Running Arduino UNO from coin cell
I'm using an arduino on a project and really need to watch the mass of the whole project and it needs to be portable for about 6 hours and working in very low temperatures.
So because of the last two parameters I opted for CR2032 lithium coin cells,200 mAh.
3 of them in a series to get a 9 V voltage and the question arises, is 200 mAh enough for 6 hours of some hardcore code(microSD shield, 3 analog sensors with a 1 Hz sampling rate, should I lower the transfer rate maybe?) or should I add another row of 3 for 400 mAh ?
It's critical for the whole mass to be the lowest possible.
200mAH probably not enough, SD card can draw higher current than that when it starts up.
Arduino then draws ~50mA when doing stuff. Got power LED sucking current, USB/Serial adapter sucking current, autovoltage select sucking power, 5V to 3.3V level translator sucking power, voltage regulator just wasting power.
Go with a 3.3V 8 MHz promini, or wire up a bare minimum chip & parts, use a 3.3V powered SD shield, run from a 1000mAH battery with a normal diode between battery & the rest to knock the battery 4.1V or 4.2V down to 3.4 or 3.5V.
Or maybe a slightly smaller LiPo if 1000mAH is too big.
You will be disappointed with coin cells unless they are like the big CR2032s - in which case I think the LiPo will be smaller, and definitely higher power density.
Matetus:
Lithium coin cells are rated for about 2mA normal use, no way can you power an SDcard
which are very power hungry.
Alkaline button cells might be possible - a stack of 3 gives 4.5V...
Even a tiny LiPo will have oodles of current to spare.
