Rotary encoder counts every second step
I have made menu for OLED display with rotary encoder control. I am using stand-alone encoder, so I set pin modes as input pullup.
#define CLK 2
#define DT 3
#define SW 4
int counter = 0;
int currentStateCLK;
int lastStateCLK;
String currentDir ="";
	// Set encoder pins as inputs
	pinMode(CLK,INPUT_PULLUP);
	pinMode(DT,INPUT_PULLUP);
	pinMode(SW, INPUT_PULLUP);
	// Setup Serial Monitor
	// Read the initial state of CLK
	lastStateCLK = digitalRead(CLK);
	// Call updateEncoder() when any high/low changed seen
	// on interrupt 0 (pin 2), or interrupt 1 (pin 3)
	attachInterrupt(0, updateEncoder, CHANGE);
	attachInterrupt(1, updateEncoder, CHANGE);
Here is updateEncoder():
void updateEncoder(){
	// Read the current state of CLK
	currentStateCLK = digitalRead(CLK);
	// If last and current state of CLK are different, then pulse occurred
	// React to only 1 state change to avoid double count
	if (currentStateCLK != lastStateCLK  && currentStateCLK == 1){
		// If the DT state is different than the CLK state then
		// the encoder is rotating CCW so decrement
		if (digitalRead(DT) != currentStateCLK) {
			counter --;
			currentDir ="CCW";
			// Encoder is rotating CW so increment
			counter ++;
			currentDir ="CW";
		Serial.print("Direction: ");
		Serial.print(currentDir);
		Serial.print(" | Counter: ");
		Serial.println(counter);
	// Remember last CLK state
	lastStateCLK = currentStateCLK;
Thanks in advance.
Did you try removing that?
Thank you for your answer. Can you please explain why it would cause the problem?
Are you saying that it was causing the problem?
