Hi guys! I'm working on an alarm clock using ESP8266, nextion touch display, and buzzer. I'm first trying to interface RTC DS1302 to ESP8266. Here's the pin configuration and code of the RTC DS1302:
// CONNECTIONS:
// DS1302 CLK/SCLK --> 5
// DS1302 DAT/IO --> 4
// DS1302 RST/CE --> 2
// DS1302 VCC --> 3.3v - 5v
// DS1302 GND --> GND
#include <ThreeWire.h>
#include <RtcDS1302.h>
ThreeWire myWire(4,5,2); // IO, SCLK, CE
RtcDS1302<ThreeWire> Rtc(myWire);
void setup ()
Serial.begin(57600);
Serial.print("compiled: ");
Serial.print(__DATE__);
Serial.println(__TIME__);
Rtc.Begin();
RtcDateTime compiled = RtcDateTime(__DATE__, __TIME__);
printDateTime(compiled);
if (!Rtc.IsDateTimeValid())
// Common Causes:
// 1) first time you ran and the device wasn't running yet
// 2) the battery on the device is low or even missing
Serial.println("RTC lost confidence in the DateTime!");
Rtc.SetDateTime(compiled);
if (Rtc.GetIsWriteProtected())
Serial.println("RTC was write protected, enabling writing now");
Rtc.SetIsWriteProtected(false);
if (!Rtc.GetIsRunning())
Serial.println("RTC was not actively running, starting now");
Rtc.SetIsRunning(true);
RtcDateTime now = Rtc.GetDateTime();
if (now < compiled)
Serial.println("RTC is older than compile time! (Updating DateTime)");
else if (now > compiled)
Serial.println("RTC is newer than compile time. (this is expected)");
else if (now == compiled)
Serial.println("RTC is the same as compile time! (not expected but all is fine)");
void loop ()
printDateTime(now);
if (!now.IsValid())
// Common Causes:
// 1) the battery on the device is low or even missing and the power line was disconnected
delay(10000); // ten seconds
#define countof(a) (sizeof(a) / sizeof(a[0]))
void printDateTime(const RtcDateTime& dt)
char datestring[20];
snprintf_P(datestring,
countof(datestring),
PSTR("%02u/%02u/%04u %02u:%02u:%02u"),
dt.Month(),
dt.Day(),
dt.Year(),
dt.Hour(),
dt.Minute(),
dt.Second() );
Serial.print(datestring);
I just ran the Rtc by Makuna sample code. I have a new RTC and a new battery. However in the serial monitor, it says "RTC lost confidence in the DateTime!"
Thank you for the help!
