RTC objects understanding problems
Hello freinds!
I leanrned from my last posts, that i must be more specfic about my probelms to help you guys.
What i am using:
ESP32
NEXTION 7 inch display
#include <Arduino.h>
#include <Wire.h>
#include "RTClib.h"
#include <Nextion.h>
#include "EEPROM.h"
#include "DFRobot_ESP_PH.h"
// SD card
#include "FS.h"
#include "SD.h"
#include "SPI.h"
//RTC-clock
#include <Wire.h>
#include "RTClib.h"
//#include <functions.cpp>
#include "functions.h"
#define RXD2 16
#define TXD2 17
//Classobjects
Initialize init_1;
File file;
RTC_DS3231 rtc;
uint32_t setup_start;
***********************SETUP****************************************************************************
  nexInit();
  Serial2.begin(9600, SERIAL_8N1, RXD2, TXD2);
  EEPROM.begin(64);
  ph.begin();
  init_1.beginInitialize();
  init_1.beginInitializeSendToNextion();
  DateTime now = rtc.now();
  setup_start = now.hour();
  //Serial COM
  Wire.begin();
   // while the serial stream is not open, do nothing:
  while (!Serial) ;
  ****************SD Initializing process**********
  SD.begin(5);
  Serial.print("Initializing SD card...");
  if (!SD.begin(5))
    Serial.println("initialization failed!");
    //return;
  uint8_t cardType = SD.cardType();
  if(cardType == CARD_NONE) {
    Serial.println("No SD card attached");
    //return;
  file = SD.open("/data.txt");
  if(!file) {
    Serial.println("File doens't exist");
    Serial.println("Creating file...");
    writeFile(SD, "/data.txt", "ID, Date, Time, Value_raw, Value_maped \r\n");
  else {
    Serial.println("File already exists");
  file.close();    */
  ****************RTC Initializing process**********
  #ifndef ESP8266
    while (!Serial); // for Leonardo/Micro/Zero
  #endif
    delay(1000); // wait for console opening
    if (! rtc.begin()) {
      Serial.println("Couldn't find RTC");
      while (1);
    if (rtc.lostPower()) {
      Serial.println("RTC lost power, lets set the time!");
      // following line sets the RTC to the date &amp; time this sketch was compiled
      rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
      // This line sets the RTC with an explicit date &amp; time, for example to set
      // January 21, 2014 at 3am you would call:
      //rtc.adjust(DateTime(2014(Jahr), 1(Monat), 21(Tag), 3(Stunde), 0(Minute), 0(Sekunde)));
      //rtc.adjust(DateTime(2019, 10, 31, 11, 19, 0));
      //rtc.adjust(DateTime(2019, 11, 1,11,48,00));
***********************Loop****************************************************************************
  //DateTime hol;
  String current_line = "";
  //Interval for measurements
  if (millis() - startChrono >=(init_1._measrueIntvl)*1000)
    voltage = mapf(analogRead(PH_PIN),A1.low_x1,A1.low_y1,A1.low_x2,A1.low_y2);
    phValue = ph.readPH(voltage);
    A1.phValue=phValue;                                                               //Ausgerechneter Ph Value von lib DFRobot wird in struct gespeichert
    writeTextIntoNextion();
    init_1.logSDCard();
    startChrono=millis();
  //Intervall for time. Usually its set to 1 sec
  if (millis() - startChrono_clock >= Clocktimer)
    sprintf(tempString, "%02d.%02d.%02d/%02d:%02d:%02d",now.day(),now.month(),now.year(),now.hour(), now.minute(),now.second());
    Serial2.print("time.txt=\"");
    Serial2.print(tempString);
    Serial2.write('"');
    Serial2.write(0xFF);
    DateTime future (now + TimeSpan(0,0,1,0));
    Serial.println("now.unixtime()");
    Serial.println(now.unixtime());
    Serial.println("future.unixtime()");
    Serial.println(future.unixtime());
    Serial.print("setup_start   ");
    Serial.println(setup_start);
    checkRoutine();
    writeGeneralInfo();
    startChrono_clock=millis();
    nexLoop(nex_listen_list);
The output that i get is:
now.unixtime(): 17
future.unixtime(): 17
setup_start: 165
What i dont understand: isnt the now object not always the same? The object DateTime now = rtc.now(); that i created in Setup, shouldnt that store the current "hours" when the sectch was uploaded? Why is it 165? I expected 17. The hours the RTC is set
thank you
No, it's an object representing the current time.
No, it should represent the timestamp when rtc.now() was called. As you call rtc.now before you call rtc.begin(), the result is probably garbage.
now.unixtime() and now.hours() is not the same!
ahh thank you.
Stupid mistake from my side.
Thank you so much!
