Boardburner2:
10 PPM is a bit low for consumption.
20 to 40 is generally considered safe.
There's an inline Ionizing Filter
[quote author=Oceanic Water Systems] IONZIED ALKALINE INFRARED pH plus and ORP negative 2.5" X 12" WATER FILTER
Ionized alkaline drinking water is saturated with negatively charged ions. These negatively charged ions attract the positively charged ions of harmful acids and neutralize them. Scientists have devised ways to measure and assign values to the electron activity. The measurement is known as oxidative reduction potential, or ORP.
What is ORP?
ORP stands for Oxydation Reduction Potential. Water either has a "positive" or "negative" ORP, measured in millivolts mV. It is the negative ORP that is beneficial to our body in that it reduces oxidation (anti-oxidant). Negative ORP is in ionized water and fresh, uncooked foods. Positive ORP increases oxidation (aging) and is found in tap water, bottled waters, distilled and reverse osmosis waters as well as cooked and processed foods.
What Does pH Mean?
pH stands for potential hydrogen. It is the measurement of hydrogen-ion concentration. The pH scale runs from 0 to 14…..A reading of 7.0 or above is alkaline and below 7.0 is acidic. The higher a pH reading the more oxygen is in the fluid you are testing and the lower the pH reading indicates less oxygen and more acid.
Acidity in the Body
The human body creates acid, all day, every day, as a byproduct of metabolism. In addition, acid is introduced into the system through eating and digestion. Many secreted and digested acids are swept away by the blood stream, filtered out by the kidneys, and released from the body in the urine. Other acids leave the body through perspiration. Your body can only process a certain amount of acids, however, so it is possible to overload the system and for the body to become acidic.
Alkaline Water Benefits
The ionization process breaks down water molecules in to micro-clusters allowing rapid delivery to cell walls for a superior hydrating effect at a cellular level. Micro-clustered water delivers nutrients to the cells more efficiently. Among several other benefits including proper hydration, detoxification, and balance in your body’s pH levels, drinking alkaline water can ultimately contribute to weight loss and anti-aging.[/quote]
Boardburner2:
75 PSI is fine without boost.
Boost is only needed in low pressure areas, in the uk 45 psi is typically the high end of the public supply.
Overpressure will rupture the membrane, mine runs at about 80 psi.
I'm not planing to use a boost pump but I figure why not make it an universal as some people might be interested to deploy such an controller and at least recover some of my time and effort that I'm sinking into making a custom shield to make things plug and play for the next person.
