RTC controlling LED's
Hi guys, I'm trying to use my RTC to control LED's. For example at a certain time the LED's will change colour. I am getting the following issue "expected primary-expression before ' , ' token." on the lines
digitalWrite(uint32_t, LOW);
Any help would be great
Thanks
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 rtc;
#define PIN 3
#define NUM_LIGHTS 24
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LIGHTS, PIN, NEO_GRB + NEO_KHZ800);
void setup () {
strip.begin();
strip.setBrightness(100);
strip.show();
Serial.begin(57600);
#ifdef AVR
Wire.begin();
#else
Wire1.begin(); // Shield I2C pins connect to alt I2C bus on Arduino Due
#endif
rtc.begin();
if (! rtc.isrunning()) {
Serial.println("RTC is NOT running!");
// following line sets the RTC to the date & time this sketch was compiled
// rtc.adjust(DateTime(F(DATE), F(TIME)));
// This line sets the RTC with an explicit date & time, for example to set
// January 21, 2014 at 3am you would call:
// rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
void loop () {
uint32_t low = strip.Color(255, 100, 0);
uint32_t high = strip.Color(255, 0, 0);
// uint32_t night = strip.Color(255, 0, 0);
// Turn them off
//for( int i = 0; i<NUM_LIGHTS; i++){
//strip.setPixelColor(i, high);
//strip.show();}
DateTime now = rtc.now();
Serial.print(now.day(), DEC);
Serial.print('-');
Serial.print(now.month(), DEC);
Serial.print('-');
Serial.print(now.year(), DEC);
Serial.print(' ');
Serial.print(now.hour(), DEC);
Serial.print(':');
Serial.print(now.minute(), DEC);
Serial.print(':');
Serial.print(now.second(), DEC);
// if the time/date is at the given point, rLED will be on, else it will be off
if(now.minute() == 20) {
digitalWrite(uint32_t, HIGH);
Your code Auto formatted in the IDE to improve its layout and posted here in code tags as suggested in Read this before posting a programming question. Please do the same in future
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 rtc;
#define PIN 3
void setup ()
  strip.begin();
  strip.show();
#ifdef AVR
  Wire.begin();
#else
#endif
  rtc.begin();
    // rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
void loop ()
  // Turn them off
  //strip.show();}
  Serial.print('-');
  Serial.print('-');
  Serial.print(' ');
  Serial.print(':');
  Serial.print(':');
  if (now.minute() == 20)
The curly brackets are in a mess in this section
  {  //<<<<<<<<<<<<<<  what is this doing here ?
Also, this:
makes no sense.
The first argument of digitalWrite should be the pin number, not a data type.
