can a RTC be made with just attiny85 ?
Hello Im trying to make a real time clock with just an attiny85 any suggestions ?
You may be able to write a program but the accuracy is low.
Weedpharma
You can use a 32 kHz watch crystal as the clock source. With appropriate programming, you could create an RTC with accuracy typical of a wristwatch (if the temperature is reasonably constant).
I've done that with a PIC chip and was also able to produce 300 baud serial output.
jremington:
how does it keep time over a power off mode ?
would you be able to feed it with a watch batter for time keeping only ?
well im actually not trying to keep time im wanting to set off fireworks at a particular time on july 4th
but I need somthing that can do hours instead of seconds or minutes
The current draw at a clock speed of 32 kHz is so low that you don't need to sleep, or special power saving tricks. For example, the PIC16F630 takes about 18 uA at 3V, with a 32 kHz crystal.
With an ATMega, you can do better though. Timer2 can run during power-save sleep mode with a 32 kHz crystal and wake the CPU every second, which will run using the internal RC oscillator. That takes less than 1 uA. I use this mode as an RTC for my data loggers, and posted the code a while back.
The ATtiny85 can be idled almost all of the time. At 32kHz the idle current is something in the 50-100uA range.
Four of the ATtiny chips have asynchronous timers that allow for wakeup from power save mode via a 32kHz watch crystal and run at 8MHz when awake. Unfortunately the '85 isn't one of them. The picoPower chips that have this feature draw ~1uA when "being an RTC". The non-picoPower ones draw more. I measured about 5uA with an ATtiny167.
The Atmega328p can also function this way.
edit: like jremington said. :slight_smile:
Im kinda stupid when it comes to using interrupts or timers if either of you have some code i could steal
i would greatly appreciate it
i have some ATMEGA328ps and have some ATMEGA32As coming well I have the 328p chips the ATMEGA32A are on their way here now if that would Help ?
This is the heart of an RTC remote RF datalogger, and runs on a bare bones ATmega328 board designed by CrossRoads on this forum.
// ATmega328p Solar/SuperCap powered Real Time Clock and voltage monitor.
// VirtualWire data  transmission
// sjames dot remington / gmail
// This code incorporates an RTC formed by Timer2 and a 32768 xtal on OSC pins
// The internal 8MHz RC oscillator is calibrated by comparison with the 32768 Hz standard
// Mini-uino board from http://crossroadsfencing.com/BobuinoRev17/index.html
// fuses: 8 MHz internal RC clock, LP xtal (32768 Hz) on OSC pins
//  Binary BCD HH:MM:SS time version, RTC maintained in global array RTC_buf[]
//  Data output on PORTD,3 (VirtualWire TX)
//  Power output on PORTD,2 (TX module)
#include <avr/sleep.h>
#include <avr/power.h>
#include <util/delay.h>
#include <VirtualWire.h>
/ Global variables for RTC, time and day
// set the time here, if you like
volatile unsigned char RTC_buf[]={
  0,0,0,0,0,0}; //binary BCD hh:mm:ss (24 hour clock)
volatile unsigned int dayno=0; //days since startup
char buf[40]; //sprintf buffer, about 30 chars actually used
int VW_PWR=2;    //433 MHz TX power
int VW_TX=3;     //Virtual Wire TX
** approximate 1ms delays (can't use Arduino delay - timer disabled)
void delay1ms(unsigned int ms)
  while (ms--) _delay_ms(1);
// everything happens in setup()
  char t,zero=0;
  unsigned int batt,h,m,s;
  pinMode(VW_PWR,OUTPUT);  //transmitter power
  digitalWrite(VW_PWR,LOW); // TX off
  pinMode(VW_TX,OUTPUT);
  digitalWrite(VW_TX,LOW);
  //PRR Power Reduction Register (set PRADC after ADCSRA=0)
  //Bit 7 - PRTWI: Power Reduction TWI
  //Bit 6 - PRTIM2: Power Reduction Timer/Counter2
  //Bit 5 - PRTIM0: Power Reduction Timer/Counter0
  //Bit 3 - PRTIM1: Power Reduction Timer/Counter1
  //Bit 2 - PRSPI: Power Reduction Serial Peripheral Interface
  //Bit 1 - PRUSART0: Power Reduction USART0
  //Bit 0 - PRADC: Power Reduction ADC
  ADCSRA = 0; //disable ADC
  PRR |= (1<<PRTWI)|(1<<PRSPI)|(1<<PRTIM0)|(1<<PRUSART0)|(1<<PRADC); //need Timers 1 and 2
  OSCCAL_calibrate();  //calibrate the RC osc for accurate timing using the 32 kHz crystal
  timer2_init(); //setup timer2 interrupts for RTC
  vw_set_tx_pin(VW_TX);  //initialize VirtualWire TX
  vw_setup(2000);	 // and bits per sec
  sei();  //enable interrupts
  t=255; //initialize loop timer
  while(1) {
    // wake up on Timer2 overflow (1/sec)
    // output day, time and cpu voltage on uart every 10 minutes
    if(t != RTC_buf[3]) {
      t=RTC_buf[3];
      s=10*RTC_buf[4]+RTC_buf[5]; //format time (seconds)
      m=10*RTC_buf[2]+RTC_buf[3]; //minutes
      h=10*RTC_buf[0]+RTC_buf[1]; //hours
      digitalWrite(VW_PWR,HIGH);  //power on TX
      PRR &= ~(1<<PRADC); //turn ADC back on
      ADCSRA = (1<<ADEN);  //enable and
      ADCSRA |= (1<<ADPS0) | (1<<ADPS1) | (1<<ADPS2);  // set prescaler to 128
      delay1ms(10); //let ADC and TX stabilize
      batt = readVcc(); //get Vcc voltage
      // format days, time and battery voltage
      sprintf(buf,"%0u,%0d,%0d,%0d,%0u%c",dayno,h,m,s,batt,zero); //max ~16 characters
      vw_send((uint8_t *)buf, strlen(buf)); //send it
      vw_wait_tx(); // Wait until message is sent
      digitalWrite(VW_TX,LOW); //power off TX
      ADCSRA = 0; //ADC off
      PRR |= (1<<PRADC);
    } //end if (t)
    //go back to sleep
    set_sleep_mode(SLEEP_MODE_PWR_SAVE);
    sleep_enable();
    cli(); //time critical steps follow
    MCUCR = (1<<BODS) | (1<<BODSE);	// turn on brown-out enable select
    MCUCR = (1<<BODS);        		//Brown out off. This must be done within 4 clock cycles of above
    sei();
    sleep_cpu();
  } //end while(1)
}  //do everything in setup()
//  Timer2 Interrupt Service
//  32 kKz / 256 = 1 Hz with prescaler 128
//  provides binary BCD Real Time Clock
//  no check for illegal values of RTC_buffer upon startup!
ISR (TIMER2_OVF_vect) {
  // RTC function
  RTC_buf[5]++;		// increment second
  if (RTC_buf[5] > 9)
    RTC_buf[5]=0;	// increment ten seconds
    RTC_buf[4]++;
    if ( RTC_buf[4] > 5)
      RTC_buf[4]=0;
      RTC_buf[3]++;			// increment minutes
      if (RTC_buf[3] > 9)
        RTC_buf[3]=0;
        RTC_buf[2]++;		// increment ten minutes
        if (RTC_buf[2] > 5)
          RTC_buf[2]=0;
          RTC_buf[1]++;			// increment hours
          char b = RTC_buf[0]; // tens of hours, handle rollover at 19 or 23
          if ( ((b < 2) && (RTC_buf[1] > 9)) || ((b==2) && (RTC_buf[1] > 3)) )
            RTC_buf[1]=0;
            RTC_buf[0]++;		// increment ten hours and day number, if midnight rollover
            if (RTC_buf[0] > 2) {
              RTC_buf[0]=0;
              dayno++; //one day at a time...
// initialize Timer2 as asynchronous 32768 Hz timing source
void timer2_init(void) {
  TCCR2B = 0;  //stop Timer 2
  TIMSK2 = 0;	// disable Timer 2 interrupts
  ASSR = (1<<AS2);	// select asynchronous operation of Timer2
  TCNT2 = 0;			// clear Timer 2 counter
  TCCR2A = 0; 		//normal count up mode, no port output
  TCCR2B = (1<<CS22) | (1<<CS20);		// select prescaler 128 => 1 sec between each overflow
  while (ASSR & ((1<<TCN2UB)|(1<<TCR2BUB))); // wait for TCN2UB and TCR2BUB to clear
  TIFR2 = 0xFF;			// clear all interrupt flags
  TIMSK2 = (1<<TOIE2);	// enable Timer2 overflow interrupt
// Read 1.1V reference against AVcc
// return battery voltage in millivolts
// must be individually calibrated for each CPU
unsigned int readVcc(void) {
  unsigned int result;
  // set the reference to Vcc and the measurement to the internal 1.1V reference
  ADMUX = (1<<REFS0) | (1<<MUX3) | (1<<MUX2) | (1<<MUX1);
  delay1ms(2); // Wait for Vref to settle
  ADCSRA |= (1<<ADSC); // Start conversion
  while (bit_is_set(ADCSRA,ADSC)); // wait until done
  result = ADC;
  // second time is a charm
  result = ADC;
  // calibrated for my Miniduino
  result = 1195700UL / (unsigned long)result; //1126400 = 1.1*1024*1000
  return result; // Vcc in millivolts
// Calibrate the internal OSCCAL byte, using the external 32768 Hz crystal as reference.
void OSCCAL_calibrate(void)  //This version specific to ATmegaXX8
  unsigned char calibrate = 0; //not calibrated;
  unsigned int temp;
  TIMSK1 = 0; //disable Timer1,2 interrupts
  TIMSK2 = 0;
  ASSR = (1<<AS2);        //select asynchronous operation of timer2 (32,768kHz)
  OCR2A = 200;            // set timer2 compare value
  TCCR1A = 0;
  TCCR1B = (1<<CS11);     // start timer1 with prescaler 8
  TCCR2B = (1<<CS20);     // start timer2 with no prescaling (ATmega169 use TCCR2A!)
  while (ASSR & ((1<<TCN2UB)|(1<<TCR2BUB)));  //wait for TCN2UB and TCR2BUB to be cleared
  delay1ms(2000); //allow xtal osc to stabilize
  while(!calibrate)
    cli(); // disable global interrupt
    TIFR1 = 0xFF;   // clear Timer1 flags
    TIFR2 = 0xFF;   // clear Timer2 flags
    TCNT1 = 0;      // clear timer1 counter
    TCNT2 = 0;      // clear timer2 counter
    TCCR1B = (1<<CS11); // start timer1 (again)
    while ( !(TIFR2&(1<<OCF2A)) );   // wait for timer2 compareflag
    TCCR1B = 0; // stop timer1
    sei();			// reenable global interrupts
    if ( TIFR1&(1<<TOV1) ) temp = 0xFFFF;   //overflow, load max
    else   temp = TCNT1;
    //expect about (1e6/32768)*201 = 6134 ticks
    if ( (temp >= 6125) && (temp <= 6145) ) calibrate=1;
    if (temp > 6145) OSCCAL--;   //RC oscillator runs too fast, decrease OSCCAL
    if (temp < 6125) OSCCAL++;   //RC oscillator runs too slow, increase OSCCAL
  } //end while(!calibrate)
} //return
Thank you jremington ill try to use it and let you know later if was able to get it to work
I got the library and got it to compile now Ive just got to figure out how to set the pin i want to turn on after some time ...this was helpful Thank you
@jremington: I'm in the middle of doing something similar and it's great to have someone else's code to compare and contrast. I like the auto-OSCCAL function.
I'm curious about a couple of things:
  1. In the code it says: "can't use Arduino delay - timer disabled"
    Why (and how) is the Arduino delay() disabled?
  2. Why is there a while(1) loop in setup() instead of using loop()?
    Is there a significant efficiency gain?
Thanks.
@bandmwhitt2013:
Let me know if you still have questions about the code. I have another version where the RTC is maintained as a ASCII string, for direct transmission as text.
@jboyton:
The auto-osccal function came from some old Atmel code (which had a couple of problems). Using it makes a huge difference in the accuracy and reliability of UART and other serial output.
  1. I disabled Timer0 to save a small amount of power and to avoid having the timer interrupts wake the CPU.
  2. Yes, loop() is repeatedly called from (hidden) main() after some other things are done, so it is slower. Not that speed, or even that consideration, matters much in this case.
Where is timer 0 disabled? Is the code buried in a library?
I've looked at the core main() code before and tried to decide if it mattered whether I bypassed it or not. I think I even tried timing it once.
Do you know what the source of inefficiency is? And how significant it is?
From 1.6.4:
int main(void)
	init();
	initVariant();
#if defined(USBCON)
	USBDevice.attach();
#endif
	setup();
	for (;;) {
		loop();
		if (serialEventRun) serialEventRun();
	return 0;
Its power is turned off by this line:
Thanks, I hadn't thought to check the power register. How much current does it save to shut off timer 0?
I just timed my code with loop() and with while(1). The difference was about 0.75us, or 6 processor clocks at 8MHz. With a 1Hz wakeup schedule that works out to 0.00008% of the time. So in my case it's not a big deal. That said, since it's basically free I think I'll take it.
One last question, if I haven't exceeded your patience:
Did you ever measure the actual wake time of the processor? I tried to do this and it didn't really add up to what I thought the datasheet said.
I haven't checked either the current draw of Timer0 or the wakeup time. The discussion of wakeup timing in the data sheet seems confusing, and then there are various choices of fuse settings that further cloud the issue.
jremington:
I found here where someone measured a 90uA savings when powering off timer 0 (328 @ 8MHz, 3.3V).
In power save mode timer 0 is stopped so I wouldn't expect it to be drawing any power. It certainly doesn't add 90uA. And it can't wake the processor from power save mode.
For what it's worth:
I tried to measure the wake time in the following way.
Since I don't have an oscilloscope I used the analog comparator of another board. I used a small resistor in series with the power supply to the target board and the analog comparator to detect when the target board current rose above a threshold. Then I had a sketch polling the comparator output and measuring the width of the period when it was high. I was getting a period of about 26us.
Within my target board sketch I was driving a pin high in the first instructions of the timer 2 ISR and low as the last instructions prior to going to sleep. That pulse width measured 10us.
According to the datasheet, the internal 8MHz oscillator starts in 6 clock cycles. Then it takes 4 cycles to process the interrupt and 3 to jump to the ISR. The ISR uses 16 clocks to push registers. That's a total of 23 clocks, about 3us at 8MHz. I'm not sure how long it takes to execute the sleep instructions at the end but I think it is less than 1us.
Totaling that up: 10us + 3us + 1us = ~14us. So why was I measuring 26us?
According to the datasheet:
Atmega328p datasheet:
When the interrupt condition is met, the wake up process is started on the following cycle of the timer clock, that is, the timer is always advanced by at least one before the processor can read the counter value. After wake-up, the MCU is halted for four cycles, it executes the interrupt routine, and resumes execution from the instruction following SLEEP.
That seems to suggest an additional timer 2 clock cycle must be added to the wakeup time. Or does it? The 32.768kHz timer 2 clock cycle is 30.5us which doesn't match the roughly 12us difference I calculated. Maybe my calculation is faulty. Or maybe my measurement was faulty. I wish I could see it on an oscilloscope. Maybe the current ramps up.
