Good day all, this may well be the wrong category for this but hay.
I'm building a pcb for a pc 12v rgb case fan / strip project, now I'm using a arduino nano, witch is going to be connected to an internal usb header on the motherboard, tip120, 220k risters, and a sata/molex power socket for my project.
I have some diodes to, I forget what they are off the top of my head, I got the part from amazon.
Link to kit for detais of parts.
Now I've had this running fine built on a breadboard using a 12v 1a power supply, my question is, is there a way to reinforced the circuit for better long turm use and protection of the PCs psu and the rgb fans / strips.
Refrnce image for a base look at the project
Now I plan on adding the diodes to ground an output to protect the tip120's, I want to knoow if there is more I can do to protect my pc and my project for longer lifespan.
FYI I plan on buildings a prototype first then get a pcb printed at a later date to clean up the project, I may also add a 5v rgb led to the board as an indicator, or do some redesigns to have the at atmega328p chip built into the board, but this would also required the usb interface too.
Any help or advice would be appreciated
