Hello,
I have a program that I want it to read a RFID tag and send the data to Carriots. I have the program set up so after a successful card read that it turns off the reader sends some data and delays for 10 seconds before reactivating the reader. The problem is the program seems to often run the while loop a second time sending the RFID data a second time sending a second stream of information to Carriots. I am kind of lost on why this is happening. Here is the code.
#include <SPI.h>
#include <Ethernet.h>
// include the SoftwareSerial library so we can use it to talk to the RFID Reader
#include <SoftwareSerial.h>
#define enablePin 5 // Connects to the RFID's ENABLE pin
#define rxPin 6 // Serial input (connects to the RFID's SOUT pin)
#define txPin 7 // Serial output (unused)
#define BUFSIZE 11 // Size of receive buffer (in bytes) (10-byte unique ID + null character)
#define RFID_START 0x0A // RFID Reader Start and Stop bytes
#define RFID_STOP 0x0D
// set up a new serial port
SoftwareSerial rfidSerial = SoftwareSerial(rxPin, txPin);
const int ON = 1; // Constant to indicate that lights are on
const int OFF = 2; // Constant to indicate that lights are off
const String APIKEY = "1475"; // Replace with your Carriots apikey
const String DEVICE = "device key"; // Replace with the id_developer of your device
String passId;
String inVar;
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = { 0x34, 0x71, 0x6D, 0x08, 0xA5, 0xE9 };
IPAddress ip(192,168,1,73); // Your IP Address
IPAddress server(82,223,244,60); // api.carriots.com IP Address
EthernetClient client; // Initialize the library instance
int outledPin = 3; // Led pin number
int inledPin = 2;
int rfread = OFF; // Current status
int newrfread = OFF; // New status
// The setup routine runs once when you press reset
// define pin modes
pinMode(enablePin, OUTPUT);
pinMode(rxPin, INPUT);
digitalWrite(enablePin, HIGH); // disable RFID Reader
pinMode(outledPin, OUTPUT); // Initialize the digital pin as an output
pinMode(inledPin, OUTPUT); // Initialize the digital pin as an output
digitalWrite(inledPin, HIGH); // disable RFID Reader
Serial.begin(9600); // Start serial port
while (!Serial); // wait until ready
Serial.println("\n\nParallax RFID Card Reader");
Serial.println(F("Starting"));
// set the baud rate for the SoftwareSerial port
rfidSerial.begin(2400);
Ethernet.begin(mac); // Start the Ethernet connection
delay(1000); // Give the Ethernet shield a second to initialize
// The loop routine runs over and over again forever
When the RFID Reader is active and a valid RFID tag is placed with range of the reader,
the tag's unique ID will be transmitted as a 12-byte printable ASCII string to the host
(start byte + ID + stop byte)
For example, for a tag with a valid ID of 0F0184F07A, the following bytes would be sent:
0x0A, 0x30, 0x46, 0x30, 0x31, 0x38, 0x34, 0x46, 0x30, 0x37, 0x41, 0x0D
We'll receive the ID and convert it to a null-terminated string with no start or stop byte.
digitalWrite(enablePin, LOW); // enable the RFID Reader
// Wait for a response from the RFID Reader
// See Arduino readBytesUntil() as an alternative solution to read data from the reader
char rfidData[BUFSIZE]; // Buffer for incoming data
char offset = 0; // Offset into buffer
rfidData[0] = 0; // Clear the buffer
while(1)
if (rfidSerial.available() > 0) // If there are any bytes available to read, then the RFID Reader has probably seen a valid tag
rfidData[offset] = rfidSerial.read(); // Get the byte and store it in our buffer
if (rfidData[offset] == RFID_START) // If we receive the start byte from the RFID Reader, then get ready to receive the tag's unique ID
offset = -1; // Clear offset (will be incremented back to 0 at the end of the loop)
else if (rfidData[offset] == RFID_STOP) // If we receive the stop byte from the RFID Reader, then the tag's entire unique ID has been sent
rfidData[offset] = 0; // Null terminate the string of bytes we just received
newrfread = ON;
digitalWrite(enablePin, HIGH); // enable the RFID Reader
break; // Break out of the loop
offset++; // Increment offset into array
if (offset >= BUFSIZE) offset = 0; // If the incoming data string is longer than our buffer, wrap around to avoid going out-of-bounds
Serial.println(rfidData); // The rfidData string should now contain the tag's unique ID with a null termination, so display it on the Serial Monitor
Serial.flush(); // Wait for all bytes to be transmitted to the Serial Monitor
if (newrfread == ON) {
if (strcmp(rfidData,"0400121C69")==0){
passId = "Pass1";
else if (rfidData == "35021DD169") {
passId = "Pass2";
if (digitalRead(inledPin) == HIGH){
digitalWrite(inledPin, LOW);
digitalWrite(outledPin, HIGH);
inVar = "Out";
else {
digitalWrite(outledPin, LOW);
inVar = "In";
newrfread = OFF;
//Serial.println("check variable");
//Serial.println(passId);
delay(10000);
sendStream();
//if (weight != newWeight) { // Check if we have a change in status
//Serial.println(F("Send Stream"));
//weight = newWeight; // Status update and send stream
//sendStream();
// If there's incoming data from the net connection, send it out the serial port
// This is for debugging purposes only
//while (client.available()) {
//char c = client.read();
//Serial.print(c);
//if (!client.connected()) {
// client.stop();
// Send stream to Carriots
void sendStream()
String txt = passId; // Text to send
//String inVar = "In";
//Serial.println(txt); // For debugging purpose only
if (client.connect(server, 80)) { // If there's a successful connection
Serial.println(F("connected"));
// Build the data field
String json = "{\"protocol\":\"v2\",\"device\":\""+DEVICE+"\",\"at\":\"now\",\"data\":{\"Pass\":\""+txt+"\",\"IN\":\""+inVar+"\"}}";
// Make a HTTP request
client.println("POST /streams HTTP/1.1");
client.println("Host: api.carriots.com");
client.println("Accept: application/json");
client.println("User-Agent: Arduino-Carriots");
client.println("Content-Type: application/json");
client.print("carriots.apikey: ");
client.println(APIKEY);
client.print("Content-Length: ");
int thisLength = json.length();
client.println(thisLength);
client.println("Connection: close");
client.println();
client.println(json);
//Serial.println(json);
else {
// If you didn't get a connection to the server:
Serial.println(F("connection failed"));
