I've seen all the comments and answers I could find on how to run steppers from cnc shield, but without grbl, and none of the code has worked for me.
I need to run 2 steppers, 200 steps per rev.
Using a lead screw and nut drive, I can easily figure out how many turns will be required to run a raster program for an XY table, to rout parallel grooves in aluminum, but the program would be something like:
move 5 inches x, forward
move 1/8 inch y, forward
move 5 inches x, backward
move 1/8 inch, forward
Repeat sequence 24 times (so grooves would be cut over a 5 inch by 3 inch area)
Many, many thanks for any help anyone can give.
(And by the way, I saw one video that said the enable/ground pins should be linked. Is that true?)
You forgot to define how fast to move for each of your movements. And are you cutting in both forward and backward movements?
Why on earth would you NOT just run Grbl, and simply feed it lines of g-code? It already does everything you would possibly need, and much more, and it is dead reliable? What is it you hope to gain, other than months of hard work re-inventing the wheel?
It's really just a question of finding out which pins connect to enable, step and direction on your CNC shield. Then you can write code to step your motors as you described. You'll need homing too I expect.
Thanks and I agree, and I would do that of course, but I've tried to load it, and it just doesn't. No doubt it's my fault, but I can't figure it out. I followed the procedure outlined: download, unzip, then open ide, include library, add zip library, select unzipped grbl-master, and it won't show as a selection. Don't know what I'm doing wrong.
I'll have to test for how fast, but I'm thinking 5 seconds/inch. I'm using an m4 lead screw, .7pitch, which works out to about 300 steps per second, I think.
And yes, I'm cutting in both forward and backward movements.
Thanks, yes, and I know the pins, but I'm just very rusty on code (and was never that great to begin with).
How much experience have you had in milling aluminum? Are you using a wood cutting router bit or a real end mill? How many flutes? Are you using a lubricant to keep the aluminum from sticking to the cutter?
In that case, I'd suggest having another go at getting grbl running.
If that fails, disconnect your steppers from the mill and start experimenting with code. Your pattern is simple, so it's just going to be stepping using delay with only one axis moving at a time. Just get a stepper moving at all to start with.
Actually to do what the OP describes also required the "Z" axis to be controlled at the beginning of each pass.
So rather than solve an installation/configuration problem, you've decided it's simpler to write your own cnc controller? I think you have VASTLY under-estimated the work involved. There are grbl forums, and I would expect you could get help that would allow you to easily resolve whatever problem you are having.
Thanks for your reply. No experience, really, and I'm using a carbide-tipped round nose router bit in a router table I built with a home-made xy table. I did used to sell very high tech motion control equipment, so it should work pretty well. I will use a lubricant, and the cuts are extremely shallow, perhaps .01" deep. I also got the softest aluminum I could find, 1100. After I rout the concave grooves, I'm going to cast a plaster mold of them and, with diamond lapping compound, polish the grooves, moving the cast piece along the axis of the grooves back and forth, to get as mirror-like a finish as possible. Then that piece will be used in a blow mold to make a plastic bottle with lenses on one side. It's a recent patent of mine and you can see it at https://media4.giphy.com/media/dv0JkFpJ7A9ygtbjAI/giphy.gif
The sample you see was done in two pieces, but I've made molds and can do blow molded bottles that look much better, except I want much thinner lenses. If 1/8" works, I'll try smaller, but I doubt I'll be able to get much thinner than 1/20".
Thanks again, I'll try that. I've no wish to be creative here, only so many hours in the day.
What is the CNC shield?
How many of these plates are you going to make?
That is the VERY worst you can use for learning. It will quickly gum up your router bit and will RIP instead of cutting the aluminum. Get the hardest aluminum you can find. Even 6061 will gum up and rip until you learn how to mill it.
You can only get smooth finish by: 1. making the end mill exactly vertical to the material you are cutting. Other wise you will be cutting divots. 2. realize that every cut will be a "step" and not a continuous, smooth movement. 3. Learn about "climb milling".
Very poor choice, especially with small diameter tools. You will have to be VERY careful with feeds and speeds, and have a GOOD understanding of the effects of RPM, depth of cut, chipload, and several other factors. High RPM and low feedrate is the WORST thing you can do. They need to be carefully matched, or disaster will follow shorly. Study and learn how and why high-speed machining works, and put it to use, or you will be buying, and breaking, LOTS of cutting tools. You'd be much better off with 6061. All the same problems exist, but not quite as severe as with 1100. Regardless of material, keeping chips out of the cut will also be critical. A Fogbuster would be an excellent investment to provide cooling, lubrication, and chip clearance.
More bad news. This set up will never be stiff enough for milling. Every time one edge of the cutter hits the metal, it will bounce away. This also makes straight lines impossible. Your cutter will always attempt to move away from the cutting line.
Bottom line, learn to mill manually before trying it with your CNC device.
Many thanks for the advice. I may give it a try or two, but also might just have it done at a shop, since I can see I'm pretty much over my head.
Thank you, I can see I might just farm it out.
Do you have a CAD drawing that they can convert to CNC? OR will it all be manually done? Be sure to have them agree to let you watch how it is set up and machined.
