rgb rainbow color fade with pot controlled brightness
Im struggling to figure out how to use a potentiometer to control the brightness of this highlighted in red. when using a pot I get an input 0-1023 but I need 0-1 for the brightness controls. Im very new to arduino so cut me some slack. Ive beat my head off the desk for well over a month before tapping and asking for help. fun fact I can write ladder logic on a plc like its nothing but this is painful for my brain to wrap around. Any help would be greatly appreciated.
// Rainbow color changing RGB leds example
// I am using common cathode RGB leds
int PIN_RED = 10;
int PIN_GREEN = 11;
int PIN_BLUE = 9;
int counter = 0;
// Number of colors used for animating, higher = smoother and slower animation)
int numColors = 255;
// The combination of numColors and animationDelay determines the
// animation speed, I recommend a higher number of colors if you want
// to slow down the animation. Higher number of colors = smoother color changing.
int animationDelay = 10; // number milliseconds before RGB LED changes to next color
pinMode(PIN_RED, OUTPUT);
pinMode(PIN_BLUE, OUTPUT);
pinMode(PIN_GREEN, OUTPUT);
// This part takes care of displaying the
// color changing in reverse by counting backwards if counter
// is above the number of available colors
float colorNumber = counter > numColors ? counter - numColors: counter;
// Play with the saturation and brightness values
// to see what they do
float saturation = 1; // Between 0 and 1 (0 = gray, 1 = full color)
float brightness = .05; // Between 0 and 1 (0 = dark, 1 is full brightness)
float hue = (colorNumber / float(numColors)) * 360; // Number between 0 and 360
long color = HSBtoRGB(hue, saturation, brightness);
// Get the red, blue and green parts from generated color
int red = color >> 16 & 255;
int green = color >> 8 & 255;
int blue = color & 255;
setColor(red, green, blue);
// Counter can never be greater then 2 times the number of available colors
// the colorNumber = line above takes care of counting backwards (nicely looping animation)
// when counter is larger then the number of available colors
counter = (counter + 1) % (numColors * 2);
// If you uncomment this line the color changing starts from the
// beginning when it reaches the end (animation only plays forward)
// counter = (counter + 1) % (numColors);
delay(animationDelay);
void setColor (unsigned char red, unsigned char green, unsigned char blue)
analogWrite(PIN_RED, red);
analogWrite(PIN_GREEN, green);
analogWrite(PIN_BLUE, blue);
long HSBtoRGB(float _hue, float _sat, float _brightness) {
float red = 0.0;
float green = 0.0;
float blue = 0.0;
if (_sat == 0.0) {
red = _brightness;
green = _brightness;
blue = _brightness;
if (_hue == 360.0) {
_hue = 0;
int slice = _hue / 60.0;
float hue_frac = (_hue / 60.0) - slice;
float aa = _brightness * (1.0 - _sat);
float bb = _brightness * (1.0 - _sat * hue_frac);
float cc = _brightness * (1.0 - _sat * (1.0 - hue_frac));
switch(slice) {
case 0:
red = _brightness;
green = cc;
blue = aa;
case 1:
red = bb;
blue = aa;
case 2:
red = aa;
blue = cc;
case 3:
red = aa;
green = bb;
blue = _brightness;
case 4:
red = cc;
green = aa;
blue = _brightness;
case 5:
red = _brightness;
green = aa;
blue = bb;
default:
red = 0.0;
green = 0.0;
blue = 0.0;
long ired = red * 255.0;
long igreen = green * 255.0;
long iblue = blue * 255.0;
return long((ired << 16) | (igreen << 8) | (iblue));
I don't understand your problem.
If you need a value between zero and one (inclusive), take the number returned by analogRead, and multiply it by 1.0/1023.0
Perfect! That's exactly what I needed. I couldn't figure out how to get a number with a decimal place and that did it! Thanks a ton it's up and working!
