RS232 to TTL converter for weighing, but Serial Write Can't show perfect data
I am want to display my weighing scale, so to make it I use max 3232 and communication running normal.
But i have some problem when I serial monitor, data appear not perfect, so I try to hyperterminal and the data appears perfect.
My arduino code is
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11    ); // RX, TX   <------<<<< use the pins you want
  mySerial.begin(9600);
    while (mySerial.available())
      Serial.print((char)mySerial.read()); //Serial.write(mySerial.read());   // You can also use:     Serial.print((char)mySerial.read());
      //delayMicroseconds(200);
and my wiring
TX scale Converter max3232
TX DB9 Pin 3
GND DB9 Pin 5 (GND)
Converter max3232 Arduino UNO
Pin TTL RX Pin D10
VCC 5V
GND GND
this my weighing scale
this serial monitor
my config hyperterminal
data at hyperterminal
data ASCII from scale
Pin TTL RX Pin D10
You forgot the ground.
++Karma; // For correctly posting code and lots of other information on your first post.
PerryBebbington:
++Karma; // For posting code and lots of other information on your first post.
oh sorry i forgot to write hehe
I already connect GND and VCC
According to the image of the data format, there are only 7 databits and a parity; that's also how you configured your terminal program. You can't configure Serial monitor for that.
You should also setup your SoftwareSerial for that format but data formats it's not supported by SoftwareSerial. Best option for that is to use a board with two or more serial ports.
If you don't care about the parity bit, then set it to 0 before sending to the serial monitor. Software serial expects to see 8 bits, no parity, 1 stop bit, so the parity bit will be input as the most significant bit of an 8-bit value.
sterretje:
OK, what board with two serial port?
actually i want show the scale data to java program (netbeans)
david_2018:
how to set it? do you mean SERIAL_8N1 ?
I want to show the data to java like this
devjavus:
Serial.write(mySerial.read() & 0x7F);
@OP
Arduino mega for example.
TX DB9 Pin 3
GND DB9 Pin 5 (GND)
Usually, the receive pin in the db9 is PIN number 2, is the above wiring correct?
Also the serial configuration is different.
Regards
david_2018:
david_2018:
Thankyou so much brother...
now i get perfect data
can you explain about "0x7F"?
abdelhmimas:
@OP
abdelhmimas:
@OP
ok thank for your suggest.
abdelhmimas:
TX DB9 Pin 3
GND DB9 Pin 5 (GND)
Regards
yeah pin numer 2 is RX max3232
mySerial.read() returns the ASCII character in the format of a parity bit in the most significant bit followed by seven data bits. The & symbol is the bitwise logical AND operator. 0x7F is hexidecimal for the binary number 01111111, which when ANDed with the ASCII character will set the most significant bit to 0 and leave the other bits unchanged.
The scale is sending ASCII characters as seven data bits, a parity bit, and a stop bit. Software serial expects eight data bits followed by a stop bit, which causes the parity bit to appear as part of the data, which is then removed by setting the parity bit to zero.
david_2018:
really brilliant.
david_2018:
ahh, I see , thankyou for your help..
Is it possible I send data to serial without "ST,"
just take +0000.150 Kg to serial monitor?
Your current code (opening post) simply echoes to the PC what is received on mySerial. You can e.g. start the echoing after you have detected the the comma after ST and stop echoing after you have detected the linefeed.
Alternatively, as demonstrated in below linked thread, you can collect the data first (basically read till the linefeed) and next send the message starting at the character after the comma.
You might get some ideas from Robin's updated Serial Input Basics thread.
Hey @devjavus I faced similar issues and solved here:
devjavus:
Devjavus,
I am interested in your Java code, can you post?
Thank you
sterretje:
ok thankyou so much
yeah I read your thread first for wiring and make sure my module its ok, but i have any problem about 7bit data hehehe
thankyou so much
abdelhmimas:
Devjavus,
Thank you
I got from internet too, basic java to arduino
you can get from this
