RTC or Millis to manage timed process
I am trying to design a system to manage a timed process which runs over a 30 hour process. I'm planning on using ESP32. The system needs to actuate two 220vac motorised ball valves, with SSR relays, to fill and empty a water vessel from a header tank. After each cycle, I would like I have a float switch to determine when the tank is full, which then needs to be emptied after a set period, ideally user input variable. Can I rely upon millis() function to count the intervals, in a Finite State Machine, or would an RTC (which I haven't used before) be a better option?
Once I have this operational, I'd like to have a simple HMI interface and a way to store some data. The tank sits on load cells sensors and I'd like to be able to store these weights and record times and dates of the fill/empty process. Ultimately, I would like to publish this data to a SQL database and display on web page.
I will take this in stages, but want to make sure I am setting the correct foundation and select the right hardware.
Suggestions appreciated.
I would use millis unless experimentation revealed some shortcomings in doing so. As you have an ESP32 connect to an NTP server and get the time that way.
Thank you Perry for that advice. I have used that approach to get time in an other project which works very well. My location for this project does not have a WAN so I'd need to use 4G or similar - don't know how complicated that would be on ESP. For phase 1 of the project, I had not intended to tackle the web access.
Re HMI, I was look at Nextion and I see that it has an onboard RTC. It also has an inbuilt SD card slot. Could I use this to store the data from the process timer and sensors?
I have not used any HMI before and interested to know if Nextion is a good option or overly complex for my requirements?
I also found this item on Amazon which has ESP board integrated with LCD display and LoRa, which might overcome lack of wifi access. Is this a viable option? For user to select inputs, such as time intervals in hours, what options would I have, since this is not touch screen?
Which would be easier to implement, as I am fairly new to this with only one project successfully implemented to date.
Thanks again,
Paul
See Displays - Arduino Forum for my tutorial on Nextion displays.
Note that only the Enhanced and Intelligent versions have an RTC, not the Basic version.
I would think the internal clock on an ESP32 would be accurate enough for an RTC. I suggest writing a simple sketch to create a millis() based clock and leave it running for a few days and see how accurate it is.
Yes, you can get the Nextion to send you the values of it's internal clock, have a read of How to send a RTC Updating value from my Nextion to an Arduino without lib. - #5 by Untipr - Displays - Arduino Forum
Certainly not with the Basic and Enhanced versions, possibly with the Intelligent version but I think you would be making hard work for yourself if it's even possible. Either use an external SD card if you need it to be removable or look at EEPROM for the ESP32. I can't remember if the ESP32 has built in EEPROM but if not there is probably a library for simulating EEPROM in FLASH, don't know, not looked, something for you to investigate.
The forum mangles links sometimes, here's yours unmangled.
Looks promising but I don't know that board at all, can't really comment.
Buttons or a keypad of some sort. Since I discovered Nextion I have mostly given up using buttons, now I know how to use a Nextion successfully I prefer them to buttons for most purposes. I'm not saying don't use buttons but...
Here is my button tutorial, there are also plenty of others by other people Buttons and other electro-mechanical inputs (introduction) - General Electronics - Arduino Forum
ESP32 store data use SPIFF's.
Don't use millis() for timing on the ESP32.
The ESP32 has a way to use 'micros()'.
No need for a finite state machine, use the built in OS freeRTOS instead.
Here is a example of using the micro seconds counter on the esp32 to do the millis() thing:
void fDoMoistureDetector( void * parameter )
  //wait for a mqtt connection
  while ( !MQTTclient.connected() )
    vTaskDelay( 250 );
  int      TimeToPublish = 5000000; //5000000uS
  int      TimeForADreading = 100 * 1000; // 100mS
  float    WetValue = 1.35f; // value found by putting sensor in water
  float    DryValue = 2.732f; // value of probe when held in air
  float    ADbits = 4095.0f;
  float    uPvolts = 3.3f;
  float    adcValue_b = 0.0f; //Jeanne's plant in yellow pot
  float    Range = DryValue - WetValue;
  float    RemainingMoisture = 100.0f; //prevents pump turn on during start up
  int      printCounts = 0;
  uint64_t TimePastKalman  = esp_timer_get_time(); // used by the Kalman filter
  uint64_t TimePastPublish = esp_timer_get_time(); // used by publish
  uint64_t TimeADreading   = esp_timer_get_time();
  TickType_t xLastWakeTime = xTaskGetTickCount();
  const TickType_t xFrequency = 10; //delay for 10mS
  SimpleKalmanFilter KF_ADC_b( 1.0f, 1.0f, .01f );
  for (;;)
    //read AD values every 100mS.
    if ( (esp_timer_get_time() - TimeADreading) >= TimeForADreading )
      adcValue_b = float( adc1_get_raw(ADC1_CHANNEL_3) ); //take a raw ADC reading
      adcValue_b = ( adcValue_b * uPvolts ) / ADbits; //calculate voltage
      KF_ADC_b.setProcessNoise( (esp_timer_get_time() - TimePastKalman) / 1000000.0f ); //get time, in microsecods, since last readings
      adcValue_b = KF_ADC_b.updateEstimate( adcValue_b ); // apply simple Kalman filter
      TimePastKalman = esp_timer_get_time(); // time of update complete
      RemainingMoisture = 100.0f * (1 - ((adcValue_b - WetValue) / (DryValue - WetValue))); //remaining moisture =  1-(xTarget - xMin) / (xMax - xMin) as a percentage of the sensor wet dry volatges
    //read gpio 0 is water level good. Yes: OK to run pump : no pump off.   remaining moisture good, denergize water pump otherwise energize water pump.
    if ( gpio_get_level( GPIO_NUM_0 ) )
      if ( RemainingMoisture >= 40.0f ) {
        gpio_set_level( GPIO_NUM_4, LOW); //denergize relay module
      if ( RemainingMoisture <= 20.0f )
        gpio_set_level( GPIO_NUM_4, HIGH); //energize relay module
      log_i( "water level bad ");
    printCounts++;
    if ( printCounts == 100 )
      log_i( "adcValue_b = %f remaining moisture %f%", adcValue_b, RemainingMoisture );
      printCounts = 0;
    // publish to MQTT every 5000000uS
    if ( (esp_timer_get_time() - TimePastPublish) >= TimeToPublish )
      //then publish
      xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY ); // whiles MQTTlient.loop() is running no other mqtt operations should be in process
      MQTTclient.publish( topicRemainingMoisture_0, String(RemainingMoisture).c_str() );
      xSemaphoreGive( sema_MQTT_KeepAlive );
      TimePastPublish = esp_timer_get_time(); // get next publish time
    vTaskDelayUntil( &xLastWakeTime, xFrequency );
  vTaskDelete( NULL );
}// end fDoMoistureDetector()
esp_timer_get_time() is the micros counter for the ESP32. The roll over is in about 207 years for the ESP32's micros counter.
What is the problem with millis() on an ESP32?
PerryBebbington:
It goes through the Arduino ESP32 core which turns out not to be as good or accurate as using the ESP32 API. Also, there is a overhead penalty for using the Arduino ESP32 core.
Easiest example, use the Arduino core to read analog values, on a ESP32, then use the ESP32 API.
++Karma; // Not used an ESP32 yet, thanks for the warning, which I'll have forgotten when I need to know!
I added to my post: "Also, there is a overhead penalty for using the Arduino ESP32 core.."
Thanks for the ++
Idahowalker - Thank you for adding your advices, which unfortunately I don't really know how to implement your suggestion. I am using PlatformIO to code ESP's but I am just a beginner. How do I access the ESP native API?
Perry - thank you for the detailed response, which I will take on board.
ESP32 API.
SPIFFS has fallen out of favour and LittleFS is the new King
I replaced millis() with esp_timer_get_time() in my working ESP8266 project but it would not
compile.
Obviously it's a little more complex than simply replacing. As I haven't seen any issues
with using Millis(), I'll stay with this approach until I get more accomplished.
joatmon13:
An ESP32 is NOT a ESP8266.
Quote from: PerryBebbington on Feb 19, 2021, 04:07 am
@ idahowalker can you please explain more
The ide implementation of millis() for the esp32 is
unsigned long IRAM_ATTR millis()
    return (unsigned long) (esp_timer_get_time() / 1000ULL);
Regarding "not to be as good or accurate", are you talking about using a different ESP32 API function other than esp_timer_get_time()?
Regarding the generic overhead penalty of using the Arduino ESP32 core IDE instead of the espressif API/IDE it it your experience that it is need worth the struggle of getting an old brain wrapped around something new. The ESP32 has been challenging enough for me in Arduino land. :confused:
cattledog:
No. I am talking about using esp_timer_get_time() over using millis().
cattledog:
I do not use the ESPRESSIF IDE. I use the Arduino IDE. I prefer to use the ESP32 API with the Arduino IDE.
I originally was fine using the Arduino ESP32 core until I ran into analog to digital conversion issues. On a whim, I tried using the ESP32 AD API. And walla, the issues I was having went away. After that, I switched my preference to using the ESP32 API, when I figured out how.
On another vein, the ESP32 has a SPI module that runs independently of the CPU and can do bi directional background transfers. The ESP32 motor control module generates and controls servo motors without CPU intervention. To cut the list, the ESP32 has many features that are simply not available with the Arduino ESP32 core. That's where the ESP32 API comes in handy, in getting at those features.
