I just got a Nano 33 IOT board, but keep getting this SAM-BA error when I upload any sketch (I haven't coded anything - just trying to upload 'Blink').
I should note that the sketch DOES successfully load & run on the nano, but it's concerning to see an error message (attached).
I've tried a couple different known-good cables, and used various USB ports on my PC (Win 10). I've looked at lots of other users' comments about the SAM-BA error, but no one seems to have found a solution. Any ideas??
Hi and welcome to the forum! Please copy the error messages and paste them in a post...Also your code should be pasted in code tags ( </> )...All this is covered in how to get the best out of the forum! Thanks!
The output finishes with "Verify successful". If your board works, I would ignore the error for now and see what happens in the future.
Try to remember what you do before you upload a sketch. Maybe you had another board connected at the same time or before. Try another USB port. It could be something specific to the PC you are using. If you have another one try that.
