Id like to make a alarm and to disable the alarm i want to enter a passcode with a rotary encoder, like you turn to 1 then press, turn to 2 then press, turn to 3 then press, turn to 4 then press and then it would disarm the alarm but how would i do this with with a rotary encoder, it would be by using some arrays, can anyone help me?
Welcome to the forums. The first thing you can do is request a moderator move your post over to "Project Guidance" since this has nothing to do with introductory tutorials.
Then, if you have the rotary encode from sparkfun, they probably have a library for the part of guidance on what library to use. Install that an look at the examples. Get them working and then start building up your project.
@jaocb14, your topic has been moved to a more suitable location on the forum. your topic has been moved to a more suitable location on the forum. Introductory Tutorials is for tutorials that e.g. you write, not for questions. Feel free to write a tutorial once you have solved your problem ![]()
what Arduino are you using and how have you connected the encoder?
have a look at Tutorial-of-Rotary-Encoder-With-Arduino
