First of all, i'd like to share with you a copy of my register settings. The settings are all well commented according to the camera's datasheet. Thats the way it should be. The really important settings are to find at the top of the list ( 1 - 6 ).
const prog_char change_reg[_registerset][2]=
// The really important stuff.
{0x12, 0x00},//1 / COM7 : YUV mode, 0b [7] Register Reset [6] Reserved [5] CIF [4] QVGA [3] QCIF [2] RGB [1] Color Bar [0] Raw RGB - 000;YUV - 100;RGB
{0x8c, 0x00},//2 / RGB444: 0b [7-2] Reserved, [1] RGB444 [0] XR GB(0) , RG BX(1)
{0x04, 0x00},//3 / COM1 : CCIR656 Format Disable
{0x40, 0xc0},//4 / COM15 : 0b [7-6] Output Range [5-4] RGB 565,555 [3-0] Reserved
{0x14, 0x18},//5 / COM9 : 4x gain ceiling
{0x11, 0x3f},//6 / CLKRC : Internal Clock, [000000] to [111111] , 16000000 / ( [111111]+ 1 ) = 250000
// Hardware Window Settings
{0x32, 0xb6},//7 / HREF :
{0x17, 0x13},//8 / HSTART: HREF Column start high 8-bit
{0x18, 0x01},//9 / HSTOP : HREF Column end high 8-bit
{0x19, 0x02},//10/ VSTRT : VSYNC Start high 8-bit
{0x1a, 0x7a},//11/ VSTOP : VSYNC End high 8-bit,
{0x03, 0x0a},//12/ VREF : Vertical Frame Control,
{0x0c, 0x00},//13/ COM3 :
{0x3e, 0x00},//14/ COM14 : Pixel Clock Devider
// Mystery Scaling Numbers
{0x70, 0x3a},//15/ SCALING XSC : Horizontal Scale Factor
{0x71, 0x35},//16/ SCALING YSC : Vertical Scale Factor
{0x72, 0x11},//17/ SCALING DCW : DCW Control
{0x73, 0xf0},//18/ SCALING PCLK: Scaling Pixel Clock Devider
{0xa2, 0x02},//19/ SCALING PCLK: Scaling Pixel Delay
{0x15, 0x00},//20/ COM10 : VSYNC , HREF , PCLK Settings
// Gamma Curve Values
{0x7a, 0x20},//21/ SLOP : Gamma Curve Highest Segment Slope
{0x7b, 0x10},//22/ GAM1 : Gamme Curve 1st Segment
{0x7c, 0x1e},//23/ GAM2 : Gamme Curve 2st Segment
{0x7d, 0x35},//24/ GAM3 : Gamme Curve 3st Segment
{0x7e, 0x5a},//25/ GAM4 : Gamme Curve 4st Segment
{0x7f, 0x69},//26/ GAM5 : Gamme Curve 5st Segment
{0x80, 0x76},//27/ GAM6 : Gamme Curve 6st Segment
{0x81, 0x80},//28/ GAM7 : Gamme Curve 7st Segment
{0x82, 0x88},//29/ GAM8 : Gamme Curve 8st Segment
{0x83, 0x8f},//30/ GAM9 : Gamme Curve 9st Segment
{0x84, 0x96},//31/ GAM10: Gamme Curve 10st Segment
{0x85, 0xa3},//32/ GAM11: Gamme Curve 11st Segment
{0x86, 0xaf},//33/ GAM12: Gamme Curve 12st Segment
{0x87, 0xc4},//34/ GAM13: Gamme Curve 13st Segment
{0x88, 0xd7},//35/ GAM14: Gamme Curve 14st Segment
{0x89, 0xe8},//36/ GAM15: Gamme Curve 15st Segment
// Automatic Gain Control and AEC Parameters
{0x13, 0x00},//37/ COM8 : Fast AGC/AEC Algorithm
{0x00, 0x00},//38/ GAIN
{0x10, 0x00},//39/ AECH
{0x0d, 0x00},//40/ COM4 :
{0x14, 0x18},//41/ COM9 : Automatic Gain Ceiling : 8x
{0xa5, 0x05},//42/ BD50MAX: 50 Hz Banding Step Limit
{0xab, 0x07},//43/ BD60MAX: 60 Hz Banding Step Limit
{0x24, 0x95},//44/ AGC - Stable Operating Region Upper Limit
{0x25, 0x33},//45/ AGC - Stable Operating Region Lower Limit
{0x26, 0xe3},//46/ AGC - Fast Mode Operating Region
{0x9f, 0x78},//47/ HAECC1 : Histogram based AEC Control 1
{0xa0, 0x68},//48/ HAECC2 : Histogram based AEC Control 2
{0xa1, 0x03},//49/ Reserved
{0xa6, 0xd8},//50/ HAECC3 : Histogram based AEC Control 3
{0xa7, 0xd8},//51/ HAECC4 : Histogram based AEC Control 4
{0xa8, 0xf0},//52/ HAECC5 : Histogram based AEC Control 5
{0xa9, 0x90},//53/ HAECC6 : Histogram based AEC Control 6
{0xaa, 0x94},//54/ HAECC7 : AEC Algorithm Selection
{0x13, 0xe5},//55/ COM8 : Fast AGC Algorithm, Unlimited Step Size , Banding Filter ON, AGC and AEC enable.
// Reserved Values without function specification
{0x0e, 0x61},//56/ COM5 : Reserved
{0x0f, 0x4b},//57/ COM6 : Reserved
{0x16, 0x02},//58/ Reserved
{0x1e, 0x07},//59/ MVFP : Mirror/Vflip disabled ( 0x37 enabled )
{0x21, 0x02},//60/ Reserved
{0x22, 0x91},//61/ Reserved
{0x29, 0x07},//62/ Reserved
{0x33, 0x0b},//63/ Reserved
{0x35, 0x0b},//64/ Reserved
{0x37, 0x1d},//65/ Reserved
{0x38, 0x71},//66/ Reserved
{0x39, 0x2a},//67/ Reserved
{0x3c, 0x78},//68/ COM12 : Reserved
{0x4d, 0x40},//69/ Reserved
{0x4e, 0x20},//70/ Reserved
{0x69, 0x00},//71/ GFIX : Fix Gain for RGB Values
{0x6b, 0x4a},//72/ DBLV : PPL Control
{0x74, 0x10},//73/ Reserved
{0x8d, 0x4f},//74/ Reserved
{0x8e, 0x00},//75/ Reserved
{0x8f, 0x00},//76/ Reserved
{0x90, 0x00},//77/ Reserved
{0x91, 0x00},//78/ Reserved
{0x92, 0x00},//79/ Reserved
{0x96, 0x00},//80/ Reserved
{0x9a, 0x00},//81/ Reserved
{0xb0, 0x84},//82/ Reserved
{0xb1, 0x0c},//83/ Reserved
{0xb2, 0x0e},//84/ Reserved
{0xb3, 0x82},//85/ Reserved
{0xb8, 0x0a},//86/ Reserved
{0x43, 0x0a},//87/ Reserved
{0x44, 0xf0},//88/ Reserved
{0x45, 0x34},//89/ Reserved
{0x46, 0x58},//90/ Reserved
{0x47, 0x28},//91/ Reserved
{0x48, 0x3a},//92/ Reserved
{0x59, 0x88},//93/ Reserved
{0x5a, 0x88},//94/ Reserved
{0x5b, 0x44},//95/ Reserved
{0x5c, 0x67},//96/ Reserved
{0x5d, 0x49},//97/ Reserved
{0x5e, 0x0e},//98/ Reserved
{0x64, 0x04},//99/ Reserved
{0x65, 0x20},//100/ Reserved
{0x66, 0x05},//101/ Reserved
{0x94, 0x04},//102/ Reserved
{0x95, 0x08},//103/ Reserved
{0x6c, 0x0a},//104/ Reserved
{0x6d, 0x55},//105/ Reserved
{0x6e, 0x11},//106/ Reserved
{0x6f, 0x9f},//107/ Reserved
{0x6a, 0x40},//108/ Reserved
{0x01, 0x40},//109/ REG BLUE : Reserved
{0x02, 0x40},//110/ REG RED : Reserved
{0x13, 0xe7},//111/ COM8 : FAST AEC, AEC unlimited STEP, Band Filter, AGC , ARC , AWB enable.
// Matrix Coefficients
{0x4f, 0x80},//112/ MTX 1 : Matrix Coefficient 1
{0x50, 0x80},//113/ MTX 2 : Matrix Coefficient 2
{0x51, 0x00},//114/ MTX 3 : Matrix Coefficient 3
{0x52, 0x22},//115/ MTX 4 : Matrix Coefficient 4
{0x53, 0x5e},//116/ MTX 5 : Matrix Coefficient 5
{0x54, 0x80},//117/ MTX 6 : Matrix Coefficient 6
{0x58, 0x9e},//118/ MTXS : Matrix Coefficient Sign for Coefficient 5 to 0
{0x41, 0x08},//119/ COM16 : AWB Gain enable
{0x3f, 0x00},//120/ EDGE : Edge Enhancement Adjustment
{0x75, 0x05},//121/ Reserved
{0x76, 0xe1},//122/ Reserved
{0x4c, 0x00},//123/ Reserved
{0x77, 0x01},//124/ Reserved
{0x3d, 0xc0},//125/ COM13
{0x4b, 0x09},//126/ Reserved
{0xc9, 0x60},//127/ Reserved
{0x41, 0x38},//128/ COM16
{0x56, 0x40},//129/ Reserved
{0x34, 0x11},//130/ Reserved
{0x3b, 0x12},//131/ COM11 : Exposure and Hz Auto detect enabled.
{0xa4, 0x88},//132/ Reserved
{0x96, 0x00},//133/ Reserved
{0x97, 0x30},//134/ Reserved
{0x98, 0x20},//135/ Reserved
{0x99, 0x30},//136/ Reserved
{0x9a, 0x84},//137/ Reserved
{0x9b, 0x29},//138/ Reserved
{0x9c, 0x03},//139/ Reserved
{0x9d, 0x4c},//140/ Reserved
{0x9e, 0x3f},//141/ Reserved
{0x78, 0x04},//142/ Reserved
// Mutliplexing Registers
{0x79, 0x01},//143/ Reserved
{0xc8, 0xf0},//144/ Reserved
{0x79, 0x0f},//145/ Reserved
{0xc8, 0x00},//146/ Reserved
{0x79, 0x10},//147/ Reserved
{0xc8, 0x7e},//148/ Reserved
{0x79, 0x0a},//149/ Reserved
{0xc8, 0x80},//150/ Reserved
{0x79, 0x0b},//151/ Reserved
{0xc8, 0x01},//152/ Reserved
{0x79, 0x0c},//153/ Reserved
{0xc8, 0x0f},//154/ Reserved
{0x79, 0x0d},//155/ Reserved
{0xc8, 0x20},//156/ Reserved
{0x79, 0x09},//157/ Reserved
{0xc8, 0x80},//158/ Reserved
{0x79, 0x02},//159/ Reserved
{0xc8, 0xc0},//160/ Reserved
{0x79, 0x03},//161/ Reserved
{0xc8, 0x40},//162/ Reserved
{0x79, 0x05},//163/ Reserved
{0xc8, 0x30},//164/ Reserved
{0x79, 0x26},//165/ Reserved
// Additional Settings
{0x09, 0x00},//166/ COM2 : Output Drive Capability
{0x55, 0x00},//167/ Brightness Control
// End Of Constant
{0xff, 0xff},//174/ End Marker
For more infos on that, see
http://tomoyo.sourceforge.jp/cgi-bin/lxr/source/drivers/media/video/ov7670.c
