I have been working on a pet feeder project based off of Automatic Pet Feeder. I have his code working but now i am tweaking it to my needs and trying to learn new things along the way. I want to add a settings menu that allows a user to use the rotary encoder to set the time and a few other variables. As of right now i have the rotary encoder working for the root layer of my menu. When i select a menu it should launch the function and use the encoder to configuration the numbers. i can not get the encoder to work inside the set time function.
the menu code is based on a cocktail maker code, i haven't cleaned up all those references yet.
Menu Code:
/* Cocktail Production - Menu Test Sketch
 *  Created by VulkanDesign.com
 *  Free to use -> but: pls pay attention to the copyrights of the included libraries
 *  Granted by Dipl.-Ing. Raimund P. Trierscheid
/* Rotary encoder handler for arduino.
   Copyright 2011 Ben Buxton. Licenced under the GNU GPL Version 3.
   Contact: bb@cactii.net
   Quick implementation of rotary encoder routine.
   More info: http://www.buxtronix.net/2011/10/rotary-encoders-done-properly.html
// Include the library code
#include <Wire.h>                   // needed for I2C communication
#include <LiquidCrystal.h>      // LCD with I2C adapter
#include <rotary.h>                 // rotary handler
#include <Time.h>
#include <TimeLib.h>
#include <DS1307RTC.h> // Real Time Clock Library
/*  maybe for later enhancements
  #include <EEPROMex.h>
  #include <EEPROMVar.h>
  #include <OneButton.h>
// Initialize the Rotary object
// Rotary(Encoder Pin 1, Encoder Pin 2, Button Pin) Attach center to ground
Rotary r = Rotary(2, 3, 4);        // there is no must for using interrupt pins !!
// Half-step mode
#define HALF_STEP
// Define I2C_LCD
LiquidCrystal  lcd(12, 11, 5, 8, 7, 6);
// Define your cocktail information
int maxNumber = 5;
int hourmaxNumber = 23;
int minmaxNumber = 59;
char* myCocktails[] = {
  "Set Time",
  "First Meal",
  "Second Meal",
  "Loola QTY",
  "Dooly QTY",
  //"Mai Tai",
  //"Bloody Mary",
  //"Mojito",
  //"Cuba Libre",
  //"Tequila Sunrise",
  //"Caipirinha",
  //"Wodka Lemon",
int x = 0;
  //initialize serial and wait for port to open :
  Serial.begin(9600);   // only for debugging, comment out later
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.println("Initialized");
    lcd.begin(16, 2);
  lcd.clear (); // go home
  lcd.print ("David S");
  lcd.setCursor(0, 1);
  lcd.print("Pet Feeder");
  delay(2000);
  //lcd.backlight();                      // only needed for 0x3F I2C Adapter
  // ------- Quick 3 blinks of backlight  -------------
  //blinkLCD();
  //char lcdline1[13];
 // sprintf (lcdline1, "Cocktail #:  %02i", x + 1);    // index starts at 0
  lcd.clear();
  lcd.setCursor(0, 0);
  //lcd.print (lcdline1);
  lcd.print("Settings");
  lcd.print("                ");              // erase previous content
  lcd.print(myCocktails[x]);
  volatile unsigned char result = r.process();
  if (result) {
    result == DIR_CCW ? x = x - 1 : x = x + 1;
    if (x < 0) {             // no values < 0; later: use unsigned int
      //blinkLCD();
      x = maxNumber - 1;    // roll over
    if (x > maxNumber - 1) {           // no more strings
      //blinkLCD();
      x = 0;                 // roll over
    //sprintf (lcdline1, "Cocktail #:  %02i", x + 1);
    lcd.clear();
  if (r.buttonPressedReleased(25)) {
    switch (x) {
      case 0:
       // lcdScreen1();
        SetTime();                      // Start der Produktion
      case 1:
       // lcdScreen1();
        Cocktail_2();                      // Start der Produktion
      case 2:
        //lcdScreen1();
        Cocktail_3();                      // Start der Produktion
      case 3:
       // lcdScreen1();
        Cocktail_4();                      // Start der Produktion
      case 4:
        //lcdScreen1();
        Cocktail_5();                      // Start der Produktion
    //blinkLCD();
    x = 0;                                  // reset to start position
    lcd.clear();
    char lcdline1[13];
    lcd.print ("Settings");
// ####################   Functions ###################
void SetTime() {
  // produce the requested cocktail -> stepper motor actions
  tmElements_t tm;    // This sectionm reads the time from the RTC, sets it in tmElements tm (nice to work with), then displays it.
  RTC.read(tm);
  volatile unsigned char Hour = r.process();
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("SET TIME HERE");
  lcd.setCursor(3,1);
  lcd.print(":");
  lcd.blink();
  x = Hour;
  if (!(r.buttonPressedReleased(25))) {
    do  {
        lcd.setCursor(1,1);
        if (Hour) {
          Hour == DIR_CCW ? x = x - 1 : x = x + 1;
              x = hourmaxNumber - 1;    // roll over
          if (x > hourmaxNumber - 1) {           // no more strings
              x = 0;                 // roll over
        tm.Hour = x;
        RTC.write(tm);
        lcd.setCursor(1,1);
        printDigits(tm.Hour);
    } while ((r.buttonPressedReleased(25)));
    lcd.noBlink();
void Cocktail_2() {
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Set First Meal");
  lcd.setCursor(0,1);
  lcd.print("Time XX:XX");
  lcd.blink();
  lcd.setCursor(5,1);
  delay(5000);
  lcd.noBlink();
void Cocktail_3() {
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Set Second Meal");
  lcd.setCursor(0,1);
  lcd.blink();
  lcd.setCursor(5,1);
  delay(5000);
  lcd.noBlink();
void Cocktail_4() {
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Set Loola Feed");
  lcd.setCursor(0,1);
  lcd.print("QTY: XX");
  lcd.blink();
  lcd.setCursor(5,1);
  delay(5000);
  lcd.noBlink();
void Cocktail_5() {
lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Set Dooly Feed");
  lcd.setCursor(0,1);
  lcd.blink();
  lcd.setCursor(5,1);
  delay(5000);
  lcd.noBlink();
void printDigits(int digits){   // utility function for digital clock display: prints leading 0
   if(digits < 10)
    lcd.print('0');
   lcd.print(digits);
Any help with getting this sorted would be great. Or even just a topic to research to help me figure it out on my own. Thank you.
