I am using a simple analog read with no delay function to read a sensor value. I would like a sampling rate of 1KHz, but I'm told Arduino Nano (which I am using) has a default sampling rate of 9Hz. I am told this rate can be modified by changing prescaler value. I would like guidance on how to do that so I can reach the range of 1KHz.
One more thing, would this sampling rate be easier to achieve on a ESP32 Wroom?
Your topic has been moved to a more suitable location on the forum. The IDE 2.0 section is for problems with the IDE, not for problems with (nor for advice on) your project.
OK
In that case it will take 100 microseconds for the ADC to convert an analog signal to digital.
When the sketch executes a analogRead(), it will stop the program for 100us until the conversion is done.
