What is not happening? In other words, can you describe in more detail? For example does the servo move at all? Have you run example test code for the servos to make sure that they actually work?
code inline:
#include <Servo.h>
Servo myservo;
int pos = 0;
This is an example sketch for our optical Fingerprint sensor
Designed specifically to work with the Adafruit BMP085 Breakout
----> http://www.adafruit.com/products/751
These displays use TTL Serial to communicate, 2 pins are required to
interface
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada for Adafruit Industries.
BSD license, all text above must be included in any redistribution
#include <Adafruit_Fingerprint.h>
#if defined(__AVR__) || defined(ESP8266)
// For UNO and others without hardware serial, we must use software serial...
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino (WHITE wire)
// Set up the serial port to use softwareserial..
SoftwareSerial mySerial(2, 3);
#else
// On Leonardo/M0/etc, others with hardware serial, use hardware serial!
// #0 is green wire, #1 is white
#define mySerial Serial1
#endif
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
while (!Serial); // For Yun/Leo/Micro/Zero/...
delay(100);
Serial.println("\n\nAdafruit finger detect test");
// set the data rate for the sensor serial port
finger.begin(57600);
delay(5);
if (finger.verifyPassword()) {
Serial.println("Found fingerprint sensor!");
Serial.println("Did not find fingerprint sensor :(");
while (1) { delay(1); }
Serial.println(F("Reading sensor parameters"));
finger.getParameters();
Serial.print(F("Status: 0x")); Serial.println(finger.status_reg, HEX);
Serial.print(F("Sys ID: 0x")); Serial.println(finger.system_id, HEX);
Serial.print(F("Capacity: ")); Serial.println(finger.capacity);
Serial.print(F("Security level: ")); Serial.println(finger.security_level);
Serial.print(F("Device address: ")); Serial.println(finger.device_addr, HEX);
Serial.print(F("Packet len: ")); Serial.println(finger.packet_len);
Serial.print(F("Baud rate: ")); Serial.println(finger.baud_rate);
finger.getTemplateCount();
if (finger.templateCount == 0) {
Serial.print("Sensor doesn't contain any fingerprint data. Please run the 'enroll' example.");
else {
Serial.println("Waiting for valid finger...");
Serial.print("Sensor contains "); Serial.print(finger.templateCount); Serial.println(" templates");
myservo.attach(9);
void loop() // run over and over again
getFingerprintID();
delay(50); //don't ned to run this at full speed.
uint8_t getFingerprintID() {
uint8_t p = finger.getImage();
switch (p) {
case FINGERPRINT_OK:
Serial.println("Image taken");
myservo.write(pos);
Serial.println(myservo.read());
while(digitalRead(9)<=10){
myservo.write(180);
case FINGERPRINT_NOFINGER:
Serial.println("No finger detected");
return p;
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println("Communication error");
return p;
case FINGERPRINT_IMAGEFAIL:
Serial.println("Imaging error");
return p;
default:
Serial.println("Unknown error");
return p;
// OK success!
p = finger.image2Tz();
switch (p) {
Serial.println("Image converted");
case FINGERPRINT_IMAGEMESS:
Serial.println("Image too messy");
return p;
return p;
case FINGERPRINT_FEATUREFAIL:
Serial.println("Could not find fingerprint features");
return p;
case FINGERPRINT_INVALIDIMAGE:
return p;
default:
return p;
// OK converted!
p = finger.fingerSearch();
if (p == FINGERPRINT_OK) {
Serial.println("Found a print match!");
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_NOTFOUND) {
Serial.println("Did not find a match");
return p;
return p;
// found a match!
Serial.print("Found ID #"); Serial.print(finger.fingerID);
Serial.print(" with confidence of "); Serial.println(finger.confidence);
return finger.fingerID;
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
if (p != FINGERPRINT_OK) return -1;
p = finger.fingerFastSearch();
// found a match!
Also you say
what I want to do is while applying thumb servo should go 0 to 90 degree and again with the same thumb, it should go to 90 to 180 degree.
That leaves some questions open. What happens after it reaches 180 degrees, and when does that happen? How long should it stay there? What happens if it goes to 90 degrees, and another person comes along and puts a different thumb on the sensor? Is there any time limit between the first and second thumb scan?
How are you powering your devices? Are both the servo and sensor drawing power from the Arduino? What kind of board is it?
Servos do not move instantaneously. After you issue a move command, you have to delay() a while to wait until they get there. Also, you read pin 9 to figure out if you want to move to 180 or not. That has nothing to do with the "same thumb" in your post.
After you read a print, you can set a variable to remember you have seen that thumb and then move to 180 vs 90 if it is the same upon the next read.
After a much improved explanation, posting the code properly may help.
Posting the code properly means:
Using the Arduino IDE autoformat function on the code (CTRL-T on a PC).
Using code tags (looks like </> ).
Using copy and paste into the code tags.
The autoformat function helps the helpers.
Posting inline using code tags helps me and anyone else who uses a mobile device.
Copy and paste helps to avoid mistakes.
I am using Arduino UNO.
form initial position 0 it should go to 90 degrees from the first input and stay there for the second input.
it should stay at 90 degrees until me or anyone inputs a finger. after giving the second time input it should goto 90 to 180 degrees. till another finger input.
it is working now but perform only the first input and the servo stuck in the first position only not able to perform the second input.
Like I stated in reply#2, you have to keep track of where you are. This example will just step from 0->90->180->0... each time a valid fingerprint is scanned. You will get a lot of output since your code prints many messages every 50msec.
#include <Servo.h>
Servo myservo;
int pos = 0;
delay(5);
while (1) {
delay(1);
else {
myservo.attach(9);
// start are home (0)
myservo.write(pos);
getFingerprintID();
switch (p) {
return p;
return p;
return p;
default:
return p;
// OK success!
switch (p) {
return p;
return p;
return p;
return p;
default:
return p;
// OK converted!
return p;
return p;
return p;
// found a match!
// move to next position
if ( pos == 0 ) {
pos = 90;
} else if ( pos == 90 ) {
pos = 180;
pos = 0;
Serial.print( "Moving to " );
Serila.println(pos);
myservo.write(pos);
// found a match!
