Rotary.h no match for call to '(Rotary) (int, int) (closed)
I think I have an "int" vs. "char" problem, but not sure how to solve it. Here is the sketch for the project (a controller for a stepper motor to tune an antenna):
#pragma once
#include <Rotary.h>
#include <Arduino.h>
#include <EEPROM.h>
#include <Servo.h>
 * Example using the Rotary library, dumping integers to the serial
 * port. The integers increment or decrement depending on the direction
 * of rotation.
 * This example uses interrupts rather than polling.
 * From URL: http://www.buxtronix.net/2011/10/rotary-encoders-done-properly.html
#include <EEPROMWearLevel.h>
// Include Wire Library for I2C
# include <Wire.h>
// Include NewLiquidCrystal Library for I2C
# include <LiquidCrystal_I2C.h>
// NewLiquidCrystal.h
// Define LCD pinout
const int  en = 2, rw = 1, rs = 0, d4 = 4, d5 = 5, d6 = 6, d7 = 7, bl = 3;
// Define I2C Address - change if reqiuired
//    const int i2c_addr = 0x27;
//    LiquidCrystal_I2C lcd(i2c_addr, en, rw, rs, d4, d5, d6, d7, bl, POSITIVE);
//following added from web https://github.com/duinoWitchery/hd44780/wiki/ioClass:-hd44780_I2Cexp
#include <Wire.h>
#include <hd44780.h>                       // main hd44780 header
#include <hd44780ioClass/hd44780_I2Cexp.h> // i2c expander i/o class header
hd44780_I2Cexp lcd; // declare lcd object: auto locate i2c address & auto config expander chip pin mapping
#define EEPROM_LAYOUT_VERSION 1
#define AMOUNT_OF_INDEXES 1
#define INDEX_RING_BUFFER 0
// Rotary encoder is wired with the common to ground and the two
// outputs to pins 2 and 3.
Rotary rotary = rotary(2, 3);
enum PinAssignments {
  encoderPinA = 2,    // right
  encoderPinB = 3,    // left
  clearButton = 5,    // Encoder swtich
// Defines 20M location variables
int long TwentyM_Pos = 3248;   // 3330 predefined travel distance to 40M from 20M
int long TwentyM_sw = 11;      // 20M target select switch
// Defines 30M location variables
int long ThirtyM_Pos = 1953;   // predefined travel distance to 40M from 30M
int long ThirtyM_sw = 10;      // 30M target select switch
// Defines 40M location variables
int long FortyM_Pos = 0;   // 3362 predefined travel distance to 40M from 20M
// defines pins numbers for motor driver A4988
    const int stepPin = 8;
    const int dirPin = 9;
// Counter that will be incremented or decremented by rotation.
long counter = 0;
long old_count = counter;   // old_count tells lcd to update if different than counter
long value = counter; //largest value that might be written to EEPROM
long FortyM_start = 0;   // Starting position for 40M
// defines power failure sensing
    int DCdown = 6;
    int PowerFail;
    int unsaved = LOW;
 *On a brand new Arduino board, remove the comment on the following line of code, power up the board, then,
 *power fail the board.
 *Next, comment out the following line. This presets the counter stored value to a known location.
 *counter = 0;
 // Sets power failure sense pin
  pinMode(DCdown, INPUT_PULLUP);
  // Sets the two pins as Outputs for stepper motor
  pinMode(stepPin,OUTPUT);
  pinMode(dirPin,OUTPUT);
  pinMode(encoderPinA, INPUT);
  pinMode(encoderPinB, INPUT);
  pinMode(clearButton, INPUT);
  // turn on pullup resistors
  digitalWrite(encoderPinA, HIGH);
  digitalWrite(encoderPinB, HIGH);
  digitalWrite(clearButton, HIGH);
  digitalWrite(ThirtyM_sw, HIGH);
  digitalWrite(TwentyM_sw, HIGH);
  digitalWrite(DCdown, HIGH);
    while (!Serial);
  attachInterrupt(0, rotate, CHANGE);
  attachInterrupt(1, rotate, CHANGE);
  EEPROMwl.begin(EEPROM_LAYOUT_VERSION, AMOUNT_OF_INDEXES);
  readData(); //reads data stored in EEPROM to find last used counter value
  // Set display type as 16 char, 2 rows
  lcd.begin(16,2);
  // Print on first row
  lcd.setCursor(0,0);
  lcd.print("Counter");
  // Wait 0.1 second
  delay(100);
  // Print on second row
  lcd.setCursor(0,1);
  lcd.print(counter);
  // Wait 0.1 seconds
  delay(100);
  if (old_count != counter) {
  // Clear the display
     lcd.clear();
     lcd.setCursor(0,0);
  // Wait 0.1 second
     delay(100);
     lcd.setCursor(0,1);
     lcd.print(counter);
  // Wait 0.1 seconds
     delay(100);
 PowerFail = digitalRead ( DCdown );
  if ( PowerFail == HIGH && unsaved == LOW) {
  Serial.print("V7.0:Storing power failure: counter: ");
  Serial.println(counter);
    writeData();  //    we only want to save to eeprom once when power fails
  Serial.println("Line 176: counter");
  unsaved = HIGH;
  delay(750);
 if ( PowerFail == LOW ) {
    unsaved = LOW;
// ***********   reset/40 Meters   **********
Sets counter to "0" which is lowest freq., 40M.
Upon power up, the tuning position is assumed to be 40M. Future
location stored in EEPROM and that position will be recalled upon boot up.
  if (digitalRead(clearButton) == LOW )  {
  Serial.println("Line 197: counter");
  while (counter < 0) {
    CCW_direction();
  while (counter > 0) {
    CW_direction();
   writeData();
   readData();
//  ************    30 Meter switch handler:     ************
  if (digitalRead(ThirtyM_sw) == LOW )  {
   Serial.println("Line 216: counter");
  while (counter < ThirtyM_Pos) {
    CCW_direction();
  while (counter > ThirtyM_Pos) {
    CW_direction();
   writeData();
   readData();
//  ************    20 Meter switch handler:     ************
  if (digitalRead(TwentyM_sw) == LOW )  {
   Serial.println("Line 254: counter");
  while (counter < TwentyM_Pos) {
    CCW_direction();
  while (counter > TwentyM_Pos) {
    CW_direction();
   writeData();
   readData();
void writeData() {
//  writes a new value no matter what value was written before.
  EEPROMwl.putToNext(INDEX_RING_BUFFER, counter);
void readData() {
  int dataLength = 4;
  long currentIndex = EEPROMwl.getCurrentIndexEEPROM(INDEX_RING_BUFFER, dataLength);
      Serial.print("251: EEPROM stored value: ");
      Serial.println(EEPROM.get(currentIndex, value));
      counter = (EEPROM.get(currentIndex, value));
  int EEPROM_address = (currentIndex);
      Serial.print("256: EEPROM_address:");
      Serial.println(EEPROM_address);
void CCW_direction() {
        digitalWrite(dirPin,HIGH); // Enables the motor to move in a CCW  direction (higher frequency)
      for(int long x =   0; x < 20; x++) {
        digitalWrite(stepPin,HIGH);
        delayMicroseconds(800);
        digitalWrite(stepPin,LOW);
   counter++;
  Serial.print("Line 273 CCW: ");
     lcd.clear();
     lcd.setCursor(0,0);
  // Wait 0.1 second
   //  delay(100);
     lcd.setCursor(0,1);
     lcd.print(counter);
  // Wait 0.1 seconds
   //  delay(100);
void CW_direction(){
    // Rotation requests for 20 pulse movement CW
        digitalWrite(dirPin,LOW); // Enables the motor to move in a CW direction (lower frequency)
      // Makes 20 pulses for making 1/10 cycle rotation
      for(long int x = 0; x < 20; x++) {
     counter--;
  Serial.print("Line 311 CW: ");
     lcd.clear();
     lcd.setCursor(0,0);
  // Wait 0.1 second
   //  delay(100);
     lcd.setCursor(0,1);
     lcd.print(counter);
  // Wait 0.1 seconds
   //  delay(100);
// rotate is called anytime the rotary inputs change state.
void rotate() {
  unsigned char result = rotary.process();
  if (result == DIR_CCW) {
    counter++;
// Rotary encoder requests 20 pulse movement CCW
        digitalWrite(dirPin,HIGH); // Enables the motor to move in a CCW direction (raises frequency)
      for(int x = 0; x < 20; x++) {
  } else if (result == DIR_CW) {
    counter--;
    // Rotary encoder requests 20 pulse movement CW
Here is the rotary.h file:
 * Rotary encoder library for Arduino.
#ifndef Rotary_h
#define Rotary_h
#include "Arduino.h"
// Enable this to emit codes twice per step.
// #define HALF_STEP
// Values returned by 'process'
// No complete step yet.
#define DIR_NONE 0x0
// Clockwise step.
#define DIR_CW 0x10
// Counter-clockwise step.
#define DIR_CCW 0x20
class Rotary
  public:
    Rotary(char, char);
    unsigned char process();
    void begin(bool internalPullup=true, bool flipLogicForPulldown=false);
    inline unsigned char pin_1() const { return pin1; }
    inline unsigned char pin_2() const { return pin2; }
  private:
    unsigned char state;
    unsigned char pin1;
    unsigned char pin2;
    unsigned char inverter;
#endif
Here is the rotary.cpp file:
/* Rotary encoder handler for arduino.
 * Copyright 2011 Ben Buxton. Licenced under the GNU GPL Version 3.
 * Contact: bb@cactii.net
#include "Rotary.h"
 * The below state table has, for each state (row), the new state
 * to set based on the next encoder output. From left to right in,
 * the table, the encoder outputs are 00, 01, 10, 11, and the value
 * in that position is the new state to set.
#define R_START 0x0
#ifdef HALF_STEP
// Use the half-step state table (emits a code at 00 and 11)
#define R_CCW_BEGIN 0x1
#define R_CW_BEGIN 0x2
#define R_START_M 0x3
#define R_CW_BEGIN_M 0x4
#define R_CCW_BEGIN_M 0x5
const unsigned char ttable[6][4] = {
  // R_START (00)
  {R_START_M,            R_CW_BEGIN,     R_CCW_BEGIN,  R_START},
  // R_CCW_BEGIN
  {R_START_M | DIR_CCW, R_START,        R_CCW_BEGIN,  R_START},
  // R_CW_BEGIN
  {R_START_M | DIR_CW,  R_CW_BEGIN,     R_START,      R_START},
  // R_START_M (11)
  {R_START_M,            R_CCW_BEGIN_M,  R_CW_BEGIN_M, R_START},
  // R_CW_BEGIN_M
  {R_START_M,            R_START_M,      R_CW_BEGIN_M, R_START | DIR_CW},
  // R_CCW_BEGIN_M
  {R_START_M,            R_CCW_BEGIN_M,  R_START_M,    R_START | DIR_CCW},
#else
// Use the full-step state table (emits a code at 00 only)
#define R_CW_FINAL 0x1
#define R_CW_NEXT 0x3
#define R_CCW_BEGIN 0x4
#define R_CCW_FINAL 0x5
#define R_CCW_NEXT 0x6
const unsigned char ttable[7][4] = {
  // R_START
  {R_START,    R_CW_BEGIN,  R_CCW_BEGIN, R_START},
  // R_CW_FINAL
  {R_CW_NEXT,  R_START,     R_CW_FINAL,  R_START | DIR_CW},
  // R_CW_BEGIN
  {R_CW_NEXT,  R_CW_BEGIN,  R_START,     R_START},
  // R_CW_NEXT
  {R_CW_NEXT,  R_CW_BEGIN,  R_CW_FINAL,  R_START},
  // R_CCW_BEGIN
  {R_CCW_NEXT, R_START,     R_CCW_BEGIN, R_START},
  // R_CCW_FINAL
  {R_CCW_NEXT, R_CCW_FINAL, R_START,     R_START | DIR_CCW},
  // R_CCW_NEXT
  {R_CCW_NEXT, R_CCW_FINAL, R_CCW_BEGIN, R_START},
#endif
 * Constructor. Each arg is the pin number for each encoder contact.
Rotary::Rotary(char _pin1, char _pin2) {
  // Assign variables.
  pin1 = _pin1;
  pin2 = _pin2;
  // Initialise state.
  state = R_START;
  // Don't invert read pin state by default
  inverter = 0;
void Rotary::begin(bool internalPullup, bool flipLogicForPulldown) {
  if (internalPullup){
    // Enable weak pullups
    pinMode(pin1,INPUT_PULLUP);
    pinMode(pin2,INPUT_PULLUP);
  }else{
    // Set pins to input.
    pinMode(pin1, INPUT);
    pinMode(pin2, INPUT);
  inverter = flipLogicForPulldown ? 1 : 0;
unsigned char Rotary::process() {
  // Grab state of input pins.
  unsigned char pinstate = ((inverter ^ digitalRead(pin2)) << 1) | (inverter ^ digitalRead(pin1));
  // Determine new state from the pins and state table.
  state = ttable[state & 0xf][pinstate];
  // Return emit bits, ie the generated event.
  return state & 0x30;
and here is the error message:
C:\Users\k1ypp\Documents\Arduino\MLA-controller-40-20M-with-LCD\MLA-controller-40-20M-with-LCD.ino:52:28: error: no match for call to '(Rotary) (int, int)'
exit status 1
Compilation error: no match for call to '(Rotary) (int, int)'
Unless I'm going down a rabbit hole, the *.h file is looking for a "char" but the error is complaining about an "int". I'm no expert, so maybe it is obvious, but not to me.
Thanks
Dennis
Try:
Rotary rotary = Rotary(2, 3);
I had already tried that and had a bunch more errors. Then again, maybe that is the correct one and there is something else that needs to be fixed?
Dennis
Did you look at how the example program does it?
Rotary r = Rotary(2, 3);
What error do you get now?
Here it is with "Rotary:"
C:\Users\k1ypp\AppData\Local\arduino\sketches\697E2FF19C97EE5B93477DA0C1AD98D9\libraries\Rotary-master\Rotary.cpp.o (symbol from plugin): In function Rotary::Rotary(char, char)': (.text+0x0): multiple definition of Rotary::Rotary(char, char)'
C:\Users\k1ypp\AppData\Local\arduino\sketches\697E2FF19C97EE5B93477DA0C1AD98D9\sketch\Rotary.cpp.o (symbol from plugin):(.text+0x0): first defined here
C:\Users\k1ypp\AppData\Local\arduino\sketches\697E2FF19C97EE5B93477DA0C1AD98D9\libraries\Rotary-master\Rotary.cpp.o (symbol from plugin): In function Rotary::Rotary(char, char)': (.text+0x0): multiple definition of Rotary::process()'
collect2.exe: error: ld returned 1 exit status
exit status 1
Compilation error: exit status 1
There seem to be a lot of "multiple definition" and "first defined here" errors. I'm having a problem determining where it should be getting defined.
Dennis
Oddly enough, here is a sketch that is based on the same code, but a shorter version and does compile with no errors.
As far as the rotary code is concerned, I see no difference, and it is using the same library.
#include <Mouse.h>
 * K1YPP MAGNETIC LOOP ANTENNA STEPPER MOTOR SKETCH FOR ARDUINO UNO
 * 12 April, 2018
 * This sketch controls a stepper motor to drive a threaded shaft to tune a magnetic loop
 * antenna. There are some variable definitions in the beginning, followed by a setup() routine
 * that initially runs to preset things.
 * Next comes the main loop(). The program keeps looping until a band switch is depressed, which
 * calls for the motor to move the shaft to the new position. If the operator needs to
 * fine tune things, a rotary encoder is turned, either CW or CCW. An interrupt routine
 * handles the encoder movements (see below)  and, if a Arduino IDE serial port is enabled, the physical
 * count of the location of the shaft is displayed.
 * Should there be a power failure OR the power switch to the stepper motor is turned off, the
 * power fail routine will write the current shaft position (counter) to EEPROM and
 * await shutdown. If the Arduino is still powered from the computer/USB port, the program will
 * still run but the motor won't respond. This can be used to change the counter without
 * moving the shaft, should the two need syncrhonization. When motor power is restored the
 * Arduino will read the EEPROM and everything is good to go.
 * The read/write to EEPROM uses the EEPROMWearLevel library from github. This library spreads
 * the writes to EEPROM over the entire 1024 addresses in the Arduino UNO. The EEPROM has a
 * maximum guaranteed write life of 100k writes (usually it is many times that, but data errors
 * could happen after 100k writes). In the real world use of this sketch, there are not too many
 * writes to EEPROM in a given day, 100k power fails amounts to a very busy day!
 * See: https://github.com/PRosenb/EEPROMWearLevel
 * for more details.
 * The Rotary Encoder library will dump integers to the serial
 * of rotation.
 * See here for an example using interrupts rather than polling.
// Lets begin the sketch:
#include <Rotary.h>
// Currently 15M band is 1995
// Defines 17M location variables (Currently 17M band, 18.068 Mhz)
int long TenM_Pos = 1491;   // 1491 predefined travel distance to 15M from 20M
int long TenM_sw = 11;      // 17M target select switch
// Defines 15M location variables (Currently 15M band, 21.000 Mhz)
int long FifteenM_Pos = 1995;   // 1995 predefined travel distance to 12M from 20M
int long FifteenM_sw = 10;      // 15M target select switch
// Defines xxM location variables (used for adding another bandswitch in future
// int long xxM_Pos = xxxx;   // predefined travel distance to xxM from 20M
// to determine xxxx, measure distance on shaft from 40M position to new band.
// Multiply inches * 200 = new xxxx.
// int long xxM_sw = xx;      // xxM target select switch, replace xx with pin number on Arduino
int long TwentyM_Pos = 0;   // 1995 predefined travel distance to 20M from 10M
long counter = 0;
    int DCdown = 6;
    int PowerFail;
    int unsaved = LOW;
  digitalWrite(FifteenM_sw, HIGH);
  digitalWrite(TenM_sw, HIGH);
  //   digitalWrite(xx_sw, HIGH); enabled if adding another band switch
    while (!Serial);
  Serial.print("V7.0:Power up: counter: ");
  Serial.print("V7.0:Going down for power failure: counter: ");
    writeData();  readData(); //    we only want to save to eeprom once when power fails
  unsaved = HIGH;
  delay(750);
    unsaved = LOW;
// ***********   reset/20 Meters   **********
Upon power up, the tuning position is assumed to be 40M. Future m
  Serial.println("Line 165: counter");
    CCW_direction();
    CW_direction();
   writeData();
   readData();
//  ************    10 Meter switch handler:     ************
  if (digitalRead(TenM_sw) == LOW )  {
   Serial.println("Line 182: counter");
  while (counter < TenM_Pos) {
    CCW_direction();
  while (counter > TenM_Pos) {
    CW_direction();
   writeData();
   readData();
//  ************    15 Meter switch handler:     ************
  if (digitalRead(FifteenM_sw) == LOW )  {
   Serial.println("Line 199: counter");
  while (counter < FifteenM_Pos) {
    CCW_direction();
  while (counter > FifteenM_Pos) {
    CW_direction();
   writeData();
   readData();
 //  ************    xx Meter switch handler (template):     ************
// Either copy this section, or remove comment limiters to enable for a new band.
// Replace anything that has "xx" with the band of interest, such as "FifteenM_sw"
  if (digitalRead(xxM_sw) == LOW )  {
   Serial.println("Line 222: counter");
  while (counter < xxM_Pos) {
    CCW_direction();
  while (counter > xxM_Pos) {
    CW_direction();
   writeData();
   readData();
void writeData() {
void readData() {
  int dataLength = 4;
      Serial.print("257: EEPROM stored value: ");
      Serial.print("262: EEPROM_address:");
counter++;
  Serial.print("Line 279 CCW: ");
     counter--;
  Serial.print("Line 296 CW: ");
void rotate() {
    counter++;
    counter--;
Maybe there is some clue here that I have missed?
Dennis
You probably have more than one .INO file in the sketch folder.
xfpd, You were on the right track. There wasn't another .ino in folder, but there was a stray rotary.h file. How it got there, I don't know.
Anyway, I deleted it and it now compiles with no errors. Why it was looking there for a library file, I'm not certain? Maybe the compiler has some sort of hierarchy that it follows to look for .h or .cpp files in the local folder before loading from the library folder? Perhaps someone can address this? Anyway, I'll mark this as closed.
Thank you.
Dennis
Any file of known extensions (.ino, .INO, .S, .h, .cpp...) inside the sketch folder is treated like a "tab" in the IDE, and it is (attempted) compiled with the sketch.
I didn't know that (obviously!). Thank you very much, I have learned something.
Dennis
