#include <Wire.h>
int lastButtonState = HIGH;
int lastButtonStateLess = HIGH;
int lastButtonStateTarget = HIGH;
int buttonState = HIGH;
int buttonStateLess = HIGH;
int buttonStateTarget = HIGH;
unsigned long lastDebounceTime;
unsigned long lastDebounceTimeLess;
unsigned long lastDebounceTimeTarget;
int debounceDelay = 50;
int count = 0;
int AA = 10;
int AB = 6;
int moisture;
int sensorinput;
int sunlight;
float temp;
float moistLimit = 463.5; // Add by 51.5
unsigned int tempLimitMin = 18;
unsigned int tempLimitmax = 29;
float lightOneLimit = 150.0;
float lightTwoLimit = 100.0;
int changetarget = 0; // Target: 1 = Moisture 2 = Temperature Min 3 = Temperature Max
unsigned long updateTime;
LiquidCrystal_I2C lcd(0x27, 16, 2);
pinMode(8, INPUT_PULLUP);
pinMode(9, INPUT_PULLUP);
pinMode(7, INPUT_PULLUP);
pinMode(2, OUTPUT);
pinMode(12, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(AA, OUTPUT);
pinMode(AB, OUTPUT);
pinMode(13, OUTPUT);
pinMode(A2, INPUT);
lcd.init();
lcd.backlight();
lcd.clear();
// the loop function runs over and over again forever
// Moisture Code
moisture = analogRead(A0);
if (moisture >= moistLimit) {
digitalWrite(2, HIGH);
digitalWrite(AA, HIGH);
digitalWrite(AB, LOW);
else {
digitalWrite(2, LOW);
digitalWrite(AA, LOW);
// Temperature Code (TMP36)
sensorinput = analogRead(A1);
float voltage = sensorinput * (5.0 / 1024.0);
temp = (voltage - 0.5) * 100;
if (temp > tempLimitmax || temp < tempLimitMin)
digitalWrite(12, HIGH);
digitalWrite(12, LOW);
//Sunlight Code
sunlight = analogRead(A2);
//DEBUGGING USE
if (sunlight <= lightOneLimit) {
digitalWrite(4, HIGH);
if (sunlight <= lightTwoLimit) {
digitalWrite(5, HIGH);
else {
digitalWrite(4, LOW);
digitalWrite(5, LOW);
// Button Code
// Increase Button
int pinValue = digitalRead(9);
if (pinValue != lastButtonState)
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay)
if (pinValue != buttonState)
buttonState = pinValue;
if (buttonState == LOW)
digitalWrite(13, HIGH);
switch (changetarget)
case 1:
moistLimit += 51.5;
case 2:
tempLimitMin += 1;
case 3:
tempLimitmax += 1;
case 4:
lightOneLimit += 50.0;
case 5:
lightTwoLimit += 50.0;
digitalWrite(13, LOW);
lastButtonState = pinValue;
// Decrease Button
int pinValueLess = digitalRead(8);
if (pinValueLess != lastButtonStateLess)
lastDebounceTimeLess = millis();
if ((millis() - lastDebounceTimeLess) > debounceDelay)
if (pinValueLess != buttonStateLess)
buttonStateLess = pinValueLess;
if (buttonStateLess == LOW)
case 1:
moistLimit -= 51.5;
case 2:
tempLimitMin -= 1;
case 3:
tempLimitmax -= 1;
case 4:
lightOneLimit -= 50.0;
case 5:
lightTwoLimit -= 50.0;
lastButtonStateLess = pinValueLess;
// Change Target Button
int pinValueTarget = digitalRead(7);
if (pinValueTarget != lastButtonStateTarget)
lastDebounceTimeTarget = millis();
if ((millis() - lastDebounceTimeTarget) > debounceDelay)
if (pinValueTarget != buttonStateTarget)
buttonStateTarget = pinValueTarget;
if (buttonStateTarget == LOW)
changetarget += 1;
if (changetarget > 5)
changetarget = 0;
lastButtonStateTarget = pinValueTarget;
if (millis() - updateTime >= 500ul)
updateTime = millis();
updateLCD();
void updateLCD()
case 0:
lcd.setCursor(0, 0);
lcd.print("Moist Temp Sun");
lcd.setCursor(0, 1);
lcd.print(" ");
lcd.print(moisture);
lcd.setCursor(6, 1);
lcd.print(round(temp));
lcd.setCursor(11, 1);
lcd.print(sunlight);
case 1:
Serial.println(moistLimit);
lcd.print("Mode 1 ");
lcd.print(" ");
lcd.print(moistLimit);
case 2:
Serial.println(tempLimitMin);
lcd.print("Mode 2 ");
lcd.print(" ");
lcd.print(" ");
lcd.print(tempLimitMin);
case 3:
Serial.println(tempLimitmax);
lcd.print("Mode 3 ");
lcd.print(" ");
lcd.print(tempLimitmax);
case 4:
Serial.println(lightOneLimit);
lcd.print("Mode 4 ");
lcd.print(" ");
lcd.print(lightOneLimit);
case 5:
Serial.println(lightTwoLimit);
lcd.print("Mode 5 ");
lcd.print(" ");
lcd.print(lightTwoLimit);
Whenever I have pinModes for the water pump pins (aka. AA, AB) my water pump doesn't run. However, when I remove the pinModes, the pump starts working, but pin 12 led starts blinking slightly.
