save data from Arduino in CSV file, Processing
Dear , I am new here and arduino I need save data from Arduino to csv. file. How I make csv file from code below
int sensorPin = A0; // analog input pin to hook the sensor to
int sensorValue = 0; // variable to store the value coming from the sensor
float val=0.0;
Serial.begin(9600); // initialize serial communications
sensorValue = analogRead(sensorPin) ;
val=sensorValue*(5/1023);
Serial.println(val);
delay(10);
that is simple code for measure voltage from analog input. How I can make csv in Processing? Thanks
You don't. The Arduino has no place to store a file, regardless of what format the data is in, or what extension you want to use.
Processing comes with lots of examples, just like the Arduino IDE. Processing comes with a forum, too, just like here.
They don't much like Arduino questions there. We don't much like Processing questions here, either, unless they are specifically about how to get data to or from Processing.
How I can save data from arduino code in csv file on example Excel?
vicas:
Using Processing? Did you not understand that that is a Processing question, for the Processing forum?
Did you not understand that the Processing folks provided you with examples that read from and write to files. Did you even look at any of them?
vicas:
float val=0.0;
delay(10);
look i.e. at this link Saving Arduino data with Processing - Processing 2.x and 3.x Forum
This may help you.
f41_ardu
Hi vicas,
the tool PLX DAQ runs in Excel and captures all information from the serial port and lists it in a worksheet.
This worksheet can afterwards be saves as a CSV or you can create graphs etc there directly.
PLX DAQ can be found for example here: PLX-DAQ version 2 - now with 64 bit support! (and further new features) - Interfacing w/ Software on the Computer - Arduino Forum
A tutorial for PLX DAQ (which is really really easy to use) can be found here (Arduino and real time charts in Excel « Robottini) or many times on Youtube.
Good luck
A super simple way to record data is by using these Processing and Arduino Programs.
They send data using markers to tell Processing when the transmission is starting and ending and are quite easy to use.
PaulS:
dont have to be negative.
You're responding to a 4 year old post, don't expect a reply.
