Im working in a project of data mesurement insertion of a MAGNETOSTRICTIVE LEVEL PROBE using RS485 communication , the probe use power supply of 12-30v in the electronic board and for that ive used a psu with 12v ( +Vcc and the 0 Vcc) and the rest of the cables (A and the B) directly to the rs485 converter.
The probe seems powered on but their is no communication between the converter and the probe (ive used putty ,serial port monitor and realterm) even the converter driver is installed and the cables are well connected (from the probe documentation).
heres the linik of the probe's technical guide:Probe's DOC
Im waiting for your help and thank you in advance.
Then it's very likely truly an input, or it's failed for some reason. Let's assume it's an input. Give it 5V, and connect ground as well. Now what happens?
