Gyro Offsets: {-109.73, -118.21, -24.61}
Accel Offsets: {-132.0, 293.0, -645.0}
Accel Scales: {1.005, 0.997, 1.011}
// MPU-6050 Mahony IMU (yaw angle is relative to starting orientation)
// last update 7/9/2020
#include "Wire.h"
// AD0 low = 0x68 (default for Sparkfun module)
// AD0 high = 0x69
int MPU_addr = 0x68;
// vvvvvvvvvvvvvvvvvv VERY VERY IMPORTANT vvvvvvvvvvvvvvvvvvvvvvvvvvvvv
//These are the previously determined offsets and scale factors for accelerometer and gyro for
// a particular example of an MPU-6050. They are not correct for other examples.
//The IMU code will NOT work well or at all if these are not correct
float A_cal[6] = {-132.0, 293.0, -645.0, 1.005, 0.997, 1.011}; // 0..2 offset xyz, 3..5 scale xyz
// the code will work, but not as accurately, for an uncalibrated accelerometer. Use this line instead:
// float A_cal[6] = {0.0, 0.0, 0.0, 1.000, 1.000, 1.000}; // 0..2 offset xyz, 3..5 scale xyz
float G_off[3] = {-109.73, -118.21, -24.61}; //raw offsets, determined for gyro at rest
#define gscale ((250./32768.0)*(PI/180.0)) //gyro default 250 LSB per d/s -> rad/s
// ^^^^^^^^^^^^^^^^^^^ VERY IMPORTANT ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
// GLOBALLY DECLARED, required for Mahony filter
// vector to hold quaternion
float q[4] = {1.0, 0.0, 0.0, 0.0};
// Free parameters in the Mahony filter and fusion scheme,
// Kp for proportional feedback, Ki for integral
float Kp = 30.0;
float Ki = 0.0;
// with MPU-9250, angles start oscillating at Kp=40. Ki does not seem to help and is not required.
// with MPU-6050, some instability observed at Kp=100 Now set to 30.
// char s[60]; //snprintf buffer, if needed
// globals for AHRS loop timing
unsigned long now_ms, last_ms = 0; //millis() timers
// print interval
unsigned long print_ms = 200; //print angles every "print_ms" milliseconds
float yaw, pitch, roll; //Euler angle output
Wire.begin();
Serial.println("starting");
// initialize sensor
// defaults for gyro and accel sensitivity are 250 dps and +/- 2 g
Wire.beginTransmission(MPU_addr);
Wire.write(0x6B); // PWR_MGMT_1 register
Wire.write(0); // set to zero (wakes up the MPU-6050)
Wire.endTransmission(true);
// Mahony scheme uses proportional and integral filtering on
// the error between estimated reference vector (gravity) and measured one.
// Madgwick's implementation of Mayhony's AHRS algorithm.
// See: http://www.x-io.co.uk/node/8#open_source_ahrs_and_imu_algorithms
// Date Author Notes
// 29/09/2011 SOH Madgwick Initial release
// 02/10/2011 SOH Madgwick Optimised for reduced CPU load
// last update 07/09/2020 SJR minor edits
// IMU algorithm update
void Mahony_update(float ax, float ay, float az, float gx, float gy, float gz, float deltat) {
float recipNorm;
float vx, vy, vz;
float ex, ey, ez; //error terms
float qa, qb, qc;
static float ix = 0.0, iy = 0.0, iz = 0.0; //integral feedback terms
float tmp;
// Compute feedback only if accelerometer measurement valid (avoids NaN in accelerometer normalisation)
tmp = ax * ax + ay * ay + az * az;
if (tmp > 0.0)
// Normalise accelerometer (assumed to measure the direction of gravity in body frame)
recipNorm = 1.0 / sqrt(tmp);
ax *= recipNorm;
ay *= recipNorm;
az *= recipNorm;
// Estimated direction of gravity in the body frame (factor of two divided out)
vx = q[1] * q[3] - q[0] * q[2]; //to normalize these terms, multiply each by 2.0
vy = q[0] * q[1] + q[2] * q[3];
vz = q[0] * q[0] - 0.5f + q[3] * q[3];
// Error is cross product between estimated and measured direction of gravity in body frame
// (half the actual magnitude)
ex = (ay * vz - az * vy);
ey = (az * vx - ax * vz);
ez = (ax * vy - ay * vx);
// Compute and apply to gyro term the integral feedback, if enabled
if (Ki > 0.0f) {
ix += Ki * ex * deltat; // integral error scaled by Ki
iy += Ki * ey * deltat;
iz += Ki * ez * deltat;
gx += ix; // apply integral feedback
gy += iy;
gz += iz;
// Apply proportional feedback to gyro term
gx += Kp * ex;
gy += Kp * ey;
gz += Kp * ez;
// Integrate rate of change of quaternion, q cross gyro term
deltat = 0.5 * deltat;
gx *= deltat; // pre-multiply common factors
gy *= deltat;
gz *= deltat;
qa = q[0];
qb = q[1];
qc = q[2];
q[0] += (-qb * gx - qc * gy - q[3] * gz);
q[1] += (qa * gx + qc * gz - q[3] * gy);
q[2] += (qa * gy - qb * gz + q[3] * gx);
q[3] += (qa * gz + qb * gy - qc * gx);
// renormalise quaternion
recipNorm = 1.0 / sqrt(q[0] * q[0] + q[1] * q[1] + q[2] * q[2] + q[3] * q[3]);
q[0] = q[0] * recipNorm;
q[1] = q[1] * recipNorm;
q[2] = q[2] * recipNorm;
q[3] = q[3] * recipNorm;
// AHRS loop
static float deltat = 0; //loop time in seconds
static unsigned long now = 0, last = 0; //micros() timers
//raw data
int16_t ax, ay, az;
int16_t gx, gy, gz;
int16_t Tmp; //temperature
//scaled data as vector
float Axyz[3];
float Gxyz[3];
Wire.write(0x3B); // starting with register 0x3B (ACCEL_XOUT_H)
Wire.endTransmission(false);
Wire.requestFrom(MPU_addr, 14); // request a total of 14 registers
int t = Wire.read() << 8;
ax = t | Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
ay = t | Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
az = t | Wire.read(); // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
Tmp = t | Wire.read(); // 0x41 (TEMP_OUT_H) & 0x42 (TEMP_OUT_L)
gx = t | Wire.read(); // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
gy = t | Wire.read(); // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
gz = t | Wire.read(); // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
Axyz[0] = (float) ax;
Axyz[1] = (float) ay;
Axyz[2] = (float) az;
//apply offsets and scale factors from Magneto
for (int i = 0; i < 3; i++) Axyz[i] = (Axyz[i] - A_cal[i]) * A_cal[i + 3];
Gxyz[0] = ((float) gx - G_off[0]) * gscale; //250 LSB(d/s) default to radians/s
Gxyz[1] = ((float) gy - G_off[1]) * gscale;
Gxyz[2] = ((float) gz - G_off[2]) * gscale;
// snprintf(s,sizeof(s),"mpu raw %d,%d,%d,%d,%d,%d",ax,ay,az,gx,gy,gz);
// Serial.println(s);
now = micros();
deltat = (now - last) * 1.0e-6; //seconds since last update
last = now;
Mahony_update(Axyz[0], Axyz[1], Axyz[2], Gxyz[0], Gxyz[1], Gxyz[2], deltat);
// Compute Tait-Bryan angles. Strictly valid only for approximately level movement
// In this coordinate system, the positive z-axis is up, X north, Y west.
// Yaw is the angle between Sensor x-axis and Earth magnetic North
// (or true North if corrected for local declination, looking down on the sensor
// positive yaw is counterclockwise, which is not conventional for NED navigation.
// Pitch is angle between sensor x-axis and Earth ground plane, toward the
// Earth is positive, up toward the sky is negative. Roll is angle between
// sensor y-axis and Earth ground plane, y-axis up is positive roll. These
// arise from the definition of the homogeneous rotation matrix constructed
// from quaternions. Tait-Bryan angles as well as Euler angles are
// non-commutative; that is, the get the correct orientation the rotations
// must be applied in the correct order which for this configuration is yaw,
// pitch, and then roll.
// http://en.wikipedia.org/wiki/Conversion_between_quaternions_and_Euler_angles
// which has additional links.
// WARNING: This angular conversion is for DEMONSTRATION PURPOSES ONLY. It WILL
// MALFUNCTION for certain combinations of angles! See https://en.wikipedia.org/wiki/Gimbal_lock
roll = atan2((q[0] * q[1] + q[2] * q[3]), 0.5 - (q[1] * q[1] + q[2] * q[2]));
pitch = asin(2.0 * (q[0] * q[2] - q[1] * q[3]));
//conventional yaw increases clockwise from North. Not that the MPU-6050 knows where North is.
yaw = -atan2((q[1] * q[2] + q[0] * q[3]), 0.5 - (q[2] * q[2] + q[3] * q[3]));
// to degrees
yaw *= 180.0 / PI;
if (yaw < 0) yaw += 360.0; //compass circle
pitch *= 180.0 / PI;
roll *= 180.0 / PI;
now_ms = millis(); //time to print?
if (now_ms - last_ms >= print_ms) {
last_ms = now_ms;
// print angles for serial plotter...
// Serial.print("ypr ");
Serial.print(yaw, 0);
Serial.print(", ");
Serial.print(pitch, 0);
Serial.print(", ");
Serial.println(roll, 0);
