I just bought an Arduino MEGA off ebay from HongKong and before I give them a positive rating I want to make sure it's in working order. Running the ATS General with nothing plugged in a get a tonne of errors. Am I supposed to be plugging things in to the board to test? or can I run the test with nothing connected?
My output was:
info.MANUFACTURER = Arduino
info.CPU-NAME = ATmega1280
info.GCC-Version = 4.3.2
info.AVR-LibC-Ver = 1.6.4
info.Compiled-date = Jun 21 2011
info.Test-Suite-Name = general
info.Free-memory = 7067 bytes
DigitalReadWrite_02 (helper pin=03) ... FAIL
DigitalReadWrite_03 (helper pin=02) ... FAIL
DigitalReadWrite_04 (helper pin=05) ... FAIL
DigitalReadWrite_05 (helper pin=04) ... FAIL
DigitalReadWrite_06 (helper pin=07) ... FAIL
DigitalReadWrite_07 (helper pin=06) ... FAIL
DigitalReadWrite_08 (helper pin=09) ... FAIL
DigitalReadWrite_09 (helper pin=08) ... FAIL
DigitalReadWrite_10 (helper pin=11) ... FAIL
DigitalReadWrite_11 (helper pin=10) ... FAIL
DigitalReadWrite_12 (helper pin=13) ... FAIL
DigitalReadWrite_13 (helper pin=12) ... FAIL
DigitalReadWrite_14 (helper pin=15) ... FAIL
DigitalReadWrite_15 (helper pin=14) ... FAIL
DigitalReadWrite_16 (helper pin=17) ... FAIL
DigitalReadWrite_17 (helper pin=16) ... FAIL
DigitalReadWrite_18 (helper pin=19) ... FAIL
DigitalReadWrite_19 (helper pin=18) ... FAIL
DigitalReadWrite_20 (helper pin=21) ... FAIL
DigitalReadWrite_21 (helper pin=20) ... FAIL
DigitalReadWrite_22 (helper pin=23) ... FAIL
DigitalReadWrite_23 (helper pin=22) ... FAIL
DigitalReadWrite_24 (helper pin=25) ... FAIL
DigitalReadWrite_25 (helper pin=24) ... FAIL
DigitalReadWrite_26 (helper pin=27) ... FAIL
DigitalReadWrite_27 (helper pin=26) ... FAIL
DigitalReadWrite_28 (helper pin=29) ... FAIL
DigitalReadWrite_29 (helper pin=28) ... FAIL
DigitalReadWrite_30 (helper pin=31) ... FAIL
DigitalReadWrite_31 (helper pin=30) ... FAIL
DigitalReadWrite_32 (helper pin=33) ... FAIL
DigitalReadWrite_33 (helper pin=32) ... FAIL
DigitalReadWrite_34 (helper pin=35) ... FAIL
DigitalReadWrite_35 (helper pin=34) ... FAIL
DigitalReadWrite_36 (helper pin=37) ... FAIL
DigitalReadWrite_37 (helper pin=36) ... FAIL
DigitalReadWrite_38 (helper pin=39) ... FAIL
DigitalReadWrite_39 (helper pin=38) ... FAIL
DigitalReadWrite_40 (helper pin=41) ... FAIL
DigitalReadWrite_41 (helper pin=40) ... FAIL
DigitalReadWrite_42 (helper pin=43) ... FAIL
DigitalReadWrite_43 (helper pin=42) ... FAIL
DigitalReadWrite_44 (helper pin=45) ... FAIL
DigitalReadWrite_45 (helper pin=44) ... FAIL
DigitalReadWrite_46 (helper pin=47) ... FAIL
DigitalReadWrite_47 (helper pin=46) ... FAIL
DigitalReadWrite_48 (helper pin=49) ... FAIL
DigitalReadWrite_49 (helper pin=48) ... FAIL
DigitalReadWrite_50 (helper pin=51) ... FAIL
DigitalReadWrite_51 (helper pin=50) ... FAIL
DigitalReadWrite_52 (helper pin=53) ... FAIL
DigitalReadWrite_53 (helper pin=52) ... FAIL
DigitalReadWrite_54 (helper pin=55) ... FAIL
DigitalReadWrite_55 (helper pin=54) ... FAIL
DigitalReadWrite_56 (helper pin=57) ... FAIL
DigitalReadWrite_57 (helper pin=56) ... FAIL
DigitalReadWrite_58 ... ok
DigitalReadWrite_59 ... ok
DigitalReadWrite_60 (helper pin=61) ... FAIL
DigitalReadWrite_61 (helper pin=60) ... FAIL
DigitalReadWrite_62 (helper pin=63) ... FAIL
DigitalReadWrite_63 (helper pin=62) ... FAIL
DigitalReadWrite_64 (helper pin=65) ... FAIL
DigitalReadWrite_65 (helper pin=64) ... FAIL
DigitalReadWrite_66 (helper pin=67) ... FAIL
DigitalReadWrite_67 (helper pin=66) ... FAIL
DigitalReadWrite_68 (helper pin=69) ... FAIL
DigitalReadWrite_69 (helper pin=68) ... FAIL
PWMoutput_02 (PWM=128 100% LOW 0% HIGH) ... FAIL
PWMoutput_03 (PWM=128 100% LOW 0% HIGH) ... FAIL
PWMoutput_04 (PWM=128 100% LOW 0% HIGH) ... FAIL
PWMoutput_05 (PWM=128 100% LOW 0% HIGH) ... FAIL
PWMoutput_06 (PWM=128 100% LOW 0% HIGH) ... FAIL
PWMoutput_07 (PWM=128 100% LOW 0% HIGH) ... FAIL
PWMoutput_08 (PWM=128 100% LOW 0% HIGH) ... FAIL
PWMoutput_09 (PWM=128 100% LOW 0% HIGH) ... FAIL
PWMoutput_10 (PWM=128 100% LOW 0% HIGH) ... FAIL
PWMoutput_11 (PWM=128 100% LOW 0% HIGH) ... FAIL
PWMoutput_12 (PWM=128 100% LOW 0% HIGH) ... FAIL
PWMoutput_13 (PWM=128 100% LOW 0% HIGH) ... FAIL
PWMoutput_44 (PWM=128 53% LOW 46% HIGH) ... ok
PWMoutput_45 (PWM=128 100% LOW 0% HIGH) ... FAIL
PWMoutput_46 (PWM=128 50% LOW 49% HIGH) ... ok
AnalogInput_00 (Low= 0 High= 52 helper pin=55) ... FAIL
AnalogInput_01 (Low=1021 High=1021 helper pin=54) ... FAIL
AnalogInput_02 (Low= 586 High= 654 helper pin=57) ... FAIL
AnalogInput_03 (Low=1021 High=1021 helper pin=56) ... FAIL
AnalogInput_04 (Low= 0 High= 468 helper pin=59) ... FAIL
AnalogInput_05 (Low= 21 High= 474 helper pin=58) ... FAIL
AnalogInput_06 (Low=1018 High=1020 helper pin=61) ... FAIL
AnalogInput_07 (Low=1023 High=1018 helper pin=60) ... FAIL
AnalogInput_08 (Low= 361 High= 443 helper pin=63) ... FAIL
AnalogInput_09 (Low=1021 High=1021 helper pin=62) ... FAIL
AnalogInput_10 (Low= 549 High= 632 helper pin=65) ... FAIL
AnalogInput_11 (Low=1021 High=1021 helper pin=64) ... FAIL
AnalogInput_12 (Low= 546 High= 641 helper pin=67) ... FAIL
AnalogInput_13 (Low=1021 High=1021 helper pin=66) ... FAIL
AnalogInput_14 (Low= 501 High= 492 helper pin=69) ... FAIL
AnalogInput_15 (Low=1015 High=1021 helper pin=68) ... FAIL
Serial1 ... ok
Serial2 ... FAIL
Serial3 ... FAIL
EEPROM_byte_rw (addr= 0x03A3) ... ok
EEPROM_word_rw (addr= 0x0C89) ... ok
EEPROM_dword_rw (addr= 0x0BB4) ... ok
Memory Usage ... ok
Ran 106 tests in 17.684s
FAILED (failures=97)
