I am using the following code on windows 10 which works ok. What do I have to do to get it to work on a raspberry pi which uses an older version of IDE
#include <Wire.h>
// Set the LCD address to 0x3F for a 16 chars and 2 line display
LiquidCrystal_I2C lcd(0x3F, 16, 2);
const byte statusLed = 13;
const byte sensorPin = 2;
// The hall-effect flow sensor outputs approximately 4.5 pulses per second per litre/minute of flow.
const float calibrationFactor = 2.9;
volatile uint16_t pulseCount;
float flowRate;
float flowLitres;
float totalLitres;
unsigned long oldTime;
const unsigned long sampleDuration = 1000ul;
// ISR
void pulseCounterISR()
pulseCount++; // Increment the pulse counter
// Initialize a serial connection for reporting values to the host
// Set up the status LED line as an output
pinMode(statusLed, OUTPUT);
digitalWrite(statusLed, HIGH); // We have an active-low LED attached
pinMode(sensorPin, INPUT_PULLUP);
pulseCount = 0;
flowRate = 0;
flowLitres = 0;
totalLitres = 0;
oldTime = millis();
// The Hall-effect sensor is connected to pin 2 which uses interrupt 0.
// Configured to trigger on a FALLING state change (transition from HIGH
// state to LOW state)
// initialize the LCD
lcd.begin();
// Turn on the blacklight
lcd.setBacklight((uint8_t)1);
// First row
lcd.print("L/min:");
// Second row
lcd.setCursor(0,1);
lcd.print("Total:");
unsigned long chrono = millis();
if ((chrono - oldTime) >= sampleDuration) // Only process counters once per sampleDuration
// Disconnect the interrupt ISR while calculating flow rate and sending the value to the host
detachInterrupt(digitalPinToInterrupt(sensorPin));
// if we have calibrationFactor pulses then we have 1 l/minute
flowRate = (pulseCount / calibrationFactor) ; // this is in l/min
// Because this loop may not complete in exactly sampleDuration intervals we calculate
// the number of milliseconds that have passed since the last execution and use
// that to scale the output.
flowRate *= (((float) sampleDuration) / (chrono - oldTime)) ; // this is in l/min
// Divide the flow rate in litres/minute by 60 to determine how many litres have
// passed through the sensor in 1s and multiply by number of second of sampling
flowLitres = (flowRate / 60.0) * (sampleDuration / 1000.0);
// Add the litres we measured to the cumulative total
totalLitres += flowLitres;
// Print the flow rate for this second in litres / minute
lcd.setCursor(8,0);
lcd.print(flowRate/10);
// Print the cumulative total of litres flowed since starting
lcd.setCursor(8,1);
lcd.print(totalLitres/10);
pulseCount = 0; // Reset the pulse counter so we can start incrementing again
oldTime = millis(); // Note the time this processing pass was executed.
// Enable the interrupt ISR again now that we've finished sending output
attachInterrupt(digitalPinToInterrupt(sensorPin), pulseCounterISR, FALLING);
