Hi guys,
I've ordered a cheap 5mtrs led strip from ebay today, and i wonder, is it possible to control each led on those strips? It would be awesome to create some kind of RGB animation.
-- J
Hi guys,
-- J
It will depend on which strip you ordered. Some can be individually controlled. Some have all the LEDs of the same color connected together.
Thanks, and i just found out that the one i ordered .. is connected in parallel, i guess i need to place a new order, heh.
I'm planning to install a set of 8x 20cm strips to an octocopter, but i wonder, would a mini board be sufficient to control these strips or do i need something else too?
It will depend on the LED strip's power requirements. If it needs more than 5V or more than 30 mA then you will need a resistor and transistor to connect the Arduino pin to the LED strip.
Hey.
Try to have a look at the WS2811 LED strips being sold on eBay. like this example.
They can be controlled individually, and only require 5V. (be sure to check out the required voltage. I read about someone getting a 12V version instead).
For controlling the WS2811, check out this blog: FastSPI LED Effects [UPDATED TO WORK WITH FastSPI_2] » funkboxing
jastrup:
Hi guys,I've ordered a cheap 5mtrs led strip from ebay today, and i wonder, is it possible to control each led on those strips?
a) What strips? My crystal ball isn't working.
b) Don't you think it would be a good idea to ask before ordering?
Try one of these —
You need to know which type of led strip that you purchased.And if u want to control the led,then u need the controller.
