Hello everyone,
I'm writing to you because i need help me on my project. I have recently decided to create a bluetooth controlled rgb led. Besides i want to highlight the fact that I am completely a noob. So in order to achieve my goal, i followed the instructions of webpage:
However i want to improve the program, but i don't know how to do it correctly.
First of all , i would like the led to be switched on , and to be completely "blue" as soon as i plugged the arduino board to the computer , which is not the case(without having to use the app). Moreover i would also like the led to fade, ( while keeping the same color i have selected), 2 seconds after i select the color using the smartphone app( as described in the webpage)
Would you mind helping me please ????? It would be so great .
the program i have used to achieve my project:
#include <SoftwareSerial.h>
#include <Wire.h>
SoftwareSerial mySerial(10,11); //Define PIN11 & PIN12 as RX and TX pins
int PIN_RED = 3;
int PIN_GREEN = 5;
int PIN_BLUE = 6;
String RGB = "";
String RGB_Previous = "255.255.255";
String ON = "ON";
String OFF = "OFF";
boolean RGB_Completed = false;
pinMode (PIN_RED, OUTPUT);
pinMode (PIN_GREEN, OUTPUT);
pinMode (PIN_BLUE, OUTPUT);
mySerial.begin(9600);
RGB.reserve(30);
while(mySerial.available()){
char ReadChar = (char)mySerial.read();
if(ReadChar == ')'){
RGB_Completed = true;
}else{
RGB += ReadChar;
if(RGB_Completed){
Serial.print("RGB:");
Serial.print(RGB);
Serial.print(" PreRGB:");
Serial.println(RGB_Previous);
if(RGB==ON){
RGB = RGB_Previous;
Light_RGB_LED();
}else if(RGB==OFF){
RGB = "0.0.0";
Light_RGB_LED();
}else{
Light_RGB_LED();
RGB_Previous = RGB;
RGB = "";
void Light_RGB_LED(){
int SP1 = RGB.indexOf(' ');
int SP2 = RGB.indexOf(' ', SP1+1);
int SP3 = RGB.indexOf(' ', SP2+1);
String R = RGB.substring(0, SP1);
String G = RGB.substring(SP1+1, SP2);
String B = RGB.substring(SP2+1, SP3);
Serial.print("R=");
Serial.println( constrain(R.toInt(),0,255));
Serial.print("G=");
Serial.println(constrain(G.toInt(),0,255));
Serial.print("B=");
Serial.println( constrain(B.toInt(),0,255));
analogWrite(PIN_RED, (R.toInt()));
analogWrite(PIN_GREEN, (G.toInt()));
analogWrite(PIN_BLUE, (B.toInt()));
