if (digitalRead(ButtonPin1) == LOW) {// If button1 to Ground is closed
digitalWrite(RelayPin, HIGH); // Turn on relay
delay(13000); // Wait 13 seconds
digitalWrite(RelayPin, LOW); // Tun off relay
if (digitalRead(ButtonPin2) == LOW) {// If button2 to Ground is closed
delay(20000); // Wait 20 seconds
omg that was the mistake? Thank you so much kmin!
I'm just a hardware guy and the programming thing is kind of confusing if you don't do it that often.
now this "two button code" is working fine!
Thanks kmin !
... and any code will benefit from being properly formatted. Your original mistake may have leapt off the screen in its obviousity. Yes that is too a word.
Until you have formatting living i your elbows and naturally just write formatted code, avail yourself of the IDE Tool called Autoformat.
It will put your code into one of the several popular formatting styles you will see in well-written code.
It all looked so good, but unfortunately there is a problem and I don't know if it's the code or not. Maybe you can rule it out?
What should be:
If button1 is connected to ground then the pump runs for 13 seconds.
If button2 is connected to ground then the pump runs for 20 seconds.
But what happens:
If button1 is connected to ground, the pump runs for 13 seconds + 13 seconds.
If button1 is connected to Ground, the pump runs for 13 seconds + 20 seconds.
It just happens irregularly
Like this too:
If button2 is connected to Ground, the pump runs for 20 seconds.
If button2 is connected to ground, the pump runs for 13 seconds.
If button2 is connected to ground, the pump runs for 20 seconds + 20 seconds.
If button2 is connected to Ground, the pump runs for 20 seconds + 20 seconds + 20 seconds.
is this a hardware problem? could it be the code???
Could it have something to do with the fact that both switches switch the same output?
I have no idea
PS: @alto777 - yes, I don't know anything about this automatic code formatting, thank you very much for the tip. I'll take a look at it. I'm learning a lot from you here right now, I'm really super grateful.
You can have as many input for one output as you want.
How is your "button" precisely? Momentary push button or something else?
Are the button wires running all over together with the pump wiring?
I have now tested both at least 10 times in succession. 13 seconds and 20 seconds one after the other but also mixed up. now it is running just as it should. i have no idea where the problem was or is.
but before that there was another 20+20 second run. Then I restarted everything, which it had actually done by switching from VIN to 5V.
The “new” code with the two outputs to the relay seems to work.
But I also have the feeling that the chemotherapy has made me totally stupid and I no longer see deeply enough into all the things, such as that it must not go below 5v on Vin.... why didn't I see that?
May I suggest you to wire your setup like this:
-5V/GND from buck directly to relay and directly to Nano.
-From nano, button wiring the way it doesn't run with other wires
-If you still have problems, add external 470R - 1K pull-up resistors for buttons
-Add flyback diode across pump terminals.
One trick that could help if you are experiencing interferences from the pump stopping: Add small delay after turning pump off:
digitalWrite(RelayPin, LOW); // Tun off relay1
