i have problem with rtc ds1307 Data logger shield, i lost 3 seconds every 5 minutes logging data. why did it happen ? and what the solution ? thanks
why did it happen ?
Because of a problem with your code, most likely.
Fix the code you didn't post, in spite of the fact that posting code IS a requirement for posting in this section of the forum.
Assuming that you're writing to an SD card, writing to a file on the card is a buffered write. So it writes to a buffer first and when the buffer is full or when you close the file, the data is actually written to the card. That last step is possibly slowing the rest of your program down.
this is my program
#include <TimeLib.h>
#include <DS1307RTC.h>
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
#include "Nextion.h"
#include <EEPROM.h>
#include <DallasTemperature.h>
#include <OneWire.h>
#include <SoftwareSerial.h>
#define ONE_WIRE_BUS 7
#define PH A0
#define samplingInterval 20
#define samplingInterval_1 20
#define samplingInterval_2 20
#define printInterval 800
#define ArrayLenth 40
#define interval 1000
#define interval1 1000
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature DS18B20(&oneWire);
float Celsius;
float Offset_suhu;
int pHArray[ArrayLenth];
int pHArrayIndex = 0;
float Offset_ph;
static float pH;
static float teganganph;
int TSS = A1;
float tss;
float Offset_tss;
float tegangantss;
String data_string;
String txt_month;
String txt_day;
String txt_hour;
String txt_minute;
String txt_second;
static unsigned long time;
static unsigned long time_for_action;
static unsigned long time_for_action_1;
static unsigned long samplingTime = millis();
static unsigned long samplingTime_1 = millis();
static unsigned long samplingTime_2 = millis();
static unsigned long printTime_1 = millis();
unsigned long millis_string;
unsigned long millis_kirimdata;
File myFile;
NexButton s1 = NexButton(2, 3, "s1");
NexButton s2 = NexButton(2, 4, "s2");
NexButton p1 = NexButton(2, 6, "p1");
NexButton p2 = NexButton(2, 7, "p2");
NexButton t1 = NexButton(2, 9, "t1");
NexButton t2 = NexButton(2, 10, "t2");
char buffer[100] = {0};
NexTouch *nex_listen_list[] = {
&s1, &s2, &p1, &p2, &t1, &t2,
NULL
void s2PushCallback(void *ptr) {
Offset_suhu += 0.1;
memset(buffer, 0, sizeof(buffer));
itoa(Offset_suhu, buffer, 10);
EEPROM.write(Offset_suhu, Celsius);
void s1PushCallback(void *ptr) {
Offset_suhu -= 0.1;
void p2PushCallback(void *ptr) {
Offset_ph += 0.1;
itoa(Offset_ph, buffer, 10);
EEPROM.write(Offset_ph, pH);
void p1PushCallback(void *ptr) {
Offset_ph -= 0.1;
void t2PushCallback(void *ptr) {
Offset_tss += 0.1;
itoa(Offset_tss, buffer, 10);
EEPROM.write(Offset_tss, tss);
void t1PushCallback(void *ptr) {
Offset_tss -= 0.1;
Serial3.begin(9600);
while (!Serial) ;
setSyncProvider(RTC.get);
if (timeStatus() != timeSet)
Serial.println("Unable to sync with the RTC");
Serial.println("RTC has set the system time");
if (!SD.begin(10, 11, 12, 13)) {
Serial.println("Gagal Membuka Micro SD!");
return;
Serial.println("Berhasil Membuka Micro SD");
DS18B20.begin();
delay(2000);
nexInit();
s1.attachPush(s1PushCallback);
s2.attachPush(s2PushCallback);
p1.attachPush(p1PushCallback);
p2.attachPush(p2PushCallback);
t1.attachPush(t1PushCallback);
t2.attachPush(t2PushCallback);
time_for_action = 0;
time_for_action_1 = 0;
millis_kirimdata = 0;
time = millis();
if (millis () > time_for_action) {
time_for_action = millis() + (unsigned long)interval;
void loggingDS18B20();
if (millis() - samplingTime > samplingInterval) {
DS18B20.requestTemperatures();
Celsius = (DS18B20.getTempCByIndex(0));
String command = "displaysuhu.txt="" + String(Celsius + Offset_suhu) + """;
Serial.print(command);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
void loggingPH();
if (millis() - samplingTime_1 > samplingInterval_1) {
pHArray[pHArrayIndex++] = analogRead(PH);
if (pHArrayIndex == ArrayLenth)pHArrayIndex = 0;
teganganph = (averageData() / 1023) * 5.0;
pH = (3 * teganganph)- 0.10;
String command = "displayph.txt="" + String(pH + Offset_ph) + """;
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
void loggingKEKERUHAN();
if (millis() - samplingTime_2 > samplingInterval_2) {
TSS = analogRead(A1);
tegangantss = TSS * (5.0 / 1023.0);
// tss = (-16.97 * tegangantss) + 69.29;
//tss = (-180.1 * tegangantss) + 742.1;
//tss = (-177.3* tegangantss) + 737;
tss = (-5.839* tegangantss) + 45.43;
String command = "displaytss.txt="" + String(tss + Offset_tss) + """;
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
if (millis () > time_for_action_1) {
time_for_action_1 = millis() + (unsigned long)interval1;
(timeStatus() == timeSet);
myFile = SD.open ("logger.txt", FILE_WRITE);
myFile.print(year());
myFile.print("-");
if (month() < 10) {
txt_month = String("0") + month();
else {
txt_month = String(month());
myFile.print(txt_month);
myFile.print("-");
if (day() < 10) {
txt_day = String("0") + day();
else {
txt_day = String(day());
myFile.print(txt_day );
myFile.print(" ");
if (hour() < 10) {
txt_hour = String("0") + hour();
else {
txt_hour = String(hour());
myFile.print(txt_hour);
myFile.print(":");
if (minute() < 10) {
txt_minute = String("0") + minute();
else {
txt_minute = String(minute());
myFile.print(txt_minute);
myFile.print(':');
if (second() < 10) {
txt_second = String("0") + second();
else {
txt_second = String(second());
myFile.print(txt_second);
myFile.print(",");
myFile.print(Celsius + Offset_suhu);
myFile.print(",");
myFile.print(pH + Offset_ph);
myFile.print(",");
myFile.print(tss + Offset_tss);
myFile.println();
myFile.close();
nexLoop(nex_listen_list);
if (millis () - millis_string >= 250) {
millis_string = millis();
data_string =
String (year())+ "," +
String (txt_month)+ "," +
String (txt_day)+ "," +
String (txt_hour)+ "," +
String (txt_minute)+ "," +
String (txt_second)+ "," +
String (Celsius + Offset_suhu) + "," +
String (pH + Offset_ph) + "," +
String (tss + Offset_tss);
if (millis() - millis_kirimdata >= 500) {
millis_kirimdata = millis();
Serial3.print(data_string);
Serial3.print('\n');
double averageData() {
double temp = 0 ;
for ( int i = 0 ; i < 500 ; i++ ) {
temp += analogRead(A0);
return temp / 500 ;
time = millis();
Why do you have a function prototype in the middle of loop()? That is NOT calling a function.
Adding time is NOT guaranteed to work. Subtracting is, unless the interval exceeds 49+ days.
You can print '0' to the file. There is NO excuse for overusing the String class the way you are.
On EVERY pass through loop(), you call millis() many, many times, and seem to think that each call is going to return the same value. It is NOT.
Call millis() ONCE and save the value in a variable. Use that variable in place of all the calls to millis().
