Sabertooth 2x25 Powering Arduino
I have the following setup, which works perfectly when the Arduino is connected to USB:
As I understand it, when the arduino is unplugged, the motor controller should provide 5V to the Vin on the Arduino. When I unplug it, everything just turns off (even the status light on the motor controller)
Motor driver needs a decent amount of current to operate, small 9V batteries cannot begin to think about
powering motors, you need a proper power supply or battery. What motor are you intending to drive?
The sabertooth can handle 50A, 9V batteries can comfortably supply perhaps 50mA, a thousand times less current.
[ The 5V BEC on the sabertooth is rated at 1A, dont expect it to even start up without a supply capable of that. ]
I'm just powering a tiny test motor (runs fine on a single AA battery).
I plan to use the Sabertooth to power two 24V motors. I'm not sure about any amperage ratings, but they're about 3" in diameter.
"5V is a regulated 5V supply provided by the driver. Drawing more than 10ma can reduce performance of the driver" -- from the first page of the Sabertooth quick start guide.
The Arduino needs much more than 10ma.
Chagrin:
I'm looking at my specs now... it says "Drawing more than 1A can reduce performance of the driver"
Kryo:
Chagrin:
It looks like that change came with V2 of the driver. The original version is 10ma (battery <=12.6V) or 100ma (battery > 12.6V). If you have V2 of the driver then I guess you can ignore that issue.
