RTC without External RTC ! Only crystal but a good of course
Hi all,
New on the forum and for a good reason , RTC ... un huge subject.
I'm not really a king on Arduino and ATMEGA328P stand alone.
But my subject is :
I don't whant to use for diffrent reasons an external RTC to manage a hour and calendar .
After lot of research on RTC topic I found this one and it interesting (find below a brief explanation and the program) :
http://www.atmel.com/images/atmel-1259-real-time-clock-rtc-using-the-asynchronous-timer_ap-note_avr134.pdf
https://www.element14.com/community/servlet/JiveServlet/download/56240-1-43640/Atmel-megaAVR-ATmega48A-Design%20Elements-Application%20Library-Atmel.Application_Library_12.zip
My questions are :
Someone has alredy tested this way ?
What do you think of this way ?
I don't find anything about drift of time , what is your opinion ?
Regards
Shouldn't technically be an issue if you use interrupts and globals correctly.
You'll need a library or write your own code to handle what happens on an increment of a "tick".
I.e. Using a 16 bit timer @ 16 MHz with a 1024 prescaler and a OCR compare of 15625 gives an overflow time of:
((15625) * 1024)/16MHz = 1 second.
You have an interrupt triggers each second...(ISR_TIMER1_COMPA) that will increment the number of seconds global value.
The global value "could" be the unix timestamp? There may be appropriate libraries to convert unix time stamp to a regional time.
PS: The out of the box crystal may need to be replaced with a more accurate version.
And why MUST you not use an RTC?
The solution described in the Atmel document uses a separate crystal for the timing of the clock. Seems to have very low power consumption and good accuracy.
But consider: What do you need the time and date for? If you want to make a clock with display you have to provide power for the display, too. How is the whole thing powered?
Every time power is lost, you need to manually set date and time. How can you do that? With what interface? You need a serial connection etc. to copy a computer's time to the device or you need to provide buttons etc. to set the clock for a standalone device.
What are you planning to build?
Some time ago I posted code to create an RTC using a 32 kHz crystal and Timer2 in this thread. It also uses the 8 MHz internal oscillator, and calibrates that versus the 32 kHz crystal for better accuracy. For explanation of all the power saving/sleep code, see this excellent tutorial.
This program forms the heart of a remote sensor for a data logger. It sends data via a simple 433 MHz transmitter. At home I have a version that just maintains the RTC and will post that if there is interest.
// ATmega328p Solar/SuperCap powered Real Time Clock and voltage monitor.
// VirtualWire data  transmission
// sjames dot remington / gmail
// This code incorporates an RTC formed by Timer2 and a 32768 xtal on OSC pins
// The internal 8MHz RC oscillator is calibrated by comparison with the 32768 Hz standard
// Mini-uino board from http://crossroadsfencing.com/BobuinoRev17/index.html
// fuses: 8 MHz internal RC clock, LP xtal (32768 Hz) on OSC pins
//  Binary BCD HH:MM:SS time version, RTC maintained in global array RTC_buf[]
//  Data output on PORTD,3 (VirtualWire TX)
//  Power output on PORTD,2 (TX module)
#include <avr/sleep.h>
#include <avr/power.h>
#include <util/delay.h>
#include <VirtualWire.h>
/ Global variables for RTC, time and day
// set the time here, if you like
volatile unsigned char RTC_buf[]={
  0,0,0,0,0,0}; //binary BCD hh:mm:ss (24 hour clock)
volatile unsigned int dayno=0; //days since startup
char buf[40]; //sprintf buffer, about 30 chars actually used
int VW_PWR=2;    //433 MHz TX power
int VW_TX=3;     //Virtual Wire TX
** approximate 1ms delays (can't use Arduino delay - timer disabled)
void delay1ms(unsigned int ms)
  while (ms--) _delay_ms(1);
// everything happens in setup()
  char t,zero=0;
  unsigned int batt,h,m,s;
  pinMode(VW_PWR,OUTPUT);  //transmitter power
  digitalWrite(VW_PWR,LOW); // TX off
  pinMode(VW_TX,OUTPUT);
  digitalWrite(VW_TX,LOW);
  //PRR Power Reduction Register (set PRADC after ADCSRA=0)
  //Bit 7 - PRTWI: Power Reduction TWI
  //Bit 6 - PRTIM2: Power Reduction Timer/Counter2
  //Bit 5 - PRTIM0: Power Reduction Timer/Counter0
  //Bit 3 - PRTIM1: Power Reduction Timer/Counter1
  //Bit 2 - PRSPI: Power Reduction Serial Peripheral Interface
  //Bit 1 - PRUSART0: Power Reduction USART0
  //Bit 0 - PRADC: Power Reduction ADC
  ADCSRA = 0; //disable ADC
  PRR |= (1<<PRTWI)|(1<<PRSPI)|(1<<PRTIM0)|(1<<PRUSART0)|(1<<PRADC); //need Timers 1 and 2
  OSCCAL_calibrate();  //calibrate the RC osc for accurate timing using the 32 kHz crystal
  timer2_init(); //setup timer2 interrupts for RTC
  vw_set_tx_pin(VW_TX);  //initialize VirtualWire TX
  vw_setup(2000); // and bits per sec
  sei();  //enable interrupts
  t=255; //initialize loop timer
  while(1) {
    // wake up on Timer2 overflow (1/sec)
    // output day, time and cpu voltage on uart every 10 minutes
    if(t != RTC_buf[3]) {
      t=RTC_buf[3];
      s=10*RTC_buf[4]+RTC_buf[5]; //format time (seconds)
      m=10*RTC_buf[2]+RTC_buf[3]; //minutes
      h=10*RTC_buf[0]+RTC_buf[1]; //hours
      digitalWrite(VW_PWR,HIGH);  //power on TX
      PRR &= ~(1<<PRADC); //turn ADC back on
      ADCSRA = (1<<ADEN);  //enable and
      ADCSRA |= (1<<ADPS0) | (1<<ADPS1) | (1<<ADPS2);  // set prescaler to 128
      delay1ms(10); //let ADC and TX stabilize
      batt = readVcc(); //get Vcc voltage
      // format days, time and battery voltage
      sprintf(buf,"%0u,%0d,%0d,%0d,%0u%c",dayno,h,m,s,batt,zero); //max ~16 characters
      vw_send((uint8_t *)buf, strlen(buf)); //send it
      vw_wait_tx(); // Wait until message is sent
      digitalWrite(VW_TX,LOW); //power off TX
      ADCSRA = 0; //ADC off
      PRR |= (1<<PRADC);
    } //end if (t)
    //go back to sleep
    set_sleep_mode(SLEEP_MODE_PWR_SAVE);
    sleep_enable();
    cli(); //time critical steps follow
    MCUCR = (1<<BODS) | (1<<BODSE); // turn on brown-out enable select
    MCUCR = (1<<BODS);         //Brown out off. This must be done within 4 clock cycles of above
    sei();
    sleep_cpu();
  } //end while(1)
}  //do everything in setup()
//  Timer2 Interrupt Service
//  32 kKz / 256 = 1 Hz with prescaler 128
//  provides binary BCD Real Time Clock
//  no check for illegal values of RTC_buffer upon startup!
ISR (TIMER2_OVF_vect) {
  // RTC function
  RTC_buf[5]++; // increment second
  if (RTC_buf[5] > 9)
    RTC_buf[5]=0; // increment ten seconds
    RTC_buf[4]++;
    if ( RTC_buf[4] > 5)
      RTC_buf[4]=0;
      RTC_buf[3]++; // increment minutes
      if (RTC_buf[3] > 9)
        RTC_buf[3]=0;
        RTC_buf[2]++; // increment ten minutes
        if (RTC_buf[2] > 5)
          RTC_buf[2]=0;
          RTC_buf[1]++; // increment hours
          char b = RTC_buf[0]; // tens of hours, handle rollover at 19 or 23
          if ( ((b < 2) && (RTC_buf[1] > 9)) || ((b==2) && (RTC_buf[1] > 3)) )
            RTC_buf[1]=0;
            RTC_buf[0]++; // increment ten hours and day number, if midnight rollover
            if (RTC_buf[0] > 2) {
              RTC_buf[0]=0;
              dayno++; //one day at a time...
// initialize Timer2 as asynchronous 32768 Hz timing source
void timer2_init(void) {
  TCCR2B = 0;  //stop Timer 2
  TIMSK2 = 0; // disable Timer 2 interrupts
  ASSR = (1<<AS2); // select asynchronous operation of Timer2
  TCNT2 = 0; // clear Timer 2 counter
  TCCR2A = 0; //normal count up mode, no port output
  TCCR2B = (1<<CS22) | (1<<CS20); // select prescaler 128 => 1 sec between each overflow
  while (ASSR & ((1<<TCN2UB)|(1<<TCR2BUB))); // wait for TCN2UB and TCR2BUB to clear
  TIFR2 = 0xFF; // clear all interrupt flags
  TIMSK2 = (1<<TOIE2); // enable Timer2 overflow interrupt
// Read 1.1V reference against AVcc
// return battery voltage in millivolts
// must be individually calibrated for each CPU
unsigned int readVcc(void) {
  unsigned int result;
  // set the reference to Vcc and the measurement to the internal 1.1V reference
  ADMUX = (1<<REFS0) | (1<<MUX3) | (1<<MUX2) | (1<<MUX1);
  delay1ms(2); // Wait for Vref to settle
  ADCSRA |= (1<<ADSC); // Start conversion
  while (bit_is_set(ADCSRA,ADSC)); // wait until done
  result = ADC;
  // second time is a charm
  result = ADC;
  // calibrated for my Miniduino
  result = 1195700UL / (unsigned long)result; //1126400 = 1.1*1024*1000
  return result; // Vcc in millivolts
// Calibrate the internal OSCCAL byte, using the external 32768 Hz crystal as reference.
void OSCCAL_calibrate(void)  //This version specific to ATmegaXX8
  unsigned char calibrate = 0; //not calibrated;
  unsigned int temp;
  TIMSK1 = 0; //disable Timer1,2 interrupts
  TIMSK2 = 0;
  ASSR = (1<<AS2);        //select asynchronous operation of timer2 (32,768kHz)
  OCR2A = 200;            // set timer2 compare value
  TCCR1A = 0;
  TCCR1B = (1<<CS11);     // start timer1 with prescaler 8
  TCCR2B = (1<<CS20);     // start timer2 with no prescaling (ATmega169 use TCCR2A!)
  while (ASSR & ((1<<TCN2UB)|(1<<TCR2BUB)));  //wait for TCN2UB and TCR2BUB to be cleared
  delay1ms(2000); //allow xtal osc to stabilize
  while(!calibrate)
    cli(); // disable global interrupt
    TIFR1 = 0xFF;   // clear Timer1 flags
    TIFR2 = 0xFF;   // clear Timer2 flags
    TCNT1 = 0;      // clear timer1 counter
    TCNT2 = 0;      // clear timer2 counter
    TCCR1B = (1<<CS11); // start timer1 (again)
    while ( !(TIFR2&(1<<OCF2A)) );   // wait for timer2 compareflag
    TCCR1B = 0; // stop timer1
    sei(); // reenable global interrupts
    if ( TIFR1&(1<<TOV1) ) temp = 0xFFFF;   //overflow, load max
    else   temp = TCNT1;
    //expect about (1e6/32768)*201 = 6134 ticks
    if ( (temp >= 6125) && (temp <= 6145) ) calibrate=1;
    if (temp > 6145) OSCCAL--;   //RC oscillator runs too fast, decrease OSCCAL
    if (temp < 6125) OSCCAL++;   //RC oscillator runs too slow, increase OSCCAL
  } //end while(!calibrate)
} //return
Hi all thanks for you first answer. For To be most clear on my request , I want to activate an output during 20 seconds when the sunrise and 20 seconds when the sunset . The electronic board will be into the nature and supplied at 3v by two AA battery and I want one year minimal autonomy. I calculate the time for awake the board with the gps position ( don't have a GPS chip, I only indicate the position by a constant in the softwares ) .
The main problem with such solutions is that they lack the temperature compensation that is built into the better RTC chips.
You can also get ideas from GitHub - leomil72/swRTC: swRTC is a library that implements a software-RTC on an Arduino board or an Atmel microcontroller
sterretje thank you, your link smell good what I want to do , but no mix with sleep mode . I will try to introduce this point in the code . If someone have good expérience in this topic , he's welcome :slight_smile:
If someone is interesting by RTC and Sleep mode with good accuracy, I found something interesting --> http://www.leonardomiliani.com/en/2012/micrologio-un-micro-orologio-con-un-atmega328p/
If this means that the board will be outdoors, then a light detector would work to determine sunrise/sunset.
That works exactly as posted in reply #3. Both are as accurate as the DS1307 RTC module, that is, the crystal is not temperature compensated.
jremington:
Sunset and sunrise time is calculted, there is no light sensor
LE-BU:
Interesting. How do you do that? The times of sunset/sunrise vary during the year and by latitude.
There is no need to calculate sunrise/set if the device is outdoors.
This Arduino code will calculate very accurate solar positions, including sunrise/set (check for elevation=0). But there are other Arduino programs that just calculate sunrise/set.
jremington thanks for your contribution
