I can't seem to figure out what I'm doing wrong here. I have a custom SAMD21 board. I tried to modify the standard samd21_sam_ba.hex bootloader to match my board. I have modified the board_definitions_boardID.h file to change the pins to what I am using. So far I have modified the LED pins and that part worked. I can still upload via USB using the command:
But if I try to do upload over UART with a USB-UART converter using the same command, I get:
Set binary mode
Send auto-baud
Set binary mode
No device found on COMXX
I use PA17 for my RX pin, and PA16 for my TX pin. This works fine in the application. It is set up on SERCOM1 with PA17 being pad 1 and PA16 pad 0. In my board_definition file I have this defined as follows:
I believe these settings are correct, but I can't figure out the issue. I believe I am building the bootloader correctly because the LEDs have changed and I can still program via USB. Any help would be very much appreciated because I'm running out of ideas.
I'm no expert with SAMD21. I think you have to compile the bootloader with the options you want.
which looks like an Atmel Studio project at a glance but the readme says you can get the toolchain and run the Makefile. I would like to know how it goes (e.g. post the build text please), I have been wanting to do a SAMD21 (or maybe 51) board for a while, unfortunately, have not really done anything.
So, I slept on it, and I figured out the issue. I was powering the board through USB, and apparently the UART bootloader does not work if USB is plugged in.
For this I had to modify the board_definitions.h file to add a case for my board, and I added a board_definitions_myboard.h file that I modified from the board_definitions_genuino_zero.h file that is given in the ArduinoCore-samd.
I also modified the makefile. The ReadMe is a little out of date. Its 2 years old, but the makefile is a month old, so the instructions don't match perfectly.
Assuming you have the Arduino IDE and the SAMD21 toolchain installed in the default locations, you only have to modify the BOARD_ID?= and NAME?= lines of the makefile.
Next challenge is a bootloader for my other board. That one will have to boot from USB or spi flash. I expect that to be more of a challenge, but I'm looking at this example to start:
jamesod:
Hi sorry for digging up this thread, but maybe you can help me. I am trying to compile a custom bootloader and have done what you have posted here, ie create a board definition, include it in board_definitions.h, and mod the Makefile. I call make from the command prompt of Cygwin64. It compiles up to where something #includes <sam.h> then it throws an error... board_driver_i2c.h:23:17: fatal error: sam.h: No such file or directory
I have latest SAMD package 1.6.20 installed on IDE 1.8.8
Problem solved. I was trying to make a boolader form the Sparkfun Dev board package, which is out of date. When I tried it from the Zero package it worked.
