I need to operate a strobe (12V) with a relay 150 mt away from the mC and was thinking of using one 25LS31 driver on the arduino side and a 25LS32 receiver on the strobe side connected with 2 twisted par of cable. But I am not sure how to set this up.
I have done a quick schematic how I think it might should be (se the pix). I would be super thankful if someone could correct it before I try to build it.
Maybe (I don't see why it should matter) I should switch place with enable and input, so the output from the microcontroller will be the output from the 26ls31 and 5V from the power supply will enable the driver.
Firstly, RS-422 is not a communications protocol, it is an electrical specification, but may have a communications protocol use on it that allows a single master many slaves network topology.
For your situation, I think you are making it overly complex for what you are wanting and in fact you would not be able to drive a relay of any size from the output of the 25LS32 chip.
These chips are ment for data communications, not driving relays.
Using it the way you have your schematic, you will potentially destroy the chip from relay back EMF quick smart.
All you need I beleive is a simple transistor circuit to drive your relay.
You can have one transistor near the Arduino to drive the cable say with a switched 5Vdc or 12Vdc low current signal. Then at the remote end, where you will have a power supply to actually drive the realy, you have a second transistor to do the actual current drive for the relay.
You don't detail enough information such as about the realy you are using to operate the strobe, or if you have a power supply at the strobe end.
This shouldn't be in networking protocols, but is the general electronics section.
I missed to put in the transistor. It is meant to be between the 26sl32 chip and the relay, so I can add supply voltage to drive the relay. The relay will control the 12V for the strobe.
I suggest not to use the 26LS chips as they are making your idea too complex for no reason or gain.
Just use two transistors like I mentioned, one to drive the 130m wire and one to drive the relay.
The arduino is next to the sensor now so I guess the problem would just be the same if I move the arduino to the other end.
What about the sensibility for disturbances with just two transistors and the long cable? I thought this would be a more safe and stable way to solve this problem (or so I heard anyway). It would also be possible to put up another arduino at the strobe end for a future wider configuration.
