Hello,
I want to measure for a project ,alternating voltage and alternating current. Im working in a frequency spectrum from 10 to 100 kHz, so its must be possible to adjust my sample rate accordingly. I have already tried some things.
syncADC();
ADC->CTRLB.bit.PRESCALER = 0x00;
syncADC()
or
while(ADC->STATUS.bit.SYNCBUSY == 1);
Either not working.
Have you guys other options or idees?
You mention that you require a sample rate of 100kHz. At this rate, it's probably better to use the SAMD21's Direct Memory Access Controller (DMAC) to transfer the ADC's results to memory. In addition to memory, the DMAC is also capable to transfering the data to other peripherals as well, such as SPI.
Here's an example that sets up the ADC for a sample rate of 107k samples per second, reads the data on A0 and transfers it to a memory array every second, using the DMAC:
// Use the SAMD21's DMAC to transfer ADC results to buffer array in memory
// ADC Clock: 48MHz / 64 = 750kHz
// Conversion/Sample Rate: (12-bit resolution / 2 + 1 delay gain) / 750kHz = 9.3us = 107.142kHz
#define SAMPLE_NO 512 // Define the number of ADC samples
uint16_t adcResult[SAMPLE_NO] = {}; // Store ADC values
typedef struct // DMAC descriptor structure
uint16_t btctrl;
uint16_t btcnt;
uint32_t srcaddr;
uint32_t dstaddr;
uint32_t descaddr;
} dmacdescriptor ;
volatile dmacdescriptor wrb[DMAC_CH_NUM] __attribute__ ((aligned (16))); // Write-back DMAC descriptors
dmacdescriptor descriptor_section[DMAC_CH_NUM] __attribute__ ((aligned (16))); // DMAC channel descriptors
dmacdescriptor descriptor __attribute__ ((aligned (16))); // Place holder descriptor
SerialUSB.begin(115200); // Start the native USB port
while(!SerialUSB); // Wait for the console to open
DMAC->BASEADDR.reg = (uint32_t)descriptor_section; // Specify the location of the descriptors
DMAC->WRBADDR.reg = (uint32_t)wrb; // Specify the location of the write back descriptors
DMAC->CTRL.reg = DMAC_CTRL_DMAENABLE | DMAC_CTRL_LVLEN(0xf); // Enable the DMAC peripheral
DMAC->CHID.reg = DMAC_CHID_ID(0); // Select DMAC channel 0
DMAC->CHCTRLB.reg = DMAC_CHCTRLB_LVL(0) | DMAC_CHCTRLB_TRIGSRC(ADC_DMAC_ID_RESRDY) | DMAC_CHCTRLB_TRIGACT_BEAT;
descriptor.descaddr = (uint32_t)0; // Set up descriptor
descriptor.srcaddr = (uint32_t)&ADC->RESULT.reg; // Take the result from the ADC RESULT register
descriptor.dstaddr = (uint32_t)&adcResult[0] + sizeof(uint16_t) * SAMPLE_NO; // Place it in the adcResult array
descriptor.btcnt = SAMPLE_NO; // Beat count is SAMPLE_NO
descriptor.btctrl = DMAC_BTCTRL_BEATSIZE_HWORD | // Beat size is HWORD (16-bits)
DMAC_BTCTRL_DSTINC | // Increment the destination address
DMAC_BTCTRL_VALID; // Descriptor is valid
memcpy(&descriptor_section[0], &descriptor, sizeof(descriptor)); // Copy the descriptor to the descriptor section
ADC->INPUTCTRL.bit.MUXPOS = 0x0; // Set the analog input to A0
while(ADC->STATUS.bit.SYNCBUSY); // Wait for synchronization
ADC->SAMPCTRL.bit.SAMPLEN = 0x00; // Set max Sampling Time Length to half divided ADC clock pulse (2.66us)
ADC->CTRLB.reg = ADC_CTRLB_PRESCALER_DIV64 | // Divide Clock ADC GCLK by 64 (48MHz/64 = 750kHz)
ADC_CTRLB_RESSEL_12BIT | // Set the ADC resolution to 12 bits
ADC_CTRLB_FREERUN; // Set the ADC to free run
ADC->CTRLA.bit.ENABLE = 1; // Enable the ADC
ADC->SWTRIG.bit.START = 1; // Initiate a software trigger to start an ADC conversion
DMAC->CHCTRLA.reg |= DMAC_CHCTRLA_ENABLE; // Enable the selected DMAC channel
while(!DMAC->CHINTFLAG.bit.TCMPL); // Wait for the DMAC to transfer complete(TCMPL) interrupt flag
DMAC->CHINTFLAG.bit.TCMPL = 1; // Clear the DMA transfer complete (TCMPL) interrupt flag
for (uint16_t i = 0; i < SAMPLE_NO; i++) // Display the results on the console
SerialUSB.print(i + 1);
SerialUSB.print(F(": "));
SerialUSB.println(adcResult[i]);
SerialUSB.println();
delay(1000); // Wait for 1 second
lucccc:
Hello,
syncADC(); router-help.com - This website is for sale! - router help Resources and Information.
syncADC()
or
Either not working.
