RS485 modbus RTU communication using TTL converter.
hi,
I am want to read the value from the slave RS485. I am using the following code communication error I am getting a communication error.
Pin configuration is explained below TTL A and B output is given to D- and D+. DE and RE are shorted and given to ground DI is given to TX and RO is given to RX.
do respond to this as soon as possible. I just want to read the RS485 values from the Slave device.
// Include these libraries for using the RS-485 and Modbus functions
#include <RS485.h>
#include <ModbusMaster485.h>
#include <SPI.h>
// Instantiate ModbusMaster object as slave ID 1
ModbusMaster485 node(254);
// Define one addres for reading
#define address 3000
// Define the number of bytes to read
#define bytesQty 100
  pinMode(5, OUTPUT);
  digitalWrite(5, LOW);
  // Power on the USB for viewing data in the serial monitor
  delay(100);
  // Initialize Modbus communication baud rate
  node.begin(19200);
  // Print hello message
  Serial.println("Modbus communication over RS-485");
  delay(100);
  // This variable will store the result of the communication
  // result = 0 : no errors
  // result = 1 : error occurred
  int result =  node.readHoldingRegisters(address, bytesQty);
  if (result != 0) {
    // If no response from the slave, print an error message
    Serial.println("Communication error");
  else {
    // If all OK
    Serial.print("Read value : ");
    // Print the read data from the slave
    Serial.print(node.getResponseBuffer(0));
  Serial.print("\n");
  delay(2000);
  // Clear the response buffer
  node.clearResponseBuffer();
Please provide a link to the libraries you used!
This won't work as it deactivates the sending part of the driver and activates the receiver constantly. The ModBus protocol needs to send answers to the master so it has to have the possibility to send out messages.
What type of Arduino are you running this on? On most types you'll have a double usage of the UART with this code (Serial connects to RX/TX on most types).
