One motor turns slightly faster than the other and the program I am using doesn't seem to have a way to adjust the speed of each motor to make up the difference. Would anyone suggest a way to add some code I could use to adjust a motor separately. Here is the program. It's an Arduino uno program.
#include<AFMotor.h>
#include <NewPing.h>
#include <Servo.h>
#define TRIG_PIN A4
#define ECHO_PIN A5
#define MAX_DISTANCE 200
#define MAX_SPEED 190 // sets speed of DC motors
#define MAX_SPEED_OFFSET 20
NewPing sonar(TRIG_PIN, ECHO_PIN, MAX_DISTANCE);
AF_DCMotor motor1(1, MOTOR12_1KHZ);
AF_DCMotor motor2(2, MOTOR12_1KHZ);
Servo myservo;
boolean goesForward=false;
int distance = 100;
int speedSet = 0;
myservo.attach(9);
myservo.write(90);
delay(2000);
distance = readPing();
delay(100);
delay(100);
delay(100);
delay(100);
int distanceR = 0;
int distanceL = 0;
delay(40);
if(distance<=15)
moveStop();
delay(100);
moveBackward();
delay(300);
moveStop();
delay(200);
distanceR = lookRight();
delay(200);
distanceL = lookLeft();
delay(200);
if(distanceR>=distanceL)
turnRight();
moveStop();
}else
turnLeft();
moveStop();
}else
moveForward();
int lookRight()
myservo.write(50);
int distance = readPing();
delay(100);
myservo.write(90);
return distance;
int lookLeft()
myservo.write(170);
delay(100);
myservo.write(90);
return distance;
delay(100);
int readPing() {
delay(70);
int cm = sonar.ping_cm();
if(cm==0)
cm = 250;
return cm;
void moveStop() {
motor1.run(RELEASE);
motor2.run(RELEASE);
void moveForward() {
if(!goesForward)
goesForward=true;
motor1.run(FORWARD);
motor2.run(FORWARD);
for (speedSet = 0; speedSet < MAX_SPEED; speedSet +=2) // slowly bring the speed up to avoid loading down the batteries too quickly
motor1.setSpeed(speedSet);
motor2.setSpeed(speedSet+MAX_SPEED_OFFSET);
delay(5);
void moveBackward() {
goesForward=false;
motor1.run(BACKWARD);
motor2.run(BACKWARD);
delay(5);
void turnRight() {
delay(300);
void turnLeft() {
delay(300);
