Hi everyone, I'm relatively knew to arduino and this is my first time hooking up a sensor to it.
Steps I took so far.
I looked up the spec sheet to see how it had to be wired.
I wired up the load cell to arduino based off of the spec sheet.
I then uploaded my code to the serial monitor and added the libraries into the library folder .
I then ran the code and the serial monitor displays a value but when I change the weight on the load cell the values do not change in the monitor.
I am unsure what is going wrong. I have hooked up the load cell up to a volt meter and there is a change in voltage so I know my sensor is working correctly. And my code is running so i'm assuming that means the libraries i added are correct as well.
Here is a link to the spec sheet for the load cell I'm working with and here's the code as well.
The code is not error-ring out so I am unsure how to troubleshoot this problem. Again I'm a beginner to arduino any suggestions would help greatly.
I have attached my code and libraries as well if that helps.
Thanks,
Appreciate the help
hx711.h (682 Bytes)
Hx711.cpp (1.16 KB)
HX711-1.ino (625 Bytes)
