I'm fairly new to Arduino. I recently figured out how to make pushbuttons work,
and when it comes to complicated parts like rotary encoders, I'm completely lost.
So I tried to walk the easy path and searched for a code on the net.
Since i use a Teensy 2.0, I changed the code to this:
#define DELAY 5 // Delay per loop in ms
enum PinAssignments
encoderPinA = 5,
encoderPinB = 6,
encoderPinC = 7,
encoderPinD = 8,
//This is up to your pin wiring
I really hope I did the right thing there because if the code was wrong this would be the wrong section.
Here is a basic tutorial that I put together recently. Maybe not so much a tutorial as commented code: it might help you understand. There are schematics, too.
It doesn't use interrupts: I have no idea how fast you can spin the knob before it misses counts.
It's written for an encoder with 20 pulses per revolution: there's a variable in there that you can change.
You set the pin numbers alright I see that. But I don't see any code there that tries to read the encoder or the interrupts or anything else. Do you think that just telling the compiler to use certain pin numbers will cause it to assume you have an encoder and automagically figure out how to read it for you and what to do with the pulses? You have to write that code.
This is just a part of the code, I linked the full code in the original post.
Delta_G:
Sorry man, very few people are going to go download your code from pastebin. We get hit by viruses that way. You can attach the file to your post or you can insert it in a code box if it is short enough.
Delta_G:
No problem. Just go up and modify your post and put the code as an attachment. Or put it in a reply. Really anywhere but pastebin.
Done
Actually, it is a lot easier if it can be included in the posting itself, if it is not too long. The ".ino" file has to be put in a correspondingly-named subdirectory and loaded in the IDE etc. etc.
What's all this about interrupts? What sort of encoder is this? Why do you want to use interrupts?
Delta_G:
Done
As I'm not sure how long too long is, I figured it would be better not to include the code in my post.
Is the rotary encoder you are using a quadrature encoder? If it is this is a pretty hard project to cut your teeth on. Do you have code that can decode the speed and direction of rotation?
You haven't mentioned if you looked at the link I gave in Reply #2 and restated here.
My code there doesn't use interrupts, and interrupts are notoriously tricky for new-comers to get their heads round. Most of the time they're not needed anyway, it seems.
See if you can work with my code to get a feel for how your encoder actually works.
First principles are always a good way to start, which is why I wrote that code for myself.
That poses an interesting question. Who has given up on who?
excd:
That is the wrong way round. You put the code in "code" tags using the "#" icon in a post - the rest of which post need be no more than "This is the current code:" and either it posts, or it tells you it is too long. Only in the latter case do you then attach an inconvenient ".ino" file. I do suspect 1.75k will fit in a posting quite comfortably.
I asked for another two explanations which are crucial to the proper way to approach the project, without which information it is simply not worth anyone spending time trying to guess the proper answer to your questions; whether to tidy up your code or scrap it in favour of a proper approach.
We see not a few rants here where people cannot understand why others will not give them the answer they want.
I tried it but I dont get anything on the serial monitor either, the leds however seem to react properly.
