I'm a complete noob, this is my first project ever.
My goal is to emulate the UP & DOWN keys from a standard keyboard (to control a separate device) with a rotary encoder.
I'm using this sketch & hardware from a Youtube video- Midi controller | Premiere Pro | Lightroom | Navigation Dial DIY (NEW) | Video Edit Jog Wheel USB - YouTube
It's a rotary encoder & ATmega32u4 board for manipulating the arrow keys on a keyboard.
The project works perfectly on my PC, but doesn't work to control my device. But, if I plug in a keyboard to my device, it work perfectly....confusing.
I would appreciate any guidance or insight.
Thanks!
Here is the code-
// Youtube : Eunchan Park
// https://www.youtube.com/watch?v=dJJ1wlJPqwE
// left right
// up down
// everytime you clicks button, it changes arrow direction from horizontal to vertical
// Resolution : some encoder is too sensitive. this reduces sensitivity.
#define RESOLUTION 4
// include a Keyboard library
#include "Keyboard.h"
// include a EEPROM library for memorizing last function
#include <EEPROM.h>
// "OUTPUT_A" is going to be replaced with "A0".
#define OUTPUT_A 2
// "PIN_GND_ENCODER" is going to be replaced with "3".
#define PIN_GND_ENCODER 3
// "OUTPUT_B" is going to be replaced with "15".
#define OUTPUT_B 4
// "BUTTON" is going to be replaced with "A1".
#define BUTTON A1
// "PIN_GND_BUTTON" is going to be replaced with "A3".
#define PIN_GND_BUTTON A3
// Declare variables aState, aLastState for checking the state of OUTPUT_A of the encoder
bool aState;
// We need to save the previous state of OUTPUT_A
bool aLastState;
// this variable for check the state of button.
bool lastButtonState = 0;
// mode selection
#define HORIZONTAL_MODE 0
#define VERTICAL_MODE 1
int mode = HORIZONTAL_MODE;
const int numMode = 2;
// void setup(){} function is for one time setting
//read the last mode
mode = EEPROM.read(0);
// in order to use the Keyboard library, begin() is necessary
Keyboard.begin();
// OUTPUT_A is for INPUT. must be pull-up
pinMode(OUTPUT_A, INPUT_PULLUP);
// OUTPUT_B is for INPUT, must be pull-up
pinMode(OUTPUT_B, INPUT_PULLUP);
// BUTTON is for INPUT
// Most pin has thier own pull-up resistor.
// INPUT_PULLUP makes the pin high.
// a leg of button is connected with this pin and another pin which is grounded.
// when the button is not pressed, the pin reads HIGH signal because of this PULL-UP
// when the button is pressed, pin is going to be LOW which means "pressed"
pinMode(BUTTON, INPUT_PULLUP);
// PIN_GND_ENCODER is for OUTPUT
// This pin is used for giving GROUND to the encoder.
// this is a kind of trick, but it works well.
pinMode(PIN_GND_ENCODER, OUTPUT);
digitalWrite(PIN_GND_ENCODER, LOW);
// PIN_GND_BUTTON is for OUTPUT
// This pin is used for giving GND to the button.
pinMode(PIN_GND_BUTTON, OUTPUT);
digitalWrite(PIN_GND_BUTTON, LOW);
// read a signal from OUTPUT_A
// this is for initialization
aLastState = digitalRead(OUTPUT_A);
long tempCount = 0;
// this loop() function repeats its code eternally
//read signal from OUTPUT_A and save its state to aState
aState = digitalRead(OUTPUT_A);
// if aLastState is not currentState, it meant there's something changed.
if (aState != aLastState) {
// read another pin's state.
// if you want to know about the theory, watch this video
// https://www.youtube.com/watch?v=v4BbSzJ-hz4
if (digitalRead(OUTPUT_B) != aState) {
rotateLeft();
rotateRight();
// save current State as last State
aLastState = aState;
// read button (short or long)
if (digitalRead(BUTTON) == LOW) {
if (lastButtonState == LOW) {
// LOW -> LOW : nothing to do
// HIGH-> LOW
delay(300); // ignoring chattering
lastButtonState = LOW;
if (lastButtonState == LOW) { // LOW -> HIGH : check whether long press or not
changeMode();
else { // HIGH -> HIGH : noting to do
lastButtonState = HIGH;
void changeMode() {
mode = ++mode % numMode;
EEPROM.write(0, mode);
void rotateLeft() {
if (tempCount++ % RESOLUTION == 0) {
if (mode == HORIZONTAL_MODE ) {
Keyboard.press(KEY_LEFT_ARROW);
} else if (mode == VERTICAL_MODE) {
Keyboard.press(KEY_UP_ARROW);
Keyboard.releaseAll();
void rotateRight() {
if (mode == HORIZONTAL_MODE) {
Keyboard.press(KEY_RIGHT_ARROW);
Keyboard.press(KEY_DOWN_ARROW);
