
