Ws2812 and arduino clocks
I am trying to make a ws2812 and Arduino clock for the first time as a beginner, getting the error mentioned below. Tried codes from different authors, but getting the same error. Please help.
"Arduino: 1.8.19 (Windows 10), Board: "Arduino Uno"
C:\Users\we\Downloads\Compressed\231223\calligraphy\JAM DIGITAL PELANGI JUMBO\JAM_DIGITAL_PELANGI_JUMBO\JAM_DIGITAL_PELANGI_JUMBO.ino: In function 'int GetTime()':
JAM_DIGITAL_PELANGI_JUMBO:75:3: error: 'RTC' was not declared in this scope
RTC.read(Now);
C:\Users\we\Downloads\Compressed\231223\calligraphy\JAM DIGITAL PELANGI JUMBO\JAM_DIGITAL_PELANGI_JUMBO\JAM_DIGITAL_PELANGI_JUMBO.ino: In function 'void TempToArray()':
JAM_DIGITAL_PELANGI_JUMBO:160:3: error: 'RTC' was not declared in this scope
RTC.read(tm);
C:\Users\we\Downloads\Compressed\231223\calligraphy\JAM DIGITAL PELANGI JUMBO\JAM_DIGITAL_PELANGI_JUMBO\JAM_DIGITAL_PELANGI_JUMBO.ino: In function 'void TimeAdjust()':
JAM_DIGITAL_PELANGI_JUMBO:241:5: error: 'RTC' was not declared in this scope
 RTC.read(Now);
exit status 1
option enabled in File -> Preferences.
Welcome to the forum
Although you have not posted your sketch (hint !), I would guess that you have not created an instance of the real time object, or if you have it is not named RTC
If you want help, post your code.
Otherwise, it's like asking a mechanic to fix your car without letting her see your car.
Similar question
@robotlaukinh_tahawa - Even robots need to mind the guidelines and start their own topic and not hijack others.
@handy_writer
Anda perlu menyiarkan lakaran anda supaya orang boleh membacanya dan membantu anda.
You need to post your sketch so people can read it and help you.
///https://youtu.be/w1XMInQThNI(Please watch and Subscribe )
#include <DS3232RTC.h>
#include <TimeLib.h>
#include <Time.h>
#include <Wire.h>
#include <FastLED.h>
#include <RTClib.h>
#define NUM_LEDS 114 // 474 +2 Number of LED controlled
#define COLOR_ORDER GRB // Define color order for your strip
#define LED_PIN 9 // Data pin for led comunication
#define DST_PIN 5 // Define DST adjust button pin
#define MIN_PIN 4 // Define Minutes adjust button pin
#define HUR_PIN 2 // Define Hours adjust button pin
#define BRI_PIN 3 // Define Light sensor pin
CRGB leds[NUM_LEDS]; // Define LEDs strip
// 0,0,0,0
// 1,1,1,1
// 1 2 3 4 5 6 7 8 9 10111213141516171819202122232425262728
byte digits[12][28] = {{0,0,0,0,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1}, // Digit 0
{0,0,0,0,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,1,1,1}, // Digit 1
{1,1,1,1,1,1,1,1,1,1,1,1,0,0,0,0,1,1,1,1,1,1,1,1,0,0,0,0}, // Digit 2
{1,1,1,1,1,1,1,1,1,1,1,1,0,0,0,0,0,0,0,0,1,1,1,1,1,1,1,1}, // Digit 3
{1,1,1,1,1,1,1,1,0,0,0,0,1,1,1,1,0,0,0,0,0,0,0,0,1,1,1,1}, // Digit 4
{1,1,1,1,0,0,0,0,1,1,1,1,1,1,1,1,0,0,0,0,1,1,1,1,1,1,1,1}, // Digit 5
{1,1,1,1,0,0,0,0,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1}, // Digit 6
{0,0,0,0,1,1,1,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,1,1,1,1}, // Digit 7
{1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1}, // Digit 8
{1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,0,0,0,0,1,1,1,1,1,1,1,1}, // Digit 9 | 2D Array for numbers on 7 segment
{1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0}, // Digit *0
{0,0,0,0,0,0,0,0,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,0,0,0,0}}; // Digit C
bool Dot = true; //Dot state
bool DST = true; //DST state// false to true
bool TempShow = false;
int last_digit = 0;
// int ledColor = 0x0000FF; // Color used (in hex)
long ledColor = CRGB::DarkOrchid; // Color used (in hex)
//long ledColor = CRGB::MediumVioletRed;
//Random colors i picked up
long ColorTable[21] = {
CRGB::Amethyst, //white
CRGB::Aqua, //pink
CRGB::Blue, //Blue
CRGB::Chartreuse,// Gold
CRGB::DarkGreen, //Red
CRGB::DarkMagenta,//Aqua
CRGB::DarkOrange, // yellow green
CRGB::DeepPink, //Aqua
CRGB::Fuchsia, //Sea blue
CRGB::Gold, //Gold
CRGB::GreenYellow,//off white
CRGB::LightCoral,//white
CRGB::Tomato,//white
CRGB::Salmon,//Pure white
CRGB::Red,// Drak Green
CRGB::Orchid,//blue white
CRGB::Sienna,//yellow white
CRGB::Purple,// aqua
CRGB::DarkOrange,//yellow green
CRGB::FloralWhite,//white
CRGB::Yellow //yellow
void setup(){
Wire.begin();
FastLED.addLeds<WS2812B, LED_PIN, RGB>(leds, NUM_LEDS);
LEDS.setBrightness(20); // Set initial brightness
pinMode(DST_PIN, INPUT_PULLUP); // Define DST adjust button pin
pinMode(MIN_PIN, INPUT_PULLUP); // Define Minutes adjust button pin
pinMode(HUR_PIN, INPUT_PULLUP); // Define Hours adjust button pin
pinMode(BRI_PIN, INPUT_PULLUP); // Define bright adjust
TempShow = false; // do not show temperature
// Get time in a single number, if hours will be a single digit then time will be displayed 155 instead of 0155
int GetTime(){
tmElements_t Now;
RTC.read(Now);
//time_t Now = RTC.Now();// Getting the current Time and storing it into a DateTime object
int hour=Now.Hour;
int minute=Now.Minute;
int second =Now.Second;
if (second % 2==0) {Dot = false;}
else {Dot = true;};
if (hour >= 12) {
hour -= 12;
// Handle hour 0 (midnight) being shown as 12.
// else if (hour == 0) {
// hour += 12;
return (hour*100+minute);
// Check Light sensor and set brightness accordingly
void BrightnessCheck(){
const byte sensorPin = 3; // light sensor pin
const byte brightnessLow = 75; // Low brightness value
const byte brightnessHigh = 20; // High brightness value
int sensorValue = digitalRead(sensorPin); // Read sensor
if (sensorValue == 0) {LEDS.setBrightness(brightnessHigh);}
else {LEDS.setBrightness(brightnessLow);}
// Convert time to array needed for display
void TimeToArray(){
int Now = GetTime(); // Get time
int cursor = 114; // last led number
// Serial.print("Time is: ");Serial.println(Now);
if (DST){ // if DST is true then add one hour
Now+=100;
// Serial.print("DST is ON, time set to : ");Serial.println(Now);
if (Dot){leds[57]=ledColor;
leds[56]=ledColor;}
else {leds[57]=0x000000;
leds[56]=0x000000;
for(int i=1;i<=4;i++){
int digit = Now % 10; // get last digit in time
if (i==1){
// Serial.print("Digit 4 is : ");Serial.print(digit);Serial.print(" ");
  cursor = 86;
  for(int k=0; k<=27;k++){
    // Serial.print(digits[digit][k]);
    if (digits[digit][k]== 1){leds[cursor]=ledColor;}
     else if (digits[digit][k]==0){leds[cursor]=0x000000;};
     cursor ++;
  // Serial.println();
  if (digit != last_digit)
    cylon();
    ledColor =  ColorTable[random(21)];
  last_digit = digit;
else if (i==2){
  // Serial.print("Digit 3 is : ");Serial.print(digit);Serial.print(" ");
  cursor =58;
     cursor ++;
 else if (i==3){
  // Serial.print("Digit 2 is : ");Serial.print(digit);Serial.print(" ");
  cursor =28;
     cursor ++;
else if (i==4){
  // Serial.print("Digit 1 is : ");Serial.print(digit);Serial.print(" ");
  cursor =0;
  if(digit !=0){
     cursor ++;
  if(digit ==0){
    if (digits[12][k]== 1){leds[cursor]=ledColor;}
     else if (digits[12][k]==0){leds[cursor]=0x000000;};
     cursor ++;
 Now /= 10;
// Convert temp to array needet for display
void TempToArray(){
tmElements_t tm;
RTC.read(tm);
if (tm.Second != 27) {
TempShow = false;
return;
TempShow = false;//true to false
int t = RTC.temperature();
int celsius = (t / 4.0) * 100;
Serial.print("Temp is: ");Serial.println(celsius);
leds[42]=0x000000;
leds[43]=0x000000;
int digit = celsius % 10; // get last digit in time
if (i==1){
  cursor = 86;
    Serial.print(digits[11][k]);
    if (digits[11][k]== 1){leds[cursor]=ledColor;}
     else if (digits[11][k]==0){leds[cursor]=0x000000;};
     cursor ++;
else if (i==2){
  cursor =58;
    Serial.print(digits[10][k]);
    if (digits[10][k]== 1){leds[cursor]=ledColor;}
     else if (digits[10][k]==0){leds[cursor]=0x000000;};
     cursor ++;
else if (i==3){
  cursor =28;
     cursor ++;
else if (i==4){
  cursor =0;
     cursor ++;
celsius /= 10;
void DSTcheck(){
int buttonDST = digitalRead(5);
// Serial.print("DST is: ");Serial.println(DST);
if (buttonDST == LOW){
if (DST){
DST=false;
// Serial.print("Switching DST to: ");Serial.println(DST);
else if (!DST){
DST=true;
void TimeAdjust(){
int buttonH = digitalRead(HUR_PIN);
int buttonM = digitalRead(MIN_PIN);
if (buttonH == LOW || buttonM == LOW)
tmElements_t Now;
RTC.read(Now);
int hour=Now.Hour;
int minutes=Now.Minute;
if (buttonH == LOW){
if (Now.Hour== 23){Now.Hour=0;}
else {Now.Hour += 1;};
}else {
if (Now.Minute== 59){Now.Minute=0;}
else {Now.Minute += 1;};
// if (Now.Hour > 12){Now.Hour = Now.Hour -12;} // 24 to 12 hr
// else {Now.Hour = Now.Hour ;};
RTC.write(Now);
/* coool effect function*/
void fadeall() { for(int i = 0; i < NUM_LEDS; i++) { leds[i].nscale8(250); } }
void cylon () {
static uint8_t hue = 0;
Serial.print("x");
// First slide the led in one direction
// Set the i'th led to red
leds[i] = CHSV(hue++, 255, 255);
// Show the leds
FastLED.show();
// now that we've shown the leds, reset the i'th led to black
// leds[i] = CRGB::Black;
fadeall();
// Wait a little bit before we loop around and do it again
delay(10);
Serial.print("x");
// Now go in the other direction.
for(int i = (NUM_LEDS)-1; i >= 0; i--) {
// Show the leds
FastLED.show();
fadeall();
delay(10);
void loop() // Main loop
BrightnessCheck(); // Check brightness
DSTcheck(); // Check DST
TimeAdjust(); // Check to se if time is geting modified
TimeToArray(); // Get leds array with required configuration
TempToArray(); // Show Temperature
FastLED.show(); // Display leds array
if (TempShow == true) delay (8000);
@handy_writer
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
