pegwatcher:
Yes, that too. and lots of machine language with octal on my first 8080 home brew. I had no compiler. I programmed the little 256 byte ROM for that one with a binary counter connected to the address pins and touched data pins with a pick hooked the higher voltage to blow the fuses.
pegwatcher:
OK, that beats me....
ABruso:
Hi all, I am looking for a relay that can switch SEQUENTIALLY through a number of different loads. I have a timer that I want to signal this 'rotary relay' to switch to the next load.This is for a 24V DC system. The loads are only 5 amps, maybe 10.
A bunch of logic-level MOSFETs rated at 40V or more and Rds(on) of 0.01 ohms or less)?
Well that would work for low-side switching. Do you need high-side switching? Are the loads
inductive?
